jake88starquest Posted March 12, 2009 Report Share Posted March 12, 2009 (edited) QUICK HELP if anyone is around? I FOund some Ruff racing 18 by 9.5 and they are our bolt patter with a 35mm Off set.. Just need to know If i would have to run a spacer or Cut spring perchers with that? He is trying to sell them Quick and i want to scoop them if they will work! THAnx!!! Edited March 12, 2009 by jake88starquest Link to comment Share on other sites More sharing options...
Sully Posted March 12, 2009 Report Share Posted March 12, 2009 you'll need spacers... big ones. Not sure about perches.. that will depend on the tire. Link to comment Share on other sites More sharing options...
jake88starquest Posted March 12, 2009 Author Report Share Posted March 12, 2009 you'll need spacers... big ones. Not sure about perches.. that will depend on the tire. Thanx for the help! if i got to run spacers I dont want to buy them! spacers R scarry! lol.. i like lug nuts having a stud! THAnx for the help! that sux cause it was a good Deal on the rims Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 12, 2009 Report Share Posted March 12, 2009 there was a guy with Ruff Racing wheels on his conquest, i saw pictures of it.. it was a fiji with some strange white graphics on it.. they seemed to fit but they werent flush so if you dont care about that they should work for you. If the seller is local just do a test fit Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted March 13, 2009 Report Share Posted March 13, 2009 Thanx for the help! if i got to run spacers I dont want to buy them! spacers R scarry! lol.. i like lug nuts having a stud! THAnx for the help! that sux cause it was a good Deal on the rims Bolt-on spacers do exist. And if you want to stay away from spacers altogether, prepare to buy custom offset rims for $550-1500 each depending on brand and size. Then you'll be lucky to not have to wait two or three months for them to arrive. Link to comment Share on other sites More sharing options...
jake88starquest Posted March 13, 2009 Author Report Share Posted March 13, 2009 Bolt-on spacers do exist. And if you want to stay away from spacers altogether, prepare to buy custom offset rims for $550-1500 each depending on brand and size. Then you'll be lucky to not have to wait two or three months for them to arrive. OK so i Bought the 2 Rears.. Here is a pic of them..http://i41.tinypic.com/opwx3n.jpg Cleaned them up a lil after i picked them up (opinions??) So ur saying i need spacers! to make this look right.. What is proper Stager to do for the fronts with this size for the back then? i guess next step is Where am i going to get a good spacer? and How safe is it using a spacer? I Plan on pushing the limets on my car and Dont want to loos a wheel! I have had lots of people tell me STAY AWAY from spacers! and i see alot of guys on here Runnig them! Soo Whats the Verdict! THAnx For all you help everyone! this wheel thing is not easy! It was easy slaping 24's on my truck.. This is work! Link to comment Share on other sites More sharing options...
michael knight Posted March 13, 2009 Report Share Posted March 13, 2009 (edited) To get close to stock rear offsets you'll need a 35 mm spacer. Stock offset for a rear 9" is 0 offset. What could you get awy with and still have them look good?.....Atleast a 15mm spacer. I think most guys would say for a 9.5" rim a good offset would be atleast -10. That would mean you'd need a 45mm spacer which is close to 2 inches. 25.4mm=1inch. -offset means pushed closer to fenders. +offset equals closer to strut. Currently I have a stock 8inch rim with spacer and my total offset is -25. For good spacers do an advanced search for "wheel spacers" in title only. That will get you in the right direction. Also, since I'm a track kind of guy i say no spacers. Unless you add longer wheel studs and don't get too crazy with the spacer size. On my studs I can go up to about 3/4" strait up non-bolt-on spacer. With that said there are loads of paople using bolt o huge spacers w/ no problems. My question is, how hard do you drive? More bad news. Your spacer will most likely need to be hub and rim centric if you don't want the tire flying off. Our hub bore is 67.1mm and not sure about your rims. Anyway, goodluck and hope you got a heck of a deal on them. Edited March 13, 2009 by michael knight Link to comment Share on other sites More sharing options...
Sully Posted March 13, 2009 Report Share Posted March 13, 2009 I use spacers all around and they got abused regularly. The sort of conditions you'll probably never see driving on the street. Never had an issue. Checked the torque on the spacers once in a while but they were never loose. Link to comment Share on other sites More sharing options...
D_Venable Posted March 13, 2009 Report Share Posted March 13, 2009 yes a 35mm spacer on the back will fit just fine. I use to run a 25mm spacer on a 22mm rear wheel (-3mm offset), same 18x9.5, with a 265/35 tire. I now run a 33mm spacer on the same rim (-11mm offset). The 33mm spacer requires fender rolling, the 25mm ones make everything clear Here's a before (25mm) and after (33mm) http://www.26liter.us/gallery/albums/userpics/10030/NewSpacer.jpg with the 35mm spacer on yours, you'll be fine, and they'll look good. Now for the front, try and find a 18x8.5, run a 245/35/18 on it, and look for a combined offset between 10-15mm, and it'll match the rear pretty well Derek Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 13, 2009 Report Share Posted March 13, 2009 If you peruse any other RWD import forum i.e. 240s and 350Zs you will see that a majority of the cars run spacers. Even competition drift cars run spacers so you shouldnt be scared of them, just make sure you buy them with the hubcentric rings. Link to comment Share on other sites More sharing options...
