1jz or 2jz transmission question
5 replies to this topic
#1 Rick50
Rick50
  • 74 posts
Posted 25 August 2018 - 01:03 PM
Can anyone tell me the measurement from the jz engine block to the center of the shifter hole? Is it only the mk3 supra version of the r154 trans that lines up with the shifter hole?
#2 aconro
aconro
  • 237 posts
Posted 10 September 2018 - 09:34 AM
Yes, the mk3 r154 is what you would want.  The tripod version of the R154 (came in the Soarer) has the shifter location moved back about 4-5".  It will still work, you would just have to cut a notch out of the shifter area on the tunnel.  There is a member that started a build thread on his 1j swap where he used the Soarer trans.
1988 Chrysler Conquest TSI Auto (Sold)
1987 Chrysler Conquest TSI 1JZ Swap - MS3-Pro, Holset HX35, ID1000, E85
2008 Dodge Caliber SRT-4
2007 Buell XB12R
#3 Rick50
Rick50
  • 74 posts
Posted 11 September 2018 - 04:44 PM
Thanks
#4 Ipjkcu
Ipjkcu
  • 50 posts
Posted 29 September 2018 - 11:28 AM
I myself used a getrag 6spd come from a 05 330i bmw. The gear ratio is amazing but requires cutting up the trans tunnel. The trans it's self cost me 600, that adapter plate /flywheel and clutch 1200.
#5 Funky Phil
Funky Phil
    Super Pooper
  • 6,423 posts
Posted 02 October 2018 - 05:37 PM
Tell me more
#6 Ipjkcu
Ipjkcu
  • 50 posts
Posted 24 November 2018 - 03:23 PM
Sent a pm Phil. But bought the adapter and cluth set up from pmc.
http://pmcmotorsport...er-gerabox.html
Collins adapters in the USA now also offers kits.  Depending on trans used. Depends on availability issues from off the self clutch kits. Mostly with the 330i/z4 6spd as it uses a 22 spline clutch. Kmiata, spec clutch do have some options as well as custom made setups
