Ok...Another...well its a 1JZ....
#42
Posted 03 March 2011 - 09:50 PM
vettekiller593, on 03 March 2011 - 04:02 PM, said:
hmmmmm.
mpi stuff
life is like a roll of toilet paper. the closer you get to the end-the faster it goes.
#44
Posted 03 March 2011 - 11:39 PM
88 starion. 91k auto to 5sp,hardpipes.2.5 turbo back,threadstone manifold,t3/t4 57 trim at 20psi,
38mm wastegate with dumptube,plx wideband,greddy rz bov,6000k hids, 8" and 9'shp 25mm in the rear.
maft 3gm.
#45
Posted 05 March 2011 - 02:57 PM
Did you get the tranny off yet? Its very simple really- remember its a pull config and not a push set-up. Bolt the thing back up to the block and reach in the the drivers side opening/dust cover and remove the fork by hand. Push the fork forward towards motor and to the passengers side it will come right out and than the tranny will come right off.
Hope this helps if you are still having issues -
#46
Posted 05 March 2011 - 03:02 PM
I will try that. thanks for the advice. Do you have any pics of your setup? My e-mail is brturner@cox.net if you have any. The other thing...
What did you do for the alternator? Its a 3 wire and I'm not 100% on it. Thanks for the help again.
Braden
#47
Posted 06 March 2011 - 08:40 AM
#48
Posted 06 March 2011 - 05:23 PM
I got the tranny off...It was the stupid clutch fork like Sup said...I'm just f'n retarded....
I'm glad I did...this clutch...is....gone...it may have held at stock boost for a while but geez...it doesn't look good. Does anyone know if the 1jz and 2jz had the same flywheel and clutch setup? I know the r154 will work with both but I don't know if its the same clutch....Thanks for the info guys.
Braden
From everything I gather on other forums..I just need a clutch kit for the 7mgte motor...Sound right?
Edited by BOHO, 06 March 2011 - 05:44 PM.
#49
Posted 06 March 2011 - 05:56 PM
I have been working on mine way to long and still needs a few fabs like power steering lines and the interior put back together. I didnt have to relocate the oli filter has I had plently of roon over the motor mount. I also need to work out the oil pressure. BOHO if you havent realized the 1jz has no sensor for the oil pressure but most use 7m sensor and tap into the oil housing.
#50
Somehow...I ended up with an extra bearing after taking the tail section off of the trans and doing the shifter swap. I checked all 4 of the allen head bolts where the springs and ball detents are..They are all there..Any idea where an extra one came from...lol...s***
#51
Posted 06 March 2011 - 07:05 PM
#53
Posted 06 March 2011 - 08:41 PM
#54
Posted 06 March 2011 - 09:44 PM
#55
Posted 07 March 2011 - 06:08 PM
I was cutting and beating on the trans tunel and my drivers side jack stand shifted and fell...I was under the car. I was able to call a friend to come by and raise the car back up...my side is bruised to hell and back but I think I'm ok...Thas was the longest 30 minutes of my life...
After researching clutches..I decided to try this one first...because i just can't afford a new one right now...I lined it up...No I can't get the trans on the last inch...I must be off a hair or something....I also cut the radiator support because I didcked it up also...I'm going to drink a beer or 6 and try again tomorrow...I'm beat...
#56
Posted 08 March 2011 - 01:27 AM
E85, GT4088R, Dual Synapse 50mm wastegates, Apexi AVC-R, Griffin Radiator, 2G Eclipse Flexalite fans, AEM 30-1300, HKS 301 cam, LSP built Marnel head, Del West 1mm oversized Titanium valves, Del West Titanium Valve lock/retainers, LSP Valve Springs, 1600cc injectors, SX AFPR, Fuelab Prodigy 140gph pump, Fuelab Filter, Bag-O-Chips Twin scroll header, Chad's MPI Manifold, 70mm Throttle, 4.62 gearset, Wiseco .030", R&R Aluminum billet Rods, ARP everything, Toyo R888's.
#57
Posted 08 March 2011 - 01:32 AM
Disclaimer: I know enough to know I don't know nearly enough!
1984 Dodge Conquest Technica - Getting closer!
New motor purchased 04/24/13
Quote
#58
Posted 08 March 2011 - 01:34 AM
Quote
#59
Posted 08 March 2011 - 11:27 PM
I had my son helping me lower the motor and he let it down to fast, it bent the radiator support really bad. I just recently fixed it. Im glad to hear your ok, dont let this thing beat ya up just take your time.
