83starionT Posted March 25, 2008 Report Share Posted March 25, 2008 I am having problems with the fuel injectors in my 1983. They are the injectors with the built in wiring and connector. At about 4500 rpms my car falls flat on its face pretty much and bugs up and down from there when i am flooring it. If i slowly rev through the rpm's it does fine. So, from what i have been reading here, i am pretty sure it is the injectors. I can't find them anywhere. Unless anyone has any other suggestions for me. Im new to starions so thx in advance. Link to comment Share on other sites More sharing options...
FlattopMike Posted March 25, 2008 Report Share Posted March 25, 2008 Don't be so quick to blame the injectors. They are obviously firing and that's all they are suposed to do. There is not a primary and secondary injector like later models. The fire together so the logic that you read in the VM forum doesn't hold true with our cars. Start with your filters. There is one in the tank. There is one inside the hose at the pump. There is a large one on the drivers fender well. There is one for each injector under the TB cover. Link to comment Share on other sites More sharing options...
83_project_toy Posted March 25, 2008 Report Share Posted March 25, 2008 Don't be so quick to blame the injectors. They are obviously firing and that's all they are suposed to do. There is not a primary and secondary injector like later models. The fire together so the logic that you read in the VM forum doesn't hold true with our cars. Start with your filters. There is one in the tank. There is one inside the hose at the pump. There is a large one on the drivers fender well. There is one for each injector under the TB cover. could also be a vac adv problem or tps problem Link to comment Share on other sites More sharing options...
83starionT Posted March 26, 2008 Author Report Share Posted March 26, 2008 It has a new fuel filter under hood, new thermostat, 180 deg., new feul line. I cleaned out the filters in the throttle body. The vacuum advance works correctly checking timing witha timing light. The wires on the injectors are very dry and brittle all the way up to the injector and i tried to cover all the wire breaks but i figured maybe enough voltage couldn't travel through the wire or something like that. Its good to know that they fire at the same time, i just got the factory service manual for the 83 in today so i am gunna read up. I am in need of the one way EGR valve so i can make my car pass emissions. I also need the piece that goes into the head where the secondary filter goes into. When i got this car it was trashed pertty much a parts car. I have since within two weeks made it run. It sort of idles irratically when it warms up, when i first start it it runs smooth. As soon as it starts to warm up it changes. Link to comment Share on other sites More sharing options...
83_project_toy Posted March 26, 2008 Report Share Posted March 26, 2008 It has a new fuel filter under hood, new thermostat, 180 deg., new feul line. I cleaned out the filters in the throttle body. The vacuum advance works correctly checking timing witha timing light. The wires on the injectors are very dry and brittle all the way up to the injector and i tried to cover all the wire breaks but i figured maybe enough voltage couldn't travel through the wire or something like that. Its good to know that they fire at the same time, i just got the factory service manual for the 83 in today so i am gunna read up. I am in need of the one way EGR valve so i can make my car pass emissions. I also need the piece that goes into the head where the secondary filter goes into. When i got this car it was trashed pertty much a parts car. I have since within two weeks made it run. It sort of idles irratically when it warms up, when i first start it it runs smooth. As soon as it starts to warm up it changes. welcome to the weird and very strange world of a 83 starion. but to be more clear with the injectors they both dont fire at the same time it's a counter fire thing. one fires then stops and as the first one stops the other fires and stops and so on. if your car runs smooth at idle it's hard to say that the injectors are the problem. whats the vacuum line look like going to the fuel pressure regulator? but the easist way to see if your injectors are leaking is to pull the pipe to the throttle body after the cars been run and see if there leaking. alot easier to see with a flash light. Link to comment Share on other sites More sharing options...
83starionT Posted March 26, 2008 Author Report Share Posted March 26, 2008 I am also thinking like you said change those filters to new inlines or something as well. The fuel was gelled up when i took the ECI cover off and apart. I was thinking of going with a walbro 255 and new sock for the fuel pump but i wanted it to run better first lol. Turbo spools nice and lots of power to around 4-4500 rpms. I thought it might be a boost leak but the gauge shows full boost even until it falls on its face, so i am thinking no. Link to comment Share on other sites More sharing options...
GAflatty Posted March 26, 2008 Report Share Posted March 26, 2008 my car kind of did the same thing and it ended up being durty fuel filters. I had replaced the one in the einge bay and had the tank boiled out and cleaned but it still fell on its face come to find out the tiny cone shaped filter at the fuelpump was blocked BIG time. i took it out and cleaned clean and then the car ran like a champ. be sure to check and clean that filter you might be suprised! just my $0.02 Link to comment Share on other sites More sharing options...
FlattopMike Posted March 26, 2008 Report Share Posted March 26, 2008 my car kind of did the same thing and it ended up being durty fuel filters. I had replaced the one in the einge bay and had the tank boiled out and cleaned but it still fell on its face come to find out the tiny cone shaped filter at the fuelpump was blocked BIG time. i took it out and cleaned clean and then the car ran like a champ. be sure to check and clean that filter you might be suprised! just my $0.02 That is the most overlooked filter. It can be accessed through an inspection plate in the back under the carpet on the drivers side. Link to comment Share on other sites More sharing options...
83starionT Posted March 27, 2008 Author Report Share Posted March 27, 2008 Thank you all for your replies, keep em comin. I will change the one by the fuel pump immediatly or at least clean it. Where is this other one, something about a fender well??? I need to check that one too. So how does this car drift?????? that was my main goal with my purchase... Link to comment Share on other sites More sharing options...
