Flatty with electric fans
4 replies to this topic
#1 starion1991
starion1991
    Its fast.....when it runs...
  • 1,971 posts
  • Interests:Rare japanese old school cars, Hookah, and my 4 sexy starions that dont run right due to my financial situation (being broke sucks!!)
Posted 02 March 2012 - 06:03 AM
After I've dropped the 86 running gear in my flatty I need to figure out a way to get the fans off the 86 running on this flatty.  The flatty never came with electric fans.  Although it dose have an ac fan of some sort.  What would be the best way of running these wide body fans?
#2 SFBMX88
SFBMX88
  • 1,359 posts
Posted 02 March 2012 - 11:10 AM
Do you still have the 86 radiator?  It has the temp switches mounted in it to trigger the fan relays.  You will also have to make a harness for the fans which will include relays and fuses.  I currently run two 12" fans rated at 10 amps each, so I run two relays, and fuse each circuit with a 20amp fuse.
#3 starion1991
starion1991
  • 1,971 posts
Posted 03 March 2012 - 09:10 PM
Yup, have the 86 rad and sensors.  Could you snap a few pics of your fan setup for me?  Also where do you have the main power running?
#4 SFBMX88
SFBMX88
  • 1,359 posts
Posted 07 March 2012 - 12:22 AM
I ran the power to the fans straight from the battery.  The fans will even run with the ignition switch off, but thats the way I wanted it.  I also added another circuit with a switch  in the cabin so I can ground the relays to turn the fans on manually.
Fan and radiator setup that came off my departed widebody:
My first fan harness(I have since made a new harness integrated into my megasquirt harness):
Installed:
...then a year later in 2009:
#5 flatty86
flatty86
  • 170 posts
Posted 16 October 2012 - 02:29 PM
NIce .... I like it.... This is somthing im going to have to do with my flatty.
