Where is the inhibitor for the automatic trans located. The one that prevents starting in D.
Where is the inhibitor switch located
Started by
SunStreaker
, Mar 27 2012 04:27 PM
2 replies to this topic
#1
Posted 27 March 2012 - 04:27 PM
#2
Posted 27 March 2012 - 05:25 PM
Nvm I found it. It is located on the passenger side of the transmission.
#3
Posted 28 March 2012 - 07:28 PM
that's called a neutral safety switch as well, if your having trouble starting the car you should look at the bushings in the linkage, if they are bad you can get some o-ring type bushings and some other bushing at ace hardware in the spare parts bins to take up the slack, worked good enough for me for the last two years.
Replaced: vac advance, Delphi injectors, all vac lines, tees and check valves, all brake hoses and pads, Master cylinder, flex plate, torque convertor, T-stat(180), CTS, TPS, both fan switches to primary, rear speakers, door speakers
Overhauled: Distributor, TB, wiper system, electrical ground connections, dash switches, auto seat belt tracks, entire auto trans, entire fuel system, A/C system
Upgraded: 1st gen Mas, HKS bov, Walbro 255lph pump, S16G Turbo and increased boost to 15psi, Aeromotive rrfpr 13105, MSD 8910 Tach adapter, Comp Cams Fireball digital ignition system, 35 watt HID headlights (6000k) 1000w 4ch amp, 100A alternator, engine to chassis to battery ground (4ga), charging wire from Alt to Batt (6ga), 2.5" Catalytic converter, Magnaflow muffler, R134 A/C, Yellow top optima battery
Added: AEM wideband, rail mounted fuel pressure gauge, dual alternator fusible links
Eliminated: Cruise, ABS, Emissions, Vac pump
