1987 Conquest TSI with no rust Custom MPFI MegaSquirt
39 replies to this topic
#1 kf4eok
kf4eok
  • 338 posts
Posted 28 April 2011 - 08:58 PM
I have tried to edit the title of the thread to reflect that the car has been sold but the full editor on this forum appears not to work. I have e-mailed an admin. about the problem.
Car has been SOLD
Price Reduced to $5000 for quick sale. My loss your gain.
Contact Daniel at (904) 234-3470 with any questions about this great car.
This car has been fully restored from the frame up, other than paint. The car has no rust or filler at all on the body. It has the original paint and is in great condition for being red and 24 years old. The plastic parts (mirrors, spoilers, bumpers and air dam) have been removed and repainted. The engine and tires has about 200 miles on them. The A/C works as it should and converted to R-134 with New Expansion valve. The car has 1988 suspension under it with the 6 bolt axels and the LSD is 1988 with all new seals.
I want to trade this car for a Honda Goldwing!!! Or maybe a Honda Insight.  I would take $7500 CASH as of today but this cash price is subject to change. I will look at any other barter options so let me know what you have. I am in no hurry unless you have what I want. I have even thought about raffling off the car, something like selling 150 tickets for $50 and the drawing ticket wins the car. There is also the option to part the car out, it would be easy to disassemble because every bolt and nut has been removed and reinstalled so no rusted or frozen fasteners to worry with.
Here is some links to some write up of some of the work that I have done to the car here on the forums
http://www.starquest...howtopic=105688
Posted Image Posted Image
Here is a list of some parts that I have installed on the car to date:
Engine:
MegaSquirt II PCB 3.0
Running Sequential Injection and CNP Setup with Wideband EGO and Boost Control
MapDaddy 4 Bar MAP Sensor with Barometric Correction
EBC Electronic Boost Control Solenoid
P&H low-z injector driver board
Knock Control
Driver Circuts for LS2 Coils
Toshiba Notebook NB305-N310 Witx XP Hope Edition Windows
TunerStudio Registered
1.66 GHz Intel Atom Processor
140 Gig HD
1 Gig Ram
WIFI
7 inch Touch Screen Monitor
New Crankshaft
New Wiesco Forged Pistons
New Oil Pump
New Adjustable Cam Gear
New Timing Kit
Recondition Rods
Garrett Turbo Rebuilt / Customized at Mikes Turbo
http://www.miketurboinc.com/index.html
compressor wheel Dia.
exducer is 76 mm
inducer is 57.7 mm
trim is 52
A/R is .50
turbine wheel Dia.
exducer is 64.3
inducer is 73.3
trim is 68
A/R is .63
New Steel Braided Oil Line
CRYO2 Intercooler. 24” Wide X 10” Tall X 3.5” Thick. With 3” inlet and outlets. With spray bar and Steel Braided line
Tube Exhaust Manifold SS
MK1 VR SENSOR BRACKET KIT
MOOKEEH MK1 CRANK PULLEY WITH EDIS TRIGGER WHEEL
ST Performance Fuel Pressure Regulator
ST Performance Fuel Filter
4 New Cooling Fans
A Large Oil Cooler with SS Braided Lines with AN Fittings
New 100 AMP Alternator
LS2 Yukon / Corvette Coils (4 of them)
Griffin custom made Radiator. It has two 1.5 inch flues which makes it 3 inches thick.
