MPGorBOOST
Hey All,
Feel free to text or PM me about the parts and I'll reply asap. I've some of these parts in storage so it might take me a day or two to get you some pics. Please provide zip code for shipping estimates and include your address when sending Paypal. Add 3% to cover Paypal fees or you can gift it. More pictures and parts to come.
Rob
9099085313
Woodystiles@gmail.com
Paypal: Woodystiles@gmail.com
PARTS AVAILABLE:
(1)88' transmission waffle pan- $25
*DM- 3" Exhaust(flat on bottom from speed bumps)with a magnaflow 3" in/out muffler- $200
84' Rubber shift knob- $20
(2)88' Rubber shift knobs- $20ea
Clean Gas Tank (Local Pickup)- $120
Passenger Side Front Black Starion Floor Mat- $40
Rear Hatch Speaker Decks with Infinity 4"x6" speakers- $80
Custom Fiberglass/Foam Hatch floor(black) with spare tire cut out and battery relocate box(local pickup)- $100
88' Black auto seatbelt headliner w/o sunroof- $50
(1) Turbo Heat Shield- $25
Repaired, heat wrapped and stress relieved exhaust manifold(needs to be resurfaced on head side)- $80
(2) TBI throttle body top hats- $10each
(2) Intake manifolds- $40each
G54b short block (good block/crank, bad blow by)w/o oil pump/timing components-$150
(1)solid crank pulley with AC guide- $40
(1) 88 LSD Diff w/o pinion gear- $40
220mm flywheel- $70
Driver side/Passenger side windows- $80
(2) stock 12a turbos (no hotside/rebuild candidates)- $30 each
(1) grey rubber shifter boot- $20
86 plastic ignitor box- $40
(2) 88/89 metal ignitor box- $40
(2) 88/89 distributor- $50 each
(1) 84 ECU- $75
(1) 86 ECU- $75
(2) 88 ECU- $75
(6) AC fans- $20 each
(3) secondary fans- $30 each
(1) primary fan - $40
Maroon Radio bezel-$40
Grey Radio bezel w/garage door compartment-$80- No cracks
(1)Dash Cluster Cover-$20 (pending)
rear hatch and gas door cable- $30- Comes with handles
(1)83' front 4 lug wheel(not sure of size)- $30
(2)Painted 16x8 rears- $60 each
(2)Painted 16x7 fronts- $40 each
(1)Stock 16x7 front- $40
(1) repaired SHP 16x9 rear- $150
(4) Polished SHP 16x9 rears(polished inside and out) - $1,200
Misc rubber, odds and ends- .50-5$ (obo) + shipping
PARTS SOLD:
*DM 6 piece Polished Aluminum hard pipe kit with TurboXS recirculating bypass valve- $350 SOLD
*DM 4" Aluminum Intercooler- $250 SOLD (Louswheel)
*DM modified stock intercooler - $60 SOLD (Couth'nize)
*DM- Radiator- $250 SOLD (1987 Conquest)
MSD 6AL w/tach adaptor and master blaster coil- sold (chassispuke)
Polished Mitsu Valve Cover- sold (chassispuke)
88' Primary and Secondary Injector- $120 SOLD (conquestador)
88' Rebuilt Primary Injector- $100 SOLD (ocidious213) includes stock FPR w/sale
TBI throttle body top hat with fuel pressure gauge- $25 SOLD (BuGG)
Rebuilt oil cooler lines with thermo-tec heat shield hose- $50 SOLD (Infamous907)
Used Jet valve elimination kit- $15 SOLD (Crazy Larry) comes with Lizard Towel, lol
(2)solid crank pulleys w/o AC guide- $50each SOLD (BuGG)
(1) Funk Lock- sold
(1)88' transmission waffle pan- $25 SOLD (BuGG)
10" Montero oil cooler(fits stock oil cooler location)- $20 SOLD (Infamous907)
Conquest Tail lights- $100 SOLD (BuGG)
(1)Auto-down drivers side window switch- $50 SOLD (89StarquestNYC)
Cloth front and rear seats including door cards 9/10- $400 SOLD (chassispuke)
(1) Black carpet- $80- sold
