Auto to manual
6 replies to this topic
#1 donplayahat
donplayahat
  • 201 posts
  • Interests:tennis, soccer, and cars
Posted 07 May 2009 - 10:37 AM
I might do I swap but first I need to know what I need exactly and how much for everything. I full swap that is. I appreciate the help.
Also what do ya recomend for it.
Edited by donplayahat, 07 May 2009 - 10:38 AM.
'88 quest tsi black, 3" full exhaust, s16g at 18 psi, 255 walbro pump
'88 quest tsi silver, stock (FOR SALE $1,500 OBO)
'91 honda accord white, two door, stage 1 exedy clutch, short ram air intake, 2.5" cat.
'72 honda 600(cars not bike) trying to restore. coupe and sedan.
#2 AndyW
AndyW
    Badda Bing
  • 3,221 posts
  • Interests:Andy W
Posted 07 May 2009 - 12:18 PM
QUOTE
A complete parts car.  Seriously.
The amount of small things that are needed from begining to end can best be had with a complte donor car.  Peddles (all 3) hanger welded in under the dash to hang the clutch, 5 speed tranny, (making sure to pop out the brass plug in the back of the automatic crank.) Hyd setup (drilling the hole thru the firewall behind the brake booster is a bear) chasing wires so your reverse light s work, 5 speed drive shaft.  custom brackets to mount the 5 speed itself, hacking the hole thru the tunnel larger, pounding the tunnel in so your gas peddle dosnt rub.
Personaly I wont do another.  thats why I just did a rebiuld on my auto.  Was ALOT easier than I had anticipated and far cheaper than doing another 5speed swap even tho I had all the stuff to do it.
AndyW
#3 donplayahat
donplayahat
  • 201 posts
Posted 07 May 2009 - 01:15 PM
How much was it for ur rebuilt in the auto tranny
#4 AndyW
AndyW
    Badda Bing
  • 3,221 posts
  • Interests:Andy W
Posted 08 May 2009 - 06:43 AM
QUOTE (donplayahat @ May 7 2009, 02:15 PM) <{POST_SNAPBACK}>
I did it myself and had about $200 into it.  I was lucky tho and my OD drum wasnt chewed up at all so I was able to reuse it.
I got a basic gasket rebuild kit and filter for about $50ish (transmissionpartusa.com item 82026 & 82922)
New Kevlar Bands from Mike Meyerhoff on here for $25ish (plus core of your old ones)
and new HP cluthes were about $110 (Drivetrain.com ALTO part # 042740, 12 or 13 needed)
full fluid change was about $30
And take your time, dont tear into it untill you have all your parts.  and lay it out and take pictures.  Its not difficult but everything only goes back together one way.  Now would be a good time to send off your valve body to BaltTSI on here for a rework too wink.gif
Edited by AndyW, 08 May 2009 - 06:46 AM.
AndyW
#5 BC_99
BC_99
    Plays in traffic
  • 2,996 posts
Posted 01 June 2009 - 03:42 PM
If you do it...get a parts car if you can find one, like andy said. It'll save you so much time and energy. Then it just depends on what you wanna do with those parts....ie. lightening your flywheel, what spec clutch you go with, replacing u-joints in the driveshaft, how you decide to mount the tranny, and pedals, stock shifter or short throw....the list can get long. I just did the basic swap with a lightened 240mm flywheel and F1 stage 1 clutch, new slave and master cyls. and braided line for the slave cyl. read thru this for all the how to's.....
http://www.starquestclub.com/forum/index.php?showtopic=57557
it helped me a ton. Good luck with it.
BC_99
http://i601.photobuc.../IMG_2072-1.jpg http://i601.photobuc...lZ18yLmpwZw.jpg http://i601.photobuc...MDA0Mi5qcGc.jpg
If you do what you've always done, you'll get what you've always gotten.
#6 89BananaQuest
89BananaQuest
  • 625 posts
Posted 04 May 2012 - 05:37 AM
It hobestly wasnt that bad.  I bought a parts car for 400$ and used all of the parts out of it.  The hardest part was the pedals..  I had the dash out at the time so it made it alot easier.
#7 Frenchi934
Frenchi934
  • 2,740 posts
Posted 04 May 2012 - 10:00 PM
If anyone is looking to do this...
I have everything you need except the pedals available.
:D end shameless plug.
Edited by Frenchi934, 04 May 2012 - 10:01 PM.
My car on Racefriv.com