Custom made Multiport Intake Manifold with a 75 mm Throttle Body from a 32 valve Northstar engine, Powder Coated
Four Delphi FJ10455 75lb Injectors with new connectors
Custom made Cam Angle Sensor (CAS)
ARP Head Studs
ARP Rod Bolts
New SX Performance Fuel Filter
New SX Performance Fuel Pressure Regulator
Schneider 280F-14 U-FW Solid Follower Camshaft with new springs to match
Adjustable Cam Gear
New NON JET Valve Cylinder Head From Engine Machine Service (Dads)
New External 38mm Wastegate
New Blow Off Valve
2.5 Inch Exhaust - No Converters
Custom 3”  Hardpipes
Balance Shaft Eliminator
Powder Coated Valve Cover
New A/C receiver dryer and also a new expansion valve. I have replaced all the o-rings with new ones. New Walbro 255 LPH fuel pump
New Silicone Heater Hoses
New Power Steering Hose
Large Oil Cooler with Steel braided lines and AN fittings
EGT Sensor
Drivetrain/Suspension:
5 Speed Manual Transmission
6 Bolt Axels and LSD
New CV- Joints Boots
New Wheel Bearings and Seals on ALL 4 Wheels
New Front and Rear Struts
New Bellows and Bumpers
All New Eibach Progressive Springs
Suspension Technqiues Front and Rear Sway Bar
New Polyurethane Sway Bar Bushings
New Polyurethane Endlink Bushings
Master Polyurethane Bushing Kit Installed
MK1 STARION FRONT AND REAR ADJUSTABLE PILLOW BALL CAMBER PLATES
New Findaza Flywheel and puck Clutch and pilot bearing and release bearing
New Clutch Master Cylinder
New Clutch Slave Cylinder
New Brake Master Cylinder
Rebuilt all 4 Wheel Calipers
Slotted Front and Rear Rotors
Steel Braided Brake Lines
ABS Delete
New U-Joints
New Goodyear's Fuel Injection line from the gas tank to the engine
New Power steering High pressure hose
Interior:
Factory Radio
New rear Speakers
New stepper boost gage
New fuel pressure gage
New Innovative EGO Wideband Gauge and Sensor
Working Stock Radio
Trunk Mounted Battery
Rebuilt Wiper Motor and linkage and transmission
New A/C Expansion Valve for R-134
Exterior:
GT Factory Diablo Door Hinges (NEW not yet installed)
Polished Wheels
New Tires
Car Cover
Misc:
I might add a Kenwood DNX5120 Radio, GPS Navigation System, DVD Player with the KCA BT200 Bluetooth Unit for the right trade might.
I also have many spare parts that I might let go with the car like, 2 complete doors, rear hatch that has the factory turbo decal from a Starion, control arms, strut tubes, intakes, valve covers, camshafts, blocks, rods, oil pumps, steering gear box, crossmember, PS pumps, lifters new and used, valves, springs, rocker shafts, alt., all seat belt components, brake calipers, flywheels, bumpers and covers, fender, transmission, body electronics, relays, wiring harness, mirrors, door hinges, vacuume pumps, exhaust manifolds, stock turbo parts, tail lights, fog lights, door glass and the rear triangle glass, axels, LSD cover, mounts, rims, A/C compressors, A/C hoses, 2.0 dual cam head and intake, spoilers, head light motors, parking brake cables, heat shields, drive shaft, and much more. You get the idea I have allot of parts already pulled That I could let go with the car.
Please ask any questions that you might have.
Thanks for looking,
Daniel
904-234-3470
daniel@thestarquestclub.com
Edited by kf4eok, 20 June 2011 - 03:19 PM.
Daniel Lewis
My new forum. Visit My forum to see what great features it has.
Visit my forum My Forum thestarquestclub, be sure to register to win the free giveaways and contest.
My phone no. 904-234-3470
My PayPal is: daniel@thestarquestclub.com
#2 NotStock88
NotStock88
  • 4,526 posts
Posted 28 April 2011 - 11:38 PM
price?
NOOB
#3 kf4eok
kf4eok
  • 338 posts
Posted 29 April 2011 - 03:11 AM
The reason I want to trade the car is that I believe that I will get into trouble with this car if I keep it. It is just to much fun to drive and I can't seem to keep it within the speed limit.
The car has had a 4 wheel alignment.
All the lights and guages work with the exception of the tac in the dash. It works I just haven't had time to reconfigure it to work with the new igintion system and MegaSquirt.
