lets walk the diesel talk
65 replies to this topic
#1 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
  • Interests:keeping the starion running, music, golf, so on and so on.
Posted 29 March 2012 - 12:02 PM
well here it goes. after having a friend do a turbo diesel swap in his 240Z and talk of a td starquest, im gonna do it. just recived a JDM 4D56T yesterday (35k on the motor) and im gonna get the swap done asap, post pics and any troubles as i go along.   till then
#2 speedyquest
speedyquest
  • 1,056 posts
Posted 29 March 2012 - 12:20 PM
Sweet man, its nice to see someone doing some unique. Get that sucker running!
Allen
1987 Flatty Starion -  Wiseco pistons, ARP head studs, Schneider springs, Martin valves, Clevite bearings, *DM 2.5" exhaust, Hahn Racecraft S16g, K&N air filter, NGK plugs & wires, GodSpeed bar / plate intercooler, Synapse Bov, 3 inch GM mas & Maft, Short route piping, 5 lug & LSD conversion, Jolyrgr stainless braided brake lines & oil feed line, AEM UEGO, Greddy Profec B II, Trust front strut brace, TEP rear strut brace,D2 coilovers, four 8" rears, car lightened significantly...  More to come!
1988 Maroon Conquest - Stock other than a 3 inch exhaust and a stage two valvebody in the tranny... yea its auto sadly but its my DD.
#3 wrngwae
wrngwae
    Always Smooth like Keith Stone
  • 1,662 posts
  • Interests:trying to keep this motor under the hood, and off the engine stand
Posted 29 March 2012 - 12:49 PM
if you need any help just let me know......... i did a 4d55 swap into a raider that Kane owns now....also could help you with some more power thru adjusting the fuel pump. there is an eccentric tapered cone that you can adjust for fuel delivery. just so you know.
1989 Conquest .20 over block. Wiseco pistons.new Marnel head w/ 1mm over sized ss valves. TEP hydraulic 272 cam. Holeset HE341 at 20psi. Stainless log manifold, hurricane MPI intake manifold. 75lb injectors. 3" exhaust. 3bar map sensor. Ajusta Head gasket. ARP head studs. FIP updated by Scott87star to control spark, running MSEXTRA. XTD stage 3 clutch. also running Scott's thermal barrier ceramic coating on the piston tops and the underside of the head, the thin film lubricant coating on the piston skirts, valve stems, cam, cam bearing journals, turbine shaft, turbo bearings, main bearings and rod bearings.  The thermal barrier blue on the exterior of the turbine housing and CHRA and an undercoating of thermal barrier ceramic on the turbine housing and CHRA.  I'm likely forgetting something.
http://www.oemmitsubishiparts.com
http://www.enginemachineservice.com
http://www.starquestgarage.com
Scotts the man! check out his store.
http://www.26liter.u....php?board=48.0
#4 Frenchi934
Frenchi934
  • 2,740 posts
Posted 29 March 2012 - 03:10 PM
interesting. should be pretty sweet
My car on Racefriv.com
#5 TexasQuest
  • 4,630 posts
  • Interests:Tsi's & VR4's
Posted 29 March 2012 - 03:11 PM
A+ for originality. Good luck! :)
88 Fiji Blue-Tsi
Zoom clutch, Fidanza flywheel, Stedebani shifter, KYB's, ST springs, abs delete, a/c delete, TEP steel brake lines, LSP braided cooler lines, MK1 silicone hoses, hard pipes, Turbo XS RFL bov, *DM 3" exhaust, TEP front & rear strut bars, SHP's
#6 Technology
Technology
    Addicted Starquester
  • 10,958 posts
  • Interests:Lots of boost!
Posted 29 March 2012 - 04:07 PM
Yeah, this is awesome! Take off that poopy mechanical fan and convert to electric!
#7 pagemo
pagemo
  • 819 posts
Posted 29 March 2012 - 07:13 PM
What kind of #'s is it capable of? Torque ... Mpg ect?
Cool swap!
2006 Silver Magnum SRT 8
#8 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 29 March 2012 - 08:42 PM
Cool swap!
stock #'s im going from about 170hp to about 115hp and from 220ft/lbs to about 175ft/lbs, and prolly 35+ mpg. from there its all how much money i put into it(as all ways), but going by team 1000 and there numbers on a 4D55T " We use 25psi-33psi boost in normal race. Max boost during testing conditions on racetrack is 37psi. At 29psi boost it produced over 200hp/295ft lbs torque on the dyno and would guess it make over 250hp and 400ft lbs of torque at 37psi." so with that its all open.im just looking forward to playing around with it and see what happens.
#9 Dred_85.5_TSI
Dred_85.5_TSI
  • 1,748 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 29 March 2012 - 08:48 PM
If you don't want the fan I would buy it from you.
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete)
   KYB GR2, Eibach Pro kit springs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates,
ABS, A/C, Cruise control.. deleted
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
#10 Technology
Technology
  • 10,958 posts
Posted 30 March 2012 - 08:41 AM
That's probably from the stock, small turbo. If you upgraded a bit, I bet you could get to the 250hp range with less boost.
#11 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 30 March 2012 - 10:28 AM
The G54B is out, gonna take some time to clean up the engine bay ( no more wire harness) and then drop in the 56T in about a week.
#12 NudeLobster
NudeLobster
    High speed low drag- good to friggin go.
  • 2,000 posts
  • Interests:working on cars, guns, anything mechanical.
Posted 30 March 2012 - 12:47 PM
This is sweeeet. I want to see a stack straight out the hood :D
-Justin
Posted Image Posted Image
Quote
owning a starion/conquest is like watching the best porn ever, while simultaneously hiting yourself in the head with a hammer and burning a 100$ bill
#13 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 30 March 2012 - 04:01 PM
that or out the pass, fender would be sweet. but imma keep my mookeeh exhaust
#14 Frenchi934
Frenchi934
  • 2,740 posts
Posted 30 March 2012 - 04:56 PM
so this is mostly a swap for fuel economy?
#15 Komeuppance
Komeuppance
    Amused.
  • Administrators
  • 13,476 posts
Posted 30 March 2012 - 06:05 PM
35mpg, if that's highway you'd have a range of 700 miles.
-Robert
#16 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 30 March 2012 - 07:49 PM
the swap is not for fuel economy, though i have read that some mighty maxs have tuned there 4d55 to 40+mpg. i think i just want to do a swap that has not been done before (i belive) and see what i can get out of it. plus i think its cool
#17 Technology
Technology
  • 10,958 posts
Posted 30 March 2012 - 08:35 PM
And over 80 dollars to fill it up.
#18 button
button
  • 1,736 posts
Posted 30 March 2012 - 09:03 PM
gas/diesel/electric, you have to pay to play.
So the 4d56t, is a wideblock only, or did it come in a narrow block varient?
Not that that is a killer, Bill makes an adapter kit to make it work in whatever.
-Jay
#19 Frenchi934
Frenchi934
  • 2,740 posts
Posted 30 March 2012 - 09:54 PM
Fair enough. Many members have talked about this, but i think itll be cool when you pull this off.
#20 NudeLobster
NudeLobster
  • 2,000 posts
Posted 31 March 2012 - 01:56 AM
tech, it's $80 to fill a car up with anything now. Diesel is cheaper here anyway :P
$4.24 for diesel...$4.54 for 87
-Justin
Quote
