Problems with old Compaq Presario 700 laptop
5 replies to this topic
#1 Mnementh
Mnementh
  • 288 posts
Posted 20 May 2011 - 11:33 AM
Well, I got a -FREE- laptop and was hoping to be able to play MPEG4, MKV and AVI video files on it & port them out the video out jack to the input on my TV.  Problems? Yeah, I got a few...
1. Video only plays small, I can't enlarge it.  I'm using the VLC media player but even if I copy the file onto the HD the video is still jerky & stutters.  Video will completely stall if I try to play in full screen mode.
2. I can't figure out how to turn the video out on the laptop ON...I hooked it up to the TV but there's no signal.
#2's probably an easy fix but #1 worries me - is the computer so old and crappy that it can't play video or is it just kludged up with crap and running slowly or something else?  Near as I can tell, Presario 700s were sold between 2002-04 so I suppose that's how old it is...
Thanks for your help in advance.
Edited by Mnementh, 20 May 2011 - 11:34 AM.
Yea, though I walk through the valley of the shadow of Starquests, I will fear no Evo: for thou ralliart with me; thy g54b and thy turbo they comfort me.
#2 Fuze
Fuze
  • 1,152 posts
  • Interests:The battle magnet returns...
Posted 20 May 2011 - 12:28 PM
Assuming everything works....
Your Laptop needs to support the resolution the TV does, or the image will look low-res. Usually 1080x720 or something like that. I assume you're running Windows XP if your PC is form '02.
You need to send the video signal to the TV, with a laptop the TV is acting like a secondary monitor, so you must send the video there manually first, afer the initial setup it will automatically do what you want when the second monitor is attached.. Right click on the desktop and you will either see a selection called "output to", or just "properties" at the bottom. Using either menu will enable you to output to two monitors, and will let you pick which one will be the primary, set resolutions, etc. It's pretty elf-explanatory once you're in there.
Follow me on Instragram? #battlemagnet
#3 Mnementh
Mnementh
  • 288 posts
Posted 21 May 2011 - 07:41 AM
Sorry, yes, it's running XP and, according to the stickers on the case, it has an AMD Duron processor.   :P
#4 Killtodie
Killtodie
    KTD
  • -219,400 posts
Posted 24 July 2011 - 01:56 AM
You need to do a clean install of the OS, that will fix everything. Also, probably at least 1GB of memory.
My Repair Progress Post!
View PostBag-O-Chips, on 13 September 2011 - 09:36 PM, said:
Toadie... not all of us scrape bubble gum off pavement :)
#5 85.5flatbodystar
85.5flatbodystar
  • 264 posts
  • Interests:On the never ending Quest for More Boost!
Posted 01 August 2011 - 01:03 PM
I would also try a different media player, I've had issues on slower machines where VLC wont decode HD content. I find that core AVC with mpchc seems to work better.
#6 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 39,160 posts
Posted 03 August 2011 - 10:42 PM
for older Compaq's use HP , they bought out compaq years back,, you can still find some info and drivers for older compaq's but not all of them
88TSI Silver
89TSI red auto