(3) wheel caps for our rims- $10 each- sold
D2 Rear camber plates- $40- sold (zafalla)
83 hood, missing front vent, original faded paint,common heat depression from turbo- $340 SOLD
Turbo door handles- $50- sold
(1) 7" front wheel, polished lip, black center- $50- sold
83 Radiator(no coolant sensor bungs)- $60- sold
88 Radiator- $60- sold
Black bezel- $40 hairline crack on both sides SOLD (Turbo Cary)
Black center console- $60 SOLD (Turbo Cary)
Flatty mudflaps-$75- paint cracked and peeling, no rubber cracking, very flexible- sold
Sunroof-$40- sold
stock IC lines except accordian pipe- $40- sold
(2) 4bolt axles-$80pair sold (Carmaniac55)
(1) Turbo Heat Shield- $25 SOLD (93 GCX Turbo)
Baffled G54B oil pan- $40 SOLD (hopeful noob)
(1)88' Leather Shift Knob- $30 (BuGG)
Apexi S-AFC- $120 (CarlosFley)
Apexi AVC-r- $100 SOLD
240mm ACT Clutch, pressure plate and throwout bearing~30K hard miles SOLD
ARP head bolts(used)- $60
86' Factory service manual for conquest- $25
Used Schneider HD valve springs- $30
(1)rebuilt Mitsu alternator with AC delete bracket and belt- $40
(2) 6bolt axles- $120pair
Rebuilt 6 bolt axles- $150pair
(2)88' 5spd Transmission(hard 3rd and synchros going in the other)- $50each
FIP Short Throw Shifter- $80
Ported Big 16G Turbo, no shaft play- $350
W/Walbro Fuel Pump and inline fuel filter
NGK Wideband A/F monitor mounted in temp indicator on dash control- $150
Fleabay-New rising rate fuel pressure regulator- $20
Maft Translator and 3" GM MAF sensor- $175
http://i290.photobucket.com/albums/ll252/Project88Starion/6BD33AF1-E274-46AB-99E1-27790E258F90-804-000000C841316C4E_zpsea0da0ae.jpg
http://i290.photobucket.com/albums/ll252/Project88Starion/Parts%20for%20Sale/20150530_115740_zps14qum6ny_edit_1433778009260_zps1rtqnywd.jpg
http://i290.photobucket.com/albums/ll252/Project88Starion/Parts%20for%20Sale/20150530_115719_zpsjy1weqyl.jpg
http://i290.photobucket.com/albums/ll252/Project88Starion/Parts%20for%20Sale/20150530_115702_zpsrzyfwedl.jpg
http://i290.photobucket.com/albums/ll252/Project88Starion/Parts%20for%20Sale/20150530_090610_zpszova1snq.jpg
http://i290.photobucket.com/albums/ll252/Project88Starion/Parts%20for%20Sale/20150528_172114_zpsbxgigmhr.jpg
Edited by MPGorBOOST
Hi,
I'm interested in the single 16x9 shp rim that's been repaired.
I would need to have it properly boxed for overseas shipping to Oz.
Please provide pic..
Hey Everyone! I'll update the list with items pending later this evening. Pulling a double today and TGIF!!!! :D Thank you to those of that have already sent paypal and shipping info. I'll box things up this weekend and get them sent out by Monday. Pulling the motor tomorrow or Sunday for the peeps waiting for pictures of engine/tranny components. Bare with me. International shipping is new to me so give me a couple days to get you a quote. Any suggestions from members who've shipped overseas/international, which carrier is most reasonable? PM me please. -Rob Edited by MPGorBOOST
if you ship to Canada, use USPS, all other companies charge ridiculous fees for importing.
I would buy a crap load of stuff but need a starion first. lol
Good to know, thank you!
I received Paypal from a Brett LeaMaster. Please contact me, no parts were listed in your payment info.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
