rack and pinion conversion
94 replies to this topic
#21 Convette
Convette
    I used to driftjunk
  • 4,185 posts
  • Interests:Going faster
Posted 02 April 2011 - 02:51 PM
I'm going to be test fitting rx7 (fd) parts up front soon.  Lighter, front street system, with tons of suspension and brake options. Either that or build my own control arms, and stay with the mustang stuff.  There are tons of options.  Make moves.
#22 leetaztsi
leetaztsi
  • 99 posts
Posted 05 April 2011 - 05:10 PM
I'm really interested in this, i would most likely buy it if someone put a package together... I can do the welding/fab work, but don't have time to go junkyard hunting
Fomerly Low Wht N Boosted...
87' Conquest TSI
05' Subaru Impreza RS (Daily)
81' Yamaha XS650
71' Triumph Tiger 650
Skateboard
Snowboard
#23 mstieg
mstieg
  • 5,371 posts
Posted 06 April 2011 - 12:50 AM
Doesn't/didn't ProfessorQuest have a kit out there somewhere?  I recall it being somewhat pricey ~$400
An alternative is to drop the power steering and go with a D-50 manual steering setup on the cheap.
Before: 352hp @15psi MPI: SDS, Chad's intake & equal length header, S256 Bullseye turbo, 48" 2.5 IC piping, MSD  MY PICS
In Progress: engine rebuild w/ Magna roller, reworked & ported AMC head, T56 swap, 4.22 rear, gas tank renewal, all gauges, steering lines & coupler fix also in works.
Future: ________
FOR SALE:  spare distributor, NIB pair of beefy U-joints, etc.  http://www.starquest...howtopic=133262 also Autometer gauge panel: http://www.starquest...pic=136703&st=0
#24 Casey_L
Casey_L
  • 3,151 posts
  • Interests:Keep dirt away from the impeller!
Posted 18 April 2011 - 11:00 PM
I was working on a rack and pinion setup about a year ago but I stopped because school and work got too busy. This setup would utilize a 240 rack and use new control arms but the same starion ball joint.
I decided the tubular setup would be way to expensive so I stopped working on it.
My Feedback
87 Mitsubishi Starion - Project Car
MS2-Extra 3.03y Firmware GM LS1 Coils, Wasted Spark
14.366 @ 100.10 Mph  - 12A, 17psi @ New England Dragway
#25 Jsmitty
Jsmitty
  • 497 posts
Posted 18 April 2011 - 11:45 PM
Dipping into dead threads, I always thought Silo from Austarion idea was good.
http://forums.austar...ght=rack pinion
http://www.projectze...topic.php?t=776
#26 Dave-O
Dave-O
    Mediocre At Best.
  • 2,854 posts
Posted 27 April 2011 - 05:38 AM
Hey guys! Sorry I haven't been around, been too-busy with work and building the Rx7 drift car.
I plan on mimicking silo's design to an extent, though I'm going to attempt using the stock SQ crossmember with S13 rack mounts welded on. From there, the steering shaft will be shortened OEM Nissan from the rack to the rag joint, and will continue as unmodified OEM Mitsu into the firewall. With the stock crossmember, LCAs will remain OEM as well. I'll be working on an option to use S-chassis LCAs should someone want to go that route.
I do also have a complete SN95 Mustang setup I can modify into the front of an SQ and build a kit from, if anyone is interested in going that route as well.
As far as a time-frame, unfortunately I don't have one. Pretty much whenever I get to it at this point - I do plan on being at the SQ Vegas Nats, so hopefully I'll have a demo or a few mock-ups on display for everyone to oogle.
--Dave
View Postdmyers151, on 08 June 2010 - 07:29 AM, said:
I see you got that Limited Edition ish.
#27 Frenchi934
Frenchi934
  • 2,747 posts
Posted 27 April 2011 - 03:01 PM
professor quest sold an extended steering colomn and a manual gearbox for 400 bucks. not a rack system
My car on Racefriv.com
#28 BOOSTED88tsi
BOOSTED88tsi
    Oh herro!
  • 4,928 posts
  • Interests:Turboed 2.6's and muscle cars
Posted 27 April 2011 - 03:02 PM
I second what dave is saying. I bought my rack last weekend and it will be going to a stock sq crossmember and collum. Will be working on it asap!
2003 600rr ,1987 conquest, and a soon to be 03 cobra powered 1968 mustang coupe.
#29 Dave-O
Dave-O
    Mediocre At Best.
  • 2,854 posts
Posted 07 May 2011 - 01:55 AM
Epic! Definitely post up your findings!
I'm most likely buying another Starion when I get back from New Mexico next week, so I'll be focusing a lot of time and money into the SQ projects in the near future.
#30 badtoad
badtoad
  • 391 posts
  • Interests:Anything fast
Posted 07 May 2011 - 09:04 AM
What the heck are you doing in my neck of the woods,nothing but sand down here.
