Cam Relationships
duration LCA overlap
2 replies to this topic
#1 scott87star
scott87star
  • 4,999 posts
Posted 30 October 2015 - 12:26 PM
Time to add something to the cam forums.  Y'all have heard the terms, here's the math that defines the cam parameters.  First, the definitions.
Overlap:  period in crank degrees when both intake and exhaust valves are off the seat.
Duration:  period in crank degrees when one valve is off the seat (seat to seat duration) or at a given lift value (0.050" typical).
LCA:  lobe centerline angle or the angle in crank degrees between the peak of the intake lobe and the peak of the exhaust lobe.  Note that in a single cam (overhead or in block) application the LCA is ground into the cam, in a dual overhead cam application the LCA can be altered using adjustable cam gears.  Either way the math still applies.
Duration = (overlap/2 + LCA)*2
Overlap = (duration/2 - LCA)*2
LCA = (duration - overlap)/2
Point being if someone gives you two of the values you can calculate the third, they are all inter-related.  Put another way you can't have big duration and overlap without having big LCA, it is forced into the design.
From the FSM, stock slipper lobe cam specs:  Overlap 45 degrees, duration 264 degrees, the LCA must then be (264 - 45)/2 or 109.5 degrees.
#2 87redcat
87redcat
    10 years and counting...
  • 3,858 posts
Posted 30 October 2015 - 03:16 PM
Good info. Thank you
#3 creakyjoints
creakyjoints
  • 1,939 posts
Posted 30 October 2015 - 03:32 PM
Cams are all about the bump n grind.