I do have a set of GT Factory Diablo door hinges for the car, I just have gotten to putting them on. It a nice little project to do.
The car will be going back to the dyno soon and I will have the latest Dyno numbers when that happens.
What I haven't got working yet or haven't tested is the cruse control. The cruse controll worked before I rebuilt the car.
Here is some pictures
Thanks for looking,
Daniel
904-234-3470
Edited by kf4eok, 30 April 2011 - 03:14 AM.
Daniel Lewis
#4 kf4eok
kf4eok
  • 338 posts
Posted 29 April 2011 - 03:14 AM
View PostNotStock88, on 28 April 2011 - 11:38 PM, said:
price?
I want to trade it for a Honda Goldwing
Daniel Lewis
#5 kf4eok
kf4eok
  • 338 posts
Posted 30 April 2011 - 02:20 AM
For an example of what I would trade for. I found this Goldwing on craigs list for barter but the owner is looking to trade for an older car.
http://jacksonville....2342822735.html The owner no longer has this and the add has been removed
I would trade for this if it checked out to be ok.
Edited by kf4eok, 10 May 2011 - 10:59 AM.
Daniel Lewis
#6 kf4eok
kf4eok
  • 338 posts
Posted 30 April 2011 - 03:35 AM
Here is some more pictures. I am going to make some video of the car soon and will get that posted here. Let me know if you want a picture of something and I will get it for you.
here is the A/C vent temp.
Daniel Lewis
#7 AndyW
AndyW
    Badda Bing
  • 3,392 posts
  • Interests:Stuff, things & other items of different sorts
Posted 30 April 2011 - 07:35 AM
$7500 is a very good price for all that you have done.  Nice job, I'v had mine going on 13 years and am in the final statges of MPI but my body is far from rust free.  You southern guys dont know just hod good you have it in that respect  lol.  Bump for a nice turn key car, this is how they should be sold.  Good job
AndyW
#8 mrvwbug
mrvwbug
    SQC Veteran Member
  • 719 posts
  • Interests:Keep the turbo spooled! Flattys before Fattys! I don't need the extra weight.
Posted 30 April 2011 - 01:38 PM
Yes, agree very good price.  If I didn't half to put a new roof on my house I'd be all over this.
Lot's of GOODIES!
Cheers,
Slim Jim
#9 Jaysquest
Jaysquest
  • 34 posts
Posted 01 May 2011 - 09:16 PM
Real nice car one of the best I've seen. Good luck with the sale.
#10 kf4eok
kf4eok
  • 338 posts
Posted 02 May 2011 - 10:57 PM
Thanks everyone for the nice responses.
I have owned this car for the last 12 years and it has been in storage for about 9 years and in March 2009 I got it out of storage and have been spending allot of money time on the car.  I have some close up pictures of the body for everyone. Just remember that this is the original paint and body and it has no rust or body work or filler to this date. I know that it has a ding or two and some chips here and there but I think it looks great for being original. I do know that it would look super with a new professional complete teardown and repaint.
above is the driver side in front of thr rear tire
                             above is the drivers side behind the rear tire        above is in front of the passenger side rear tire
                                     above is behind the passenger rear tire        above is another pictuer of behind the passengre tire
                              above is the passenger side in front of the rear tire        above is behind the passenger rear tire
Daniel Lewis
#11 kf4eok
kf4eok
  • 338 posts
Posted 02 May 2011 - 11:00 PM
Here is more pictures.
Daniel Lewis
#12 kf4eok
kf4eok
  • 338 posts
Posted 02 May 2011 - 11:04 PM
I almost frogot here is a youtube video I made showing a walkaround of the car.
car walk around
More to come soon.
Thanks everyone for your interest.
Edited by kf4eok, 03 May 2011 - 08:20 PM.
Daniel Lewis
#13 Frenchi934
Frenchi934
  • 2,798 posts
Posted 03 May 2011 - 06:51 PM
What OEM manifold did you use to make that MPFI? Very nice car GLWS
My car on Racefriv.com
#14 kf4eok
kf4eok
  • 338 posts
Posted 03 May 2011 - 07:43 PM
Here is a video link of the car with the engine running I hope everyone enjoys it. My camera picked up allot of high pitch wind like noise which is not heard in person.
