RWD transmission replacement for the KM132.
5 replies to this topic
#1 Bag-O-Chips
Bag-O-Chips
    Too close for missles, switching to guns!
  • 1,250 posts
  • Interests:welding toothpicks to battleships.
Posted 29 October 2011 - 10:35 PM
Has anyone researched the details on the RWD transmission bolted on the 2.4L 4G64 equipped Montero Sport?
The 2.4 Montero sport came equipped with a 5 speed R5M21 and bolts on the Wide block. Not only that but It's also a Hydraulic Clutch setup.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
E85, GT4088R, Dual Synapse 50mm wastegates, Apexi AVC-R, Griffin Radiator, 2G Eclipse Flexalite fans, AEM 30-1300, HKS 301 cam, LSP built Marnel head, Del West 1mm oversized Titanium valves, Del West Titanium Valve lock/retainers, LSP Valve Springs, 1600cc injectors, SX AFPR, Fuelab Prodigy 140gph pump, Fuelab Filter, Bag-O-Chips  Twin scroll header, Chad's MPI Manifold, 70mm Throttle, 4.62 gearset, Wiseco .030", R&R Aluminum billet Rods, ARP everything, Toyo R888's.
#2 joey_crandall
joey_crandall
    undecided and confused starquester
  • 1,323 posts
  • Interests:starquests, rc cars, i like my job to, im a little bit boring hobby-wise though. i like beer.
Posted 04 November 2011 - 09:26 AM
pecifications
The gear box is a manual transmission ofr passenger vehicle, which is manufactured based on Japanese Mitsubishi technology. S
Matching  Engine:  4G63/4G64/4G69/4G94/4G94
Ratio:
:  4.330
:  2.356
:  1.509
:  1.000
:  0.834
Rev:  4.143
Central  Distance:  72
Torque:  196
The transmission has five forward speeds and one reverse speed. Synchronizers are adopted to all forward speeds. The speed shift is controlled directly.
i found this on the net through some shanghai parts dismantler
Edited by joey_crandall, 04 November 2011 - 09:27 AM.
<p>86 TSI + SHP</p>
<p> </p>
http://i1230.photobu...0c8ee17-1-1.jpg
#3 joey_crandall
joey_crandall
  • 1,323 posts
Posted 04 November 2011 - 09:43 AM
also looking around i found an article on austarion about mitusboshi vans having that transmission. but someone else said that you couldnt get 5 spd vans in the US. but it seems doable if you could find one.
<p>86 TSI + SHP</p>
<p> </p>
#4 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 04 November 2011 - 11:40 PM
The only reason I ask is, I've already grabbed the 4.22 gears from this Montero sport and was wondering if the construction/gearing was beefier than the Stock KM132-CNL that the SQ's come with.
#5 StarquestRescue
StarquestRescue
  • 3,355 posts
Posted 05 November 2011 - 07:13 AM
There were surly improvements made, but i can;t see the torque capacity being any better than the 88-89 sq trans. Plus it has truck gear ratios. :(
2012 fall set up 20g 06  in the stock turbine houseing. 2g mas, Neo afc, Versafueler, 1200 / 2000 injectors on E85.  379hp 395 tq TBI Power
379/395 TBI   Dyno link-----------TBI Power http://www.sqperform....php?topic=33.0-----------Rear Gear link----------2010 Dyno link-------Feedback link
#6 Bag-O-Chips
Bag-O-Chips
  • 1,250 posts
Posted 06 November 2011 - 12:13 AM
Thats what I was afraid of, darn shame though...  I was hoping it would be equiped for a higher torque load but now as i look further into it, it's still coupled to a 2.4 .  Oh well, I might as well grab the motor, ECU, and wire harness. It's already setup for MPI, and wouldn't be much work to build.