83_project_toy Posted March 27, 2008 Report Share Posted March 27, 2008 Thank you all for your replies, keep em comin. I will change the one by the fuel pump immediatly or at least clean it. Where is this other one, something about a fender well??? I need to check that one too. So how does this car drift?????? that was my main goal with my purchase... well drifting depends on if you have the lsd in the rear. Link to comment Share on other sites More sharing options...
83stariontravis Posted March 27, 2008 Report Share Posted March 27, 2008 Most 83s ive seen or heard about are not LSD. If you have the 15" sport wheels and ABS you probably have LSD. There may be a sticker in the door jam letting you know its there. Find an 86 starion/conquest rear end and torque tube for a direct swap. Late- Travis Link to comment Share on other sites More sharing options...
83starionT Posted April 7, 2008 Author Report Share Posted April 7, 2008 UPDATE!! Got the new injectors from chad now the car runs great!!! Link to comment Share on other sites More sharing options...
FlattopMike Posted April 7, 2008 Report Share Posted April 7, 2008 Good to hear. Everyone likes a happy ending. :thumbsup: Link to comment Share on other sites More sharing options...
83stariontravis Posted April 8, 2008 Report Share Posted April 8, 2008 so who is this 83StarionT? hmm. What does the T stand for? I have heard people are thinking your me... I guess as long as you don't disgrace the name. LOL. sorry not adding anything productive to this thread. Late, Travis Link to comment Share on other sites More sharing options...
Komeuppance Posted April 8, 2008 Report Share Posted April 8, 2008 Suddenly... Travis' name is not so original... LMAO... "My screen name is 83Stariontravis... I drive an 83 Starion... and... my name is Travis." -Robert Link to comment Share on other sites More sharing options...
FlattopMike Posted April 8, 2008 Report Share Posted April 8, 2008 Suddenly... Travis' name is not so original... LMAO... "My screen name is 83Stariontravis... I drive an 83 Starion... and... my name is Travis." -Robert + :biggrinumbrella1: :hmm3grin2orange: Link to comment Share on other sites More sharing options...
83_project_toy Posted April 8, 2008 Report Share Posted April 8, 2008 http://i18.photobucket.com/albums/b128/klinkzor/epic_fail.jpg Link to comment Share on other sites More sharing options...
Komeuppance Posted April 9, 2008 Report Share Posted April 9, 2008 LMAO... You missed it Mike, Travis really did say that at the last meet we went to. -Robert Link to comment Share on other sites More sharing options...
83starionT Posted April 16, 2008 Author Report Share Posted April 16, 2008 The T just stands for turbo. Tough one i know, lol. And the only people who disgrace names are the ones who trash other cars on here. Link to comment Share on other sites More sharing options...
FlattopMike Posted April 16, 2008 Report Share Posted April 16, 2008 Don't worry, you couldn't possibly disgrace the name more than Travis does on a daily basis! We don't trash other cars, only Travis. But he knows that it is all in fun. :chair: Link to comment Share on other sites More sharing options...
83starionT Posted April 19, 2008 Author Report Share Posted April 19, 2008 Well the car has passed colorado emissions. Got collectors tags for it so never have to re-emission test it again. Link to comment Share on other sites More sharing options...
yoshi Posted April 22, 2008 Report Share Posted April 22, 2008 my car kind of did the same thing and it ended up being durty fuel filters. I had replaced the one in the einge bay and had the tank boiled out and cleaned but it still fell on its face come to find out the tiny cone shaped filter at the fuelpump was blocked BIG time. i took it out and cleaned clean and then the car ran like a champ. be sure to check and clean that filter you might be suprised! just my $0.02 Awesome $0.02c worth GaFlatty...Thanks...I will do that regardless while I am still deciding on a head in terms of the better price to go Link to comment Share on other sites More sharing options...
idriftnaked707 Posted April 23, 2008 Report Share Posted April 23, 2008 Thank you all for your replies, keep em comin. I will change the one by the fuel pump immediatly or at least clean it. Where is this other one, something about a fender well??? I need to check that one too. So how does this car drift?????? that was my main goal with my purchase... from my personal drifting experience on my 83, you wont do that great with the 1 legger diff, its just hard to keep angle with a non lsd. now i have a diff from a 87 widebody that i had sittin. i can keep angle for days now. then again it would help to stiffen up the suspension to get rid of the insane body roll that our cars have from stock. well like project toy said, welcome to our wierd world of the 83, i might have 1 good injector laying around if your interested. i decided to do the 4g63 swap now so i MIGHT have some really clean 83 parts for sale soon (all of you thats seen my car know what im talking about) but im still thinking about it since the setup is so rare. anyway good luck Link to comment Share on other sites More sharing options...
Komeuppance Posted April 23, 2008 Report Share Posted April 23, 2008 Interested in 83 parts for a resto... tps isc injectors perhaps TB -Robert Link to comment Share on other sites More sharing options...
FlattopMike Posted April 23, 2008 Report Share Posted April 23, 2008 Interested in 83 parts for a resto... tps isc injectors perhaps TB -Robert Isn't your garage full enough with projects? Besides, the way I run through parts, I'm going to need them all! Link to comment Share on other sites More sharing options...