Car running video
If anyone wants any pictures or video of anything just let me know and I will see about getting them poster for you.
Thanks for watching the video and looking at my car.
This will make someone an fun ride.
Edited by kf4eok, 03 May 2011 - 08:19 PM.
Daniel Lewis
#15 kf4eok
kf4eok
  • 338 posts
Posted 03 May 2011 - 08:12 PM
Hi Frenchi, thanks for looking at my car. If I remember correctly I started with a Ford Probe intake. I cannot say what year it was but I think that it was a 2.2 Liter engine. The runner spacing was close to the GB54 engine and I liked the long runner it has. I cut off the old intake flange and tig on a new flange that fit the GB54 engine and port matched everything. I had to use a thermostat housing off a stock GB54 intake and tig it to the flange and clocked it so that the radiator hose would clear everything. I had to tig new injector bosses in the intake runners and made a fuel rail to match them. The old injector bosses were an odd size and wanted to use standard size injectors. I had the intake milled to make sure everything was straight. I had to reconfigure the inlet to the intake to get the throttle body where I wanted it and pointing in the right direction. I wanted a good size throttle body with a TPS and IAC. I searched high and low until I found what I wanted. I ended up using a throttle body off of a Cadillac 32 valve North Star engine. It is a 75 MM throttle body with a TPS and a GM IAC valve. I wanted the GM IAC valve because it works well with the MegaSquirt setup to control the idle of the engine. I also welded a neck to the throttle and a flange to mount a blow off valve close to the throttle body. Doing this eliminates more connections and prevented possible leaks. I then powder coated the complete intake on the outside. By the time I was finished I could have just built the intake from scratch.
Edited by kf4eok, 03 May 2011 - 08:22 PM.
Daniel Lewis
#16 kf4eok
kf4eok
  • 338 posts
Posted 10 May 2011 - 11:15 AM
The car may be sold pending personal inspection. I have been talking with a man in New York that is going to come down at the end of May to buy the car after he inspects and tests drive the car. He offered to put a down payment to hold the car but I did not accept it. I would rather receive the money at the time of the sale.
On another note I will be going to the dyno soon and will have the results posted here for everyone to see.
Daniel Lewis
#17 Blue
Blue
    THAT Young'n
  • 2,427 posts
  • Interests:StarQuests. Guitars. Metallica.
Posted 10 May 2011 - 12:03 PM
You type in large font, sir. :lol:
Very nice car, worth the money, guys!
Disclaimer: I know enough to know I don't know nearly enough!
1993 Honda Civic EX Coupe - "Superdaily" CAI, Tanabe exhaust, Skunk2 coilovers, rear strut brace, Drag DR-19s
1984 Dodge Conquest Technica - Going on 1 year since the build started. Mod list is too long to type. :lol:
Quote
12:24 AM [Technology] yeah, eventually, and I wish I was reading this for the hair joke.
Happiness is a click away My Photobucket
My Feedback Thread
#18 kf4eok
kf4eok
  • 338 posts
Posted 11 May 2011 - 01:45 AM
View Post87Blue, on 10 May 2011 - 12:03 PM, said:
You type in large font, sir. Posted Image
Hi 87Blue Thanks for the nice commient. The larger font makes it easier for me to read. Thanks for taking the time to look at my car.
Daniel Lewis
#19 Blue
Blue
    THAT Young'n
  • 2,427 posts
Posted 11 May 2011 - 09:51 AM
Lol. I understand sir. I was just making an observation. :)
I hope to see this car go to a good home and not get parted out. GLWS! ^_^
Quote
My Feedback Thread
#20 PR ROSADO
PR ROSADO
  • 5 posts
Posted 12 May 2011 - 02:19 AM
Nice i wish i have the cash
