AEM Cal
7 replies to this topic
#1 tux
tux
  • 1,653 posts
Posted 02 June 2020 - 09:20 PM
Nobody has posted any of these yet, so I'll post the cal that I started with for idle and the cal that made it down the street.
The start and idle only is labeled as such
https://drive.google...iew?usp=sharing
AEM EMS-4
AEM EPM for engine position
AEM 5 Bar MAP
GM IAT
GM CLT
No IAC
Tach on GPIO 1 - required a mosfet to drive
GM LQ9 Coils - D585
MOPAR SRT4 Stage 2 injectors - 682cc at 65psi
AEM UEGO Wideband
Ford TPS
Ford 4.6L 75MM Throttlebody
20g1A turbo
Edited by tux, 02 June 2020 - 09:20 PM.
#2 tux
tux
  • 1,653 posts
Posted 13 July 2020 - 06:20 PM
More refined, but no boost allowed.
Idles perfect with Bosch 2 Wire IAC.  Starts after about 3 seconds.  Free rev looks good.
Still no street tuning yet.  Hunting down random oil leaks before I take it out.
#3 tux
tux
  • 1,653 posts
Posted 23 August 2020 - 09:44 PM
update map.  drivability up to 4 psi seems solid in most rpms.  No o2 feedback enabled yet.
Starts after 4 seconds of cranking
Edited by tux, 23 August 2020 - 09:45 PM.
#4 importwarrior
  • 18,391 posts
Posted 24 August 2020 - 08:46 AM
Good info thanks for sharing.
#5 tux
tux
  • 1,653 posts
Posted 24 August 2020 - 12:53 PM
Working on vss now with factory reed switch.  Will be update when it's working correctly
#6 87starion_in_ma
87starion_in_ma
  • 69 posts
  • Interests:working on cars and spending time with family
Posted 11 September 2020 - 09:43 AM
How did you get AEM epm to mount to the engine? I want to run this same setup.
#7 tux
tux
  • 1,653 posts
Posted 11 September 2020 - 10:06 AM
The epm comes with a sketch of how to machine the distributor.
I used a broken Magna distributor that I got for next to nothing and my machinist merged the two.
You can do the same with an OEM distributor.
Cost me about 200$ in machining.
I was originally trying to use a magna distributor, but the resolution (4-1) was too poor for the AEM to work well with Cool On Plug.
If the DSM cas plate was available when I started that would have been a cheaper route and I could just replace the cas disc with a higher resolution one (24-1)
#8 ucw458
ucw458
  • 11,737 posts
Posted 01 October 2020 - 11:02 PM
4G64 distributor accepts the AEM nissan 24-1 trigger disk.  4G64 dizzy fits a G54B with a 1/4" spacer.  You just have to move the dizzy adjustment bolt hole in the head or make a new adjustment slot as part of the 1/4" spacer.  That's what I run in mine and it cost $20 at the junkyard + trigger disk.
My 87