Sully Posted March 13, 2009 Report Share Posted March 13, 2009 I didn't run hubcentric rings. Neither did Chad's IMSA car. Which is why I wasn't too worried about them. its good for piece of mind though. Link to comment Share on other sites More sharing options...
jake88starquest Posted March 16, 2009 Author Report Share Posted March 16, 2009 I didn't run hubcentric rings. Neither did Chad's IMSA car. Which is why I wasn't too worried about them. its good for piece of mind though. OKKK.. I did a test fit And That Rim is All over my shock!! I took a pic hard to tell exaclty how much it is on it but Its on it like white on rice! I all so did a search for spacers in a few places and coming up short on that.. alot of 4 lug stuff for some reason? So Now what to do??? Sorry bout being a Pain in the A$$ here guys but I guess going to need some more input? Thanx again! http://i42.tinypic.com/11ah8ug.jpg http://i41.tinypic.com/ra2kbk.jpg http://i43.tinypic.com/2s7sv2t.jpg Link to comment Share on other sites More sharing options...
JustPaus_88TSi Posted March 17, 2009 Report Share Posted March 17, 2009 I bought mine from http://www.wheeladapter.com/ If you want hub and rim bore centric spacers, you'll need to find out what the rim bore diameter is. The SQ hub diameter is 67.1mm Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 17, 2009 Report Share Posted March 17, 2009 (edited) look on ebay for Mitsubishi spacers .. no need to get anything high end like Ichiba or Project kics when you are going to be running at least 25mm. a good pair with hubcentric rings should be like 60 bucks. Did you mount them on the front or the back? Edited March 17, 2009 by dem0ntsi Link to comment Share on other sites More sharing options...
jake88starquest Posted March 17, 2009 Author Report Share Posted March 17, 2009 look on ebay dude.. no need to get anything high end like Ichiba or Project kics when you are going to be running at least 25mm. a good pair with hubcentric rings should be like 60 bucks. Did you mount them on the front or the back? I "Set" i wouldnt even say mount lol.. Cause if i put them flush there is maby a Thread to hold it there.. MABY.. mounted them on just back because The front ones.. if i decide to keep will be 18 x 8.5.. (i put pix of the wheel sitting on the car in this thread.. (and be4 i get to diggin to much farther On these wheels i got to see if i can find a front set of them.. or i will be selling these 2.. or maken them in to Tables or somthing? lol I did check E-bay Didnt find much excpet 4 lug addapaters.. I am kinds getting discuraged allready! U have had several sets of wheels and all look reely good.. thats the only reason i Am still thinking i want aftermarket wheels! I dont want to wast money on buying tires for my stock rims.. if i going to keep looking for wheels.. I have a few sets of stocks i should look n see what condition they are all in! I reely like some of the aftermarket sets on the cars tho! Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 17, 2009 Report Share Posted March 17, 2009 (edited) i got have 4 sets(a set being 2) of spacers. 3 I bought off Ebay.. when I get home Ill check my email to find out who the vendor was and post it up here. FYI when you look up spacers on ebay dont look up Starion or Conquest, look up Mitsubishi Edited March 17, 2009 by dem0ntsi Link to comment Share on other sites More sharing options...
garychoffmann Posted March 17, 2009 Report Share Posted March 17, 2009 look up rx-7 spacer. they are 67.1, thats what I always run. You can get in any configuration or http://lmgtfy.com/?q=rx7+wheel+spacers Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 17, 2009 Report Share Posted March 17, 2009 1 inch spacers for 49.00 here on ebay this should put you at a +10 offset which will still be sunk in but should clear your struts with no problem. Link to comment Share on other sites More sharing options...
jake88starquest Posted March 17, 2009 Author Report Share Posted March 17, 2009 1 inch spacers for 49.00 here on ebay this should put you at a +10 offset which will still be sunk in but should clear your struts with no problem. Sweet! ya i was typing in wheel spacer and stuff for starion! no wonder nothing right would come up! so if i get these should i still by those hub centric Rings? i was reading the descriptions and said UNIVERSAL DESIGN ALLOW YOU TO FIT WHEELS WITH DIFFERENT HUB SIZES.. Or does that not apply when using those? Thanx Dem0nTSI! and everyone else for all the help! I think i will try it! Link to comment Share on other sites More sharing options...
dem0ntsi Posted March 17, 2009 Report Share Posted March 17, 2009 Sweet! ya i was typing in wheel spacer and stuff for starion! no wonder nothing right would come up! so if i get these should i still by those hub centric Rings? i was reading the descriptions and said UNIVERSAL DESIGN ALLOW YOU TO FIT WHEELS WITH DIFFERENT HUB SIZES.. Or does that not apply when using those? Thanx Dem0nTSI! and everyone else for all the help! I think i will try it! i dont know if these will come with hubcentric rings or not, I cant find the vendor Optionselect on there anymore. Link to comment Share on other sites More sharing options...
