In Need of Better Struts
Im on the hunt for nice struts as my fronts are blown and lowerider status bouncy now. My car is lowered on ST springs. I like the height and dont care to go lower. Is there any struts that will do the job for a lowered car? Ive searched a ton. I keep coming with MR2 inserts or Mookeehs. Mookeehs say they are 30% stiffer than stock. I have tried to find reviews but cant find any on the Mookeeh. Any suggestions? Thanks guys
Car in need
I come from a city full of potholes, ride quality was stiff on the highway, on the potholes the bad ones id bottom out but i bottom out with my tokikos aswell, they probably are stiffer than stock but not by that much, but i had no complaints about them
the agx's seem to be fine with most people (and they are adjustable).
The koni's are just a bit better in terms of quality and valving, but for a street car you'll be happy with the AGX.
once you have time and drive you can shorten your struts and convert to coil overs and still retain your AGX's. so in that sense they'll be able to stay in use as your car progresses.
MR2 mod FTMFW.
I have illuminas, set to max stiff at 5... I need slightly stiffer spring rates myself, I'm running some well-used-by-now 8k front/6k rears and they're a bit softer than I'd like.
-Robert
you think 8k is too soft? jeeze. what kinda issues make you feel they are too soft?
Have you not seen how low he is? He can't have springs that allow for more then 2" travel at most.
Also from reading above.... your shocks are not really going to make your ride soft / hard that is way more a function of your springs, the shock is there to contorl rebound from the springs, not to ride on.
The springs can only do so much when the struts dont control any rebound at all. I can push front font end down with one hand now. Was not that bad when I bought the car
ronnie, if you have access to metal fab stuff, it's pretty damn cheap to build a good set of coil-overs using high end products.
especially if you source some used items from members (maybe people here selling AGX inserts? ). Idk, I got my koni yellows, agx, sleeves, springs, camber plates for like $700 IIRC.
otherwise if you don't want to fabricate you probably gotta buy some D2 idk if anyone else makes a set up for these cars
