lets walk the diesel talk
86 replies to this topic
#21 wrngwae
wrngwae
    Always Smooth like Keith Stone
  • 3,450 posts
  • Interests:trying to keep this motor under the hood, and off the engine stand
Posted 31 March 2012 - 07:58 AM
the diesels were only wide blocks. i mated mine to an auto trans which was never an option ever in a diesel. i had to mod the starter and flex plate but it is doable so he can run the 5 speed or auto. i would recommend the auto myself. due to the taller gearing. those diesels do not like RPMS at all. also are you going to source a fuel heater/water separator? also your going to need a starter....the 2.6 will fit but its not gonna turn that beast over....300psi of compression......
Edited by wrngwae, 31 March 2012 - 08:16 AM.
1989 Conquest  MOTOR BUILT BY DAD!!!!!!!!!.20 over block. Wiseco pistons.new M28 head w/ ss valves. Holeset Hx35 at 25psi.Snow Performance Meth injection, hurricane MPI intake manifold. 750 injectors. 3" exhaust. 3bar map sensor. Ajusta Head gasket. ARP head studs. FIP updated by Scott87star to control spark, and boost. running MS2.0.6. XTD stage 3 clutch.  I'm likely forgetting something. http://www.enginemachineservice.com http://www.starquestgarage.com
Scotts the man! check out his store.  http://www.starquest...             My site provided by Natallica the sticker Guru http://nbingaman.wix.../gntperformance Posted Image
#22 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 31 March 2012 - 12:04 PM
How many PSI does a stock engine have? What's the static compression of that diesel engine?
#23 wrngwae
wrngwae
  • 3,450 posts
Posted 31 March 2012 - 03:30 PM
compression ratio of 21:1..... should be 300 psi...and that head,,,,,,,,has 17 head bolts
#24 white quest ky
white quest ky
  • 485 posts
  • Interests:conquests, starions, mopar, and my montero
Posted 31 March 2012 - 07:55 PM
Where did u guys find these diesel motors a website or what also if u dont mind me askin how much do they cost
#25 white quest ky
white quest ky
  • 485 posts
Posted 31 March 2012 - 11:37 PM
Lookin for a swap ib thw montero
#26 zmcreynolds
zmcreynolds
  • 40 posts
  • Interests:keeping the starion running, music, golf, so on and so on.
Posted 01 April 2012 - 10:53 AM
i do have a filter/ heater/water separator, the diesel came with the starter, and its going on the stock tranny
soshin usa, out of cali. and the motor without the auto tranny was 2 g's
Edited by zmcreynolds, 01 April 2012 - 10:54 AM.
#27 wrngwae
wrngwae
  • 3,450 posts
Posted 01 April 2012 - 07:48 PM
nice,,,,,should be an easy swap than! we need more pics man..........MORE PICS,,,,,,,lol
#28 zmcreynolds
zmcreynolds
  • 40 posts
Posted 05 April 2012 - 08:28 PM
i now have my flywheel from being resurfaced, and clutch. now i just waiting on a oil pan gasket, that will be here sat. morn.. hope to have the motor in this weekend with pics up shortly there after, and a vid by wed.
#29 zmcreynolds
zmcreynolds
  • 40 posts
Posted 08 April 2012 - 02:49 PM
Attached File  4.jpg   17.25K   143 downloads
Look what i got. TD Starion.  More pics coming soon
#30 Komeuppance
Komeuppance
    Amused.
  • 13,589 posts
Posted 08 April 2012 - 03:00 PM
Man I wish that pic were smaller!!
Haha... nice work... got any real sized pics??
-Robert
#31 zmcreynolds
zmcreynolds
  • 40 posts
Posted 10 April 2012 - 12:12 PM
http://s1066.photobu...IG.jpg&newest=1
here are a few pics, my progrip clutch, and then the engine in the bay.
Edited by zmcreynolds, 10 April 2012 - 12:14 PM.
#32 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 10 April 2012 - 12:26 PM
sweet. What are you going to do about vacuum for brakes?
#33 zmcreynolds
zmcreynolds
  • 40 posts
Posted 10 April 2012 - 08:43 PM
There is a vac. pump on the alt. that i will just run a vac. hose off of, to the tube on the brake booster.Then the bad news, starter is bad so i gotta wait on that to come in before i can even give it a test run. so now starts the ups ground waiting game.
#34 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 10 April 2012 - 08:47 PM
Yellow pages. Look for an alternator repair shop near you, don't buy a new one and throw the old one away, just get it repaired. these things are possible, ya know.
#35 kyle's89quest
kyle's89quest
  • 425 posts
  • Interests:2jz gte, precision 6765 turbo, no traction! :)
Posted 11 April 2012 - 05:05 PM
yeah this is gonna be sweet.
Posted Image   Posted Image
  What the heck is a conquest???.... Your Bout To Find Out!!!
#36 zmcreynolds
zmcreynolds
  • 40 posts
Posted 22 April 2012 - 12:58 PM
ok so i got the new starter in about 5 days ago, the diesel starter does not engage the flywheel, and the starions old old starter just dont have the nuts to turn the engine over. already tryed to make a franken starter, no go. so now im stuck with a TD starion thats done and just needs a starter.
Edited by zmcreynolds, 22 April 2012 - 12:59 PM.
#37 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
Posted 22 April 2012 - 01:06 PM
Is the battery dead?
#38 wrngwae
wrngwae
  • 3,450 posts
Posted 23 April 2012 - 06:23 AM
did you hook it to a 5speed or an auto trans? fly wheel should be the same auto is different. why is it not engaging? is it not reaching the teethe or shooting past them? there has to be some more reason why its not working.
#39 zmcreynolds
zmcreynolds
  • 40 posts
Posted 23 April 2012 - 02:49 PM
hooked it to a five speed but it came off a auto, the starter is not reaching the flywheel. the starter turn and does every thing its made to do but hit the flywheel.
#40 wrngwae
wrngwae
  • 3,450 posts
Posted 24 April 2012 - 10:19 AM
auto and maual are different. the flex plate teeth stick farther out than the fly wheel of a 5speed..... what i did was remove that hog ring off the starter gear,,,, remover the gear,,,, than flip it over. you will need to check if it rubs when not engaged.  if it does, you will have to remove some of the gear height. that is if your using a diesel starter.....
