rx-7 tranny swap
4 replies to this topic
#1 kadein13
kadein13
  • Pip
  • 49 posts
Posted 21 November 2011 - 06:57 PM
im looking to do a tranny swap for an rx-7 tranny but not sure what all i need to  change out i know i need a new bell housing but is the drive saft the same
#2 Frenchi934
Frenchi934
  • 2,749 posts
Posted 21 November 2011 - 07:46 PM
http://projectzerog....smissions.shtml
My car on Racefriv.com
#3 AUSSIEOLDIE
AUSSIEOLDIE
  • 62 posts
Posted 10 June 2012 - 05:47 PM
If you have not done this yet then this may help as I have an RX7 series 5 tranny in my JB flatty useing the bell as per the zerog pics.
1 the imput shaft is the same size and when mounted to the bell measure winthin a wisker of the same distance from the engine side of the bell.
2 the clutch spline &  spiggot bearing are the same size
3 the speedo cable fits straight in as well as the reversing switch
4 the extension housing has to be shortened so the rearmost bolts screw into the front holes
5 the trans will require a  custom xmember
6 the trans will be at app 15 deg angle so the stick will lean towards the driver which is great for LHD But in a RHD  will need to be bent upright otherwise it is too far away.
7 the drive shaft will need to be shortened by app 100mm/4 inches and have a new yoke fitted at the front
8 I lift the side of the car up to get the trans app upright and remove both flller plugs and fill thru the top hole till oil runs out of the lower one then you will have the correct volume of oil in the 7 tranny
TIP  my 7 trans was very notchy and tried several oils and 1 additive and no change and was about to tear it out for a rebuild and changed to Redline LW synthetic oil ( called Smurf Blood over here LOL) and the shift feel improved almost straight away and continued to improve the more I drove .
Was so impressed by the trans oil that I have changed the oil in my TC stroker to Redline as well and the lsd will be getting Redline soon.
Edited by AUSSIEOLDIE, 09 August 2012 - 04:26 PM.
I've had mine since 1992!
#4 AUSSIEOLDIE
AUSSIEOLDIE
  • 62 posts
Posted 23 June 2012 - 03:32 PM
I have a 3.9 diff and when the speedo shows 100kph (60 mph ) the sat nav says the true speed is 105 kph so if you have a 3.5 diff the speedo will read app 10% out
#5 Zone
Zone
  • Banned
  • 134 posts
  • Interests:Starquests!!!
Posted 02 July 2012 - 12:33 AM
All very good information guys.
I just got my hands on a B2600 bellhouseing today.
Not to hijack,  but cant the bellhouseing fit a RX8 transmission too ?
Edited by Zone, 02 July 2012 - 12:59 AM.
88 Quest 5Speed, 1gmas, Fidanza flywheel, HID, MegaSquirt!!, D2 Suspension
160'stat, 3" exhaust, MK1 SS, F1Stage3 Clutch, M28 nonjet head, KDM Aluminium Rad, ARP & and fresh rebuilt motor with less then 5k miles
85.5 Starion 5Speed, New clutch, TBI rebuild, 3" exhaust, 87control harness
