How To: Change a Headlight
STEP BY STEP w/ pictures
3 replies to this topic
#1 techboy
techboy
  • 3,562 posts
Posted 26 November 2018 - 04:57 PM
I know this is a pretty simple thing - but with Starquestforums SOS no longer around I'm trying to help rebuild by documenting even the easiest of tasks.
So, here goes, changing a SQ headlap ...
TIME: 15 minutes a side (could be longer if you have rusted seized nuts/screws)
TOOLS: Philips or JIS Screwdriver, 10MM and 7MM nutdrivers
First, you need to remove the 5 screws that hold the black headlight surround in place.  There's 2 to the inside, and 3 on the outside.
If your surround is all faded looking, now would be a good time to pick up some trim and bumper paint in a spray can and give them a fresh coat. I did mine a while back, so they still look good.
In order to get the lamp actually out, you need to remove the metal headlight cover.  4 screws, 2 on each side.  You can use a screwdriver or a 10mm nut driver.
To get the lamp to come out, there is a silver metal trim ring around the lamp that holds it in place.  I can't remember if I changed these bolts out for something different when I did my restore, but mine are a 7MM bolt.  Like I said, I forget what OEM was, so you might have to grab something else.  There's 2 up top, and 2 down below.
The 2 down below are definitely in a hard to reach place.  If your car has decent pain and you don't want to ruin your header panel it might worth the extra minute to put a piece of painters tape on there to protect it before you go reaching in there with a tool.
Trim ring with the 4 bolts holding it in place removed.
Now, the lamp should pop out in your hand.
There's a three prong connector on the back.  It might have been on there for a while so pry it off gently.  (Sorry, didn't take a picture of that). Nonetheless, once that's off you have removed the headlight.
Grab your new one and reverse the process to put it all back together.  NOTE: If you look you will also see two long threaded bolts - one above and one to the side. Those are for adjusting the up/down and left/right pitch.  If your headlights are not aimed correctly, now would be a good time to mess with this too.
All back together.  Now, go do the other side.  It should go quicker b/c you know how to do it :P
All done.
Edited by techboy, 26 November 2018 - 05:00 PM.
#2 87redcat
87redcat
    10 years and counting...
  • 4,039 posts
Posted 27 November 2018 - 03:56 AM
Nice write up
#3 croquest87
  • 1,756 posts
Posted 27 November 2018 - 06:23 AM
Awesome job man  very detailed
#4 techboy
techboy
  • 3,562 posts
Posted 27 November 2018 - 10:49 PM
View Post87redcat, on 27 November 2018 - 03:56 AM, said:
Nice write up
Thanks both of you.
Moderators ... please feel free to move to appropriate FAQ section. :)
