Fuel Issue
3 replies to this topic
#1 03CL55AMG
03CL55AMG
  • 586 posts
  • Interests:cars and more cars, and hot girls
Posted 25 June 2017 - 09:45 PM
Just curious if anyone has run into what I ran into, so I have after market Injectors.. 950/1800 and I had been running 45 to 46 lbs fuel pressure. For the most part, no issues... But occasionally under light to moderate gas pedal modulation, I would experience dead lean...like there was no fuel at all. If I let off a little on the gas it would come back to life. So , I thought... Bigger injectors probably need a little more fuel pressure. Well the problem got worse with 50 lbs pressure, so I went the other way and backed it down to 42lbs...and that cured the issue, I am not sure why...was thinking maybe the more pressure created void or air in the injectors... Don't know. I thought I would share this, perhaps someone else is experiencing this.
Forged motor, weisco pistons ,3" exhaust, garret 60 cold/ 96 hot turbo, 950/ 1800 injectors , 52mm tb, maft, meth kit.
#2 Preludedude
Preludedude
  • 2,830 posts
Posted 25 June 2017 - 09:57 PM
You running stock ecu?   Maybe a delay before secondary injector kicked in?
Aftermarket inj usually perform around 42-44psi
#3 importwarrior
  • 18,239 posts
Posted 26 June 2017 - 04:48 AM
what are you tuning with? i had similar issues but also am using MAF-T.
#4 03CL55AMG
03CL55AMG
  • 586 posts
Posted 26 June 2017 - 09:42 PM
Tuning with Maft right now, I am running a stock ECU...it would happen below 3 grand, isn't that when the secondary kicks in. Hopefully pretty soon I will wire up the Gen 2 Maft and some sensors..I will Road test some more soon and see if the issue stays cured.
