Slight Slipping
11 replies to this topic
#1 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,081 posts
Posted 10 January 2018 - 08:04 PM
My '85 Auto Trans is starting to slip when I go from reverse into any forward gear. It doesn't slip if I first go to neutral and give it a little rev, then go into drive. I'm not so knowledgeable with automatics.
So if I back out of a parking spot, and then shift into forward gear, it will slip unless I give it a little rev in neutral first.
Just wondering if there is something I can adjust, or what the best course of action is at this point.
The fluid and filter was changed about 10K miles ago and kept full always. Fluid looks very clean.
Works better and doesn't really slip at all after it is fully warmed up and I've driven a few blocks, so I am sure to let it fully warm up. Then it only slips on the first reverse-forward shift.
'84 Dodge Conquest Parts car
#2 croquest87
  • 1,284 posts
Posted 11 January 2018 - 07:47 PM
Hello there had same issue  ended up custom making some bushings for the linkage  and had local shop do some adjustments was loosing pressure drove it w gage hooked to the tranny and pressure would drop suddenly  complete re build later and no issues   fibers from all the clutches had overtaken every port and filter so it would clog everything and not let fluid pass to the right spots
#3 Tim_C.
Tim_C.
  • 10,081 posts
Posted 14 January 2018 - 07:15 PM
Yeah, that makes sense. I was hoping to not need to pull the trans and rebuild it of course.
#4 importwarrior
  • 18,174 posts
Posted 15 January 2018 - 06:51 PM
Possibly bands need adjustment???
#5 Tim_C.
Tim_C.
  • 10,081 posts
Posted 20 January 2018 - 04:54 PM
Yes, I looked in the FSM and didn't see where the adjustment is. I'll look again. I'm also concerned that adjusting them tighter would eat the drums worse and make the eventual rebuild require bands and drums.
I have some new bands to put on but it seems to me that it would be better to clean and rebuild it entirely when I put them in.
Is there a good place to get new drums from? I'd have to think they are getting very rare so I might just buy them now too, if they are available.
I took it for a drive on the highway today. It doesn't slip at all when the engine has run fully warm for a few minutes. So I let it warm all the way up before I take it out of the driveway.
This one is my winter driver because I have studded snows on it and it is a posi-trac rear. My '83 daily driver is a one wheel wonder. I have a posi out of an '84 to put in it when I have time.
Anyway, I like to drive the auto in the winter, but I'll probably let it sit most of this winter until I take car of the trans.
#6 fuel
fuel
  • 152 posts
Posted 20 January 2018 - 07:20 PM
I would at the very least drop the pan, look at the condition of the pan magnets and replace the filter and re-fill up to the correct level.
#7 croquest87
  • 1,284 posts
Posted 21 January 2018 - 02:03 PM
Not sure if you have ammco transmission places around you?   They found parts needed   Mechanic there said it is a Nissan transmission once he got into it and ordering things
#8 BuGG
BuGG
  • 1,949 posts
Posted 21 January 2018 - 02:08 PM
Yeah mazda used it too.  I remember a while back someone needed drums but could not get new ones.  Had to source good used ones.
#9 Tim_C.
Tim_C.
  • 10,081 posts
Posted 28 January 2018 - 09:04 PM
Thanks you guys. I'll check around for some drums because I'm sure it will need it eventually. Then maybe I could just pull the pan and try adjusting the bands without concern about making the drums worse.
Or, just pull it all apart and rebuild it before too long.
#10 Tim_C.
Tim_C.
  • 10,081 posts
Posted 14 February 2018 - 10:47 PM
Well, the water pump on my wife's Buick went out. I just replaced it with a new NAPA about 20K miles ago.
Anyway, so the only other car I have that she can drive is this '85 Plymouth Conquest auto. It actually did well for the week or so she had to drive it. I did try some Lucas 'Stop Slip'. We have put about 300 miles on it since and still not slipping. Had to pay a mechanic to swap the water pump since I was traveling. Nothing that another $500 couldn't cure! Money I hoped to spend on other projects including this one.
#11 Tim_C.
Tim_C.
  • 10,081 posts
Posted 05 November 2018 - 11:51 PM
Update on the trans: It has been running fine all year. Granted, I only drive it once a week or so. About 2,000 miles more on it with no issues since putting in the Lucas 'Stop Slip'.
#12 croquest87
  • 1,284 posts
Posted 06 November 2018 - 03:36 AM
Cool it's still driving l like it. Watch this video if you get a chance.
https://youtu.be/o690DovjDAc
#13 Tim_C.
Tim_C.
  • 10,081 posts
Posted 11 November 2018 - 05:37 PM
Yeah, good info. Mine looks between good and replace. LoL! i did change it when I first bought the car at around 80K miles. It had probably never been changed before that. It didn't look black and never smelled burned.
I'm just afraid to change it again at this point because it really will need some rebuild attention.
Thanks again.
