Partition software
10 replies to this topic
#1 vbrad511
vbrad511
  • 8,273 posts
Posted 30 December 2011 - 05:02 PM
I know this belongs in the Digital threads but I'm hoping for a quick reply. I've just formatted a 640gb drive and my computer reads it as 124gb. I've used a free partition program before to expand it, but that program's long gone. Anybody have any free fav's they use that are easy to use?
#2 holeysocks
holeysocks
  • 357 posts
Posted 30 December 2011 - 05:09 PM
does the drive mfg. have one might try them
Edited by holeysocks, 30 December 2011 - 05:11 PM.
#3 vbrad511
vbrad511
  • 8,273 posts
Posted 30 December 2011 - 05:33 PM
WD didn't offer any resizing software, that I could ID. I got a referral for EaseUS from a buddy before, found a dl link on Cnet, worked like a charm, easy too. Thanks though....  :)
#4 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,210 posts
  • Interests:I have an announcement to make, "Turbo........ That is all".
Posted 30 December 2011 - 05:36 PM
Hmm, I'm interested too as I have the same problem with a WD 640GB.
Question:
Are you running XP?
Edited by Dred_85.5_TSI, 30 December 2011 - 05:37 PM.
Posted Image   1984 Starion ES: Currently running 15psi, Stock block (ARP main and head studs rod bolts, Clevite bearings) BSEK, M28 NJV head with mechanical valve train gasket matched on intake and exhaust, Treadstone exhaust manifold and Holset HX35w with BEP turbine housing, MK1 3" stainless exhaust, Old skool HKS super BOV, 3" GM MAF with MAFT, Artinist's old 4" core intercooler, custom Aluminium hard pipes, S13/SR20 Aluminium radiator w/clutch fan, Innovate LC-1 wide band O2, `83 crank pulley with A/C removed.
   `88 5 speed trans with Stedbani short shifter, Stedbani poly trans mount and engine mounts, drilled and slotted rotors, Joly roger stainless steel braided lines(brake, clutch, oil cooler, and ABS delete).
   KYB GR2, Artinist sleeve coil-overs, MK1 poly bushings, Energy Suspension poly end links, MK1 Adjustable tension rods, Cusco front camber plates, Artinist slotted rear camber plated.
ABS, A/C, Cruise control.. deleted, Right hand drive E-brake handle.
... more to come
Feedback:
Feedback thread #1
Feedback thread #2I'm PayPal Verified
#5 vbrad511
vbrad511
  • 8,273 posts
Posted 30 December 2011 - 05:47 PM
Mine a WD 640 also. I used the top result here...
http://www.cnet.com/...tition&tag=srch
I'm on XP Pro, and this program worked well and was very fast and easy. I moved my 640 out to a 590, leaving a little room for future defragging,
#6 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,210 posts
Posted 30 December 2011 - 07:34 PM
yup I'm on XP professional as well. I will have to try that program. Thanks
... more to come
Feedback:
Feedback thread #1
#7 SidewaySStarion
SidewaySStarion
  • 526 posts
Posted 30 December 2011 - 08:17 PM
Is this hard drive IDE? Sounds like your motherboard is old enough to have the 48bit lba limit which limits you at 137gb which formatted sounds about right for your partition size.
http://www.48bitlba.com/
Edited by SidewaySStarion, 30 December 2011 - 08:17 PM.
#8 Dred_85.5_TSI
Dred_85.5_TSI
    Flatty Love
  • 2,210 posts
Posted 30 December 2011 - 09:38 PM
this is my mobo:
http://www.newegg.co...N82E16813131356
the HD is a WD caviar black 640mb
and I have SP3 installed
Edited by Dred_85.5_TSI, 30 December 2011 - 09:46 PM.
... more to come
Feedback:
Feedback thread #1
#9 Fuze
Fuze
    AKA @Battlemagnet
  • 2,695 posts
  • Interests:Chess Boxing
Posted 25 January 2012 - 03:25 PM
Might sound strange but the best drive tools are on a Linux install disk. Get a free linux distrubition like Mint or Ubuntu from distrowatch.com and burn the image on a CD. Boot off the CD and use the drive tools, you may have to begin an installation but don't worry, the drive tools are the first thing to come up and you can quit after that. The partition management is everything you will want.
Insta = @battlemagnet
#10 natallica
natallica
    Resident Graphics Guru
  • 3,007 posts
  • Interests:Music, Movies, Guitars, Family, Computers and Starquests!!!
Posted 25 January 2012 - 11:38 PM
Perhaps when the drive was formatted, it's formatted FAT32 or exFAT... Shouldn't it be formatted for NTFS for a 32 bit XP machine? I read there are GB limitations with different file formats...at least this is true for high GB flash media.
Just a thought :)
-N8
#11 BIL
BIL
  • 539 posts
Posted 04 March 2012 - 05:57 PM
Just ran across this...it might prove helpful
http://www.wondersha...m/disk-manager/
it's free
'89 TSi, MS-1 v3.0, Magna intake with 65mm, 750 cc inj, Fidanza, ACT2600, Turbonetics 60-1, log header by Chad, Tial 38 mm, cam and rollers, 3" turbo back exhaust, Magnaflow, Walbro, KDM hard pipes, KDM aluminum radiator, KDM 4" intercooler, Aeromotive FPR, Stedabani short shifter and urethane bushings, Accel coil pack, FIP distributorless pulley kit, ABS removal, BSE.
