Dual spring Cosmos
#1
Posted 07 April 2012 - 03:26 PM
#2
Posted 07 April 2012 - 04:36 PM
Laodicea, on 25 May 2010 - 12:16 PM, said:
88 quest:
2.25" d/p w/ 3" cat back & 3" aero muff. (needs to be redone)
marnal head from dad ready for .5 lift w/1.6 rollers & 274H cam, adj. cam gear
felpro 8770 smashed down w/arp's
Accel 8mm wires w/blaster 2 coil.
o-ringed block(copper o-ring), 8:1 wiseco's .30 over, race prep'd rods, polished crank to standard bore w/more arp's
Bosch fuel pump w/ trilogy turbos rrfpr @ 38-40 & new replacement FIC injectors
3" GM Maf w/ maf-t (blow through set up..sorta)
Inovate lc-1 wideband
XTD - stage 3 clutch
port matched intake, ported exhaust housing
ported 17c/ hard pipes @/13 psi...for now..
...how much hp is that???
(apparently the same as my old engine @ 17lbs with the 17c,...... 249lbs of tq. 182 h/p all at the wheels)
SJ/Fremont starquests! Keepen it BOOSTED!!!
need a replacement fan sensor? Here's one! --> click me!! , works great! lower temp switch, kicks the fans on sooner.
:WARNING: constant nooblet questions and lack of knowledge on the G54B turbo engine, will result in constant criticism of said nooblet questions, and failure to understand that there is no DOHC head., please read terms of agreement and check the box stating that you are said to be over the age of 18, then proceed at your own risk.
#3
Posted 07 April 2012 - 05:37 PM
Bottom line - def go with the dual springs if you're ordering Cosmo's IMO.
Edited by Goddard, 07 April 2012 - 05:40 PM.
#4
Posted 07 April 2012 - 07:10 PM
#5
Posted 07 April 2012 - 07:11 PM
When you switch to these types of springs, you loose the stock tophat, which sits on the keyed ("D"-shaped) segment of the strut shaft. The new aluminum tophats I've found sit lower than the stock hats. this allows that keyed section to go up into the bearing up front, and the hole in the rear. although it may look torqued down, you've actually only bottomed out the nut on the threads. that small gap is then was causes most of all the clunking (aside from some major 3-wheeling action, or setting down from being jacked up in the air)
This gap then needs spaced from the bottom to keep that keyed area of the shaft out of the mounts (my fronts became wedged HARD in the front bearings because of this). a few grade 8 washers (I believe 5/8", but measure it yourself to be sure) cures almost any clunking issues with single springs.
Another thing that can cause clunking is that the threaded sleeve itself is moving, which if it's not installed correctly can and will move on you. Electrical tape and some 2.25" exhaust tubing will cure that when installing. (the stuff they come with to remedy the gap is harder to install)
It really comes down to personal preference on your part, but iirc the single spring setup will allow you to go lower in the end
-Derek
Edited by D_Venable, 07 April 2012 - 07:15 PM.
88 TSI parts car
#6
Posted 07 April 2012 - 08:24 PM
what els is comin out now? or whos making the complete sets? i havnt been around for some time now, seems like quite a bit has changed. all i know is D2 is making sets for us?
88 quest:
#7
Posted 08 April 2012 - 09:00 AM
#8
Posted 08 April 2012 - 10:08 AM
- Wrap 2 bands of electrical tape around the strut, at the top and bottom of where the tubing will sit. should only take a couple times around until the tubing goes on snug.
- Repeat above with electrical tape around the tubing so the threaded sleeve then goes on snug as well.
***Please note that these pics are on a shortened housing for an MR-2 insert conversion with new lower spring perch.
With tubing after a couple wraps of electrical tape under (I guess I forgot to grab a pic of just the tape on the strut)
Tape around the tubing
Threaded sleeve installed
88 TSI parts car
#9
Posted 08 April 2012 - 06:07 PM
Edited by Goddard, 08 April 2012 - 06:14 PM.
#10
Posted 08 April 2012 - 06:31 PM
After (I also shortened and flattened the stock plate with the D-hole when installing the secondary spring) -
#11
Posted 08 April 2012 - 06:35 PM
I just took the MR2 setup off my flatty
88 TSI parts car
#12
Posted 08 April 2012 - 07:09 PM
#13
Posted 08 April 2012 - 08:44 PM
Edited by bha280, 09 April 2012 - 07:48 AM.
