Radiator?
12 replies to this topic
#1 TroyStarion
TroyStarion
  • 135 posts
  • Interests:Old race cars and classic rock
Posted 04 June 2019 - 06:17 PM
What are you guys running for a radiator? Seems like the only aftermarket is the CX Racing one, but I don't know if it bolts right up with the factory fans or not. Also, if you got a NOS or a good used one that you could sell for cheaper than the CX and you are near me (CT), send a PM.
Thanks
Troy
87' Sarajevo White ESi-R- Daily driver for the summer
87' Serbia Black ESi-R- SOLD
#2 Preludedude
Preludedude
  • 3,768 posts
Posted 04 June 2019 - 07:37 PM
Just go ahead and get a CXRacing radiator, and 2 12" slim electric fans....It will keep it very cool, and work perfectly...
#3 croquest87
  • 1,853 posts
Posted 04 June 2019 - 07:53 PM
Cx racing radiator is awesome. All bolts up like stock! Just make sure to bolt the fans to it  outside of the car and slide the whole assembly in  it's a half hr job.
It will also clear clutch fan assembly  if you ever go or wanna go that route. I had it in my car both ways.
#4 croquest87
  • 1,853 posts
Posted 04 June 2019 - 07:55 PM
Just like the post above says   get one!
#5 markhansenconquest
markhansenconquest
  • 3,809 posts
Posted 04 June 2019 - 10:05 PM
u can even run A/C...... clears the fan by 1/16 of a inch ............#DM copy
#6 importwarrior
  • 18,412 posts
Posted 05 June 2019 - 06:56 PM
Yes CX racing.
works great.
#7 TexasQuest
  • 9,236 posts
Posted 06 June 2019 - 11:00 PM
Factory fans will bolt onto The CX radiator.
88 Fiji Blue -TSi
#8 TroyStarion
TroyStarion
  • 135 posts
Posted 18 June 2019 - 06:44 PM
Got mine soldered up by a shop (It had pin-holes in it from the top fan bracket breaking off), put a fresh coat of paint on it and BAM! Good as new.
#9 88whitestarion
88whitestarion
  • 410 posts
Posted 11 July 2019 - 10:31 AM
Did anyone buy the optional shroud from CX? or just bolt the fans directly to the radiator. It appears the shroud is so flat it would actually decrease the flow outside the perimeter of the fan.
#10 markhansenconquest
markhansenconquest
  • 3,809 posts
Posted 11 July 2019 - 12:14 PM
use your stock fans and if they are bad change them out will NEW SUBARU fans,,,,,,,,,,there a post how to do it.................
don't pay for stuff u don't need ,,if stock will do.......IMO
Edited by markhansenconquest, 11 July 2019 - 12:16 PM.
#11 TroyStarion
TroyStarion
  • 135 posts
Posted 11 July 2019 - 04:40 PM
I've heard that the shroud on the CX is really bad for cooling at anything other than cruising. Stockies should do better as long as they work right.
#12 TexasQuest
  • 9,236 posts
Posted 11 July 2019 - 05:32 PM
I have the complete fan/shroud/radiator combo from CX Racing and have had zero issues with cooling.
88 Fiji Blue -TSi
#13 croquest87
  • 1,853 posts
Posted 11 July 2019 - 08:52 PM
Cx radiator works perfect for our cars w any fan set up .
Edited by croquest87, 11 July 2019 - 08:54 PM.
