r154 to g54b adapterplate?
#2
Posted 17 September 2011 - 10:42 AM
I have about 10 wideblock R 154's in service right now, and I have one on hand
they run $425.00 and include the slave cylinder, front plate. throw out bearing and throw out bearing coller, they are a direct bolt up that use the original pilot bearing with a Toyota Supra disc
#4
Posted 17 September 2011 - 01:56 PM
the slave cylinder was chosen for the drivers side to avoid the exhaust system, the difference is the bleeder valve has to face upward
#5
Posted 17 September 2011 - 02:01 PM
Side-Swipe, on 11 January 2012 - 12:49 AM, said:
#6
Posted 17 September 2011 - 03:13 PM
#9
Posted 17 September 2011 - 06:46 PM
vettekiller593, on 09 September 2011 - 10:20 AM, said:
lionbull, on 07 September 2011 - 02:26 PM, said:
#10
Posted 17 September 2011 - 06:57 PM
#11
Posted 18 September 2011 - 05:30 PM
#12
Posted 18 September 2011 - 06:38 PM
right now, the only option I know of is for powertrain industries in California
part # 1303-23
23spline 1.200 inner diameter 6.125length 1.575 outer (seal) diameter Toyota Car
power train industries
garden Grove, calif
1-800-798-4585
$107.89
the reason this yoke is a good option is because it uses a 1330 U-joint or equivilant to a 3/4 ton truck U joint
I would love to find a 1350 ( one ton) U-jiont to finish out this swap
#14
#15
Posted 19 January 2012 - 02:48 AM
#16
Posted 19 January 2012 - 08:25 AM
you still have to get the conquest manual starter, flywheel and pressure plate with a 7m-turbo r154 clutch, and you would also need the driveshaft stated above by bill.
this is what i was going to use but i picked up a stock 5speed for cheap so it saved me some money. unless you are putting down 350-400+ hp to the wheels you wont need the r154 this is a pretty expensive way to go. i already had the trans from when i was going to try the 2jz swap but money didnt last long enough so i pulled the plug on that and went with the g54b again and a stock 5 speed. the conversion is pretty easy from what i hear ive just finished ordering most of my parts to do the manual swap with. i just need a few other parts and ill be ready!
#17
Posted 26 January 2012 - 11:09 PM
I feel like my 5speed has too much vibration after about 80mph and I'm pushing about 350horses
Sorry to thread jack, but this mod looks like something I need soon. Also how does the r154 compare to a t56 swap?
Any info would be greatly appreciated.
Tae
blowzilla - blew.............
built custom mpi and the motor was crankwalking.....
http://s1199.photobu...1001_192245.mp4
2jz swap nearly done. ^
http://s1199.photobu...=1358206904.mp4 l
l
mighty max - cyl#2 20psi compression...awaiting fresh motor......from---------------l
and all mpi, turbo, aem transfered over to ---soon to be "Almighty MAX"
#18
Posted 27 January 2012 - 04:55 AM
Ratios:
- First Gear: 3.250:1
- Second Gear: 1.955:1
- Third Gear: 1.310:1
- Fourth Gear: 1.00:1
- Fifth Gear: 0.753:1
- First Gear: 3.369:1
- Second Gear: 2.035:1
- Third Gear: 1.360:1
- Fourth Gear: 1:1
- Fifth Gear: .856:1
Edited by Technology, 27 January 2012 - 04:55 AM.
#19
Posted 27 January 2012 - 06:35 AM
KM132
gear. top speed @ 6500rpm
1. 40.020 mph
2. 66.251 mph
3. 99.134 mph
4. 134.819 mph
5. 154.236 mph
R154
5. 168.123 mph
Edited by Technology, 27 January 2012 - 06:38 AM.
#20
Posted 27 January 2012 - 02:40 PM
anyone with the swap already done, do you guys recomend it? and what are the max hp/torque r154 can handle?
again, thanks for all the info
tae
l