260 HP....299 TQ...      Ported Marnal head , Ross pistions , Carrillo H beam rods, 52 mm throttle body , Ported intake , Gm maf 1.3 translater, 3" exhaust, 20 G turbo, 2.5 ic piping, Fidenza flywheel, ACT clutch , Trilogys ,  Gm alt conversion, SHP rims, Wire tuck, Fuse Delete, ect ect ect
#31 fuel
fuel
  • Pip
  • 46 posts
Posted 15 June 2011 - 08:28 PM
bumping this up, am keen to know how people are getting on with their rack and pinion swaps - am seriously wanting to do this to my car also with S13 parts. I too wanted to retain the stock crossmember, unless the S13/240 crossmember is much narrower on the front side, the engine I eventually want to fit has a larger bowl in the (front) sump.
#32 Dave-O
Dave-O
    Mediocre At Best.
  • 2,854 posts
Posted 21 June 2011 - 11:06 PM
I'm managing a warehouse in Albuquerque that deals with smoke shop supplies. Been here long enough to consider myself New Mexican haha.
So after a trade deal fell through on my Starion and Conquest, and my roommate in Utah wanting to buy back my daily '86 Rx7, I'll be bringing my Conquest to daily status and working on it and the Starion quite a bit more. I'm going in on a shop in SLC with a friend so there will be tools for me to finally use to fab up a rack setup. For my Conquest (since its the missile/test-bed) I'll be using a complete S13 front suspension, brakes and steering, with S13 coilovers all around. I do still intend to build a kit to swap in an S13 rack and keep the rest of the suspension OEM SQ. I hope to have something of progress to show for the Mesquite '11 meet.
#33 old-colt
old-colt
  • Pip
  • 14 posts
  • Interests:Custom fabrication
Posted 07 July 2011 - 01:35 PM
Hi Guys,
I have not been around here but I have an EVO 8 rack installed under one of my Starions. These pictures were taken 5 years ago.
In this last picture you will notice the caliper mounts are a bit different on my car as well. I have been running Wilwood Superlite calipers over 12 7/8 rotors front and 12 3/16 rotors on the rear. This suspension and brakes have been run going on 15 years now. I eliminated the brake booster as well way back then but now have a triple master setup in the car.
Edited by old-colt, 07 July 2011 - 01:37 PM.
Charlie North
If it ain't broke, Modify it
7 widebodies
4 RWD Colts
3 Galant VR4
an AWD 93 Mirage
To many others, just ask my wife.
#34 TsTKl
TsTKl
  • 341 posts
Posted 09 July 2011 - 01:46 AM
Haven't done mine yet but plan to. Heres some info I've dug up.
The virtual length of the lower control arm is roughly 15.5 inches. The middle section of a steering rack that has 15.5 inch would be just barely over 20 inches. The closest I found at the junk yard was out of a suzuki swift. It was 21.5 inches if I recall correctly. This would have the least amount of bump steer of any set up I could find.
it would appear that very very few production cars have LCA's as long as ours, possibly why our cars handle so well. If you make the two perfectly parallel at whatever your ride height is you'll probably never notice any significant bump steer, however I wanted it perfect.
Still looking but haven't decided what I'll end up doing, HOWEVER:
any front steer rack that you want to use on your car, just get a right hand drive version of that unit and mount it backwards. It is now a rear steer unit.
what I'm currently playing around with: honda s2000 steering rack. At roughly 31 inches it will have a lot of bump steer at the extremes of suspension travel, however my car is a road race car anyways, so it shouldn't be too big of an issue. I'd like to see if I can chop and weld it up so that it will be closer to 20 inches. The biggest driving point to the s2000's steering rack: its electric. Also it has a 13.9:1 ratio.
you might have to read through this twice cuz I think I wrote it kinda quickly and poorly.
#35 25gconquest
25gconquest
  • 198 posts
Posted 18 August 2011 - 04:39 PM
If any one can come up with a bolt in system using as much SQ parts I am in because I have front brake upgrade and a D2 coil over system going on the car , it wil be expensive to redo all of this . love all the idea. Casey if you had to make your system up Pm me on estimate cost.
#36 KT
KT
  • 159 posts
Posted 16 September 2011 - 08:48 PM
A DSM steering unit is rear mount.  I haven't seen that mentioned yet as an option.  Has anyone looked into it?  Trying to keep this one near the top.  I definitely want to rid my car of power steering and the weight associated w/ it.
KT
#37 Scotty Dont
Scotty Dont
    starion drift pro
  • 5,661 posts
Posted 16 September 2011 - 11:35 PM
I just finished up the 240 rack in my car with modes knuckles and I have 2.750 turns lock to lock and the turning radius is unbelievable!
#38 Technology
Technology
    Addicted Starquester
  • 10,993 posts
  • Interests:Lots of boost!
Posted 17 September 2011 - 10:35 AM
Can you post some pics please?
#39 Scotty Dont
Scotty Dont
    starion drift pro
  • 5,661 posts
Posted 17 September 2011 - 10:44 AM
i know things move quickly in china but give me some time,  I may make a little write up.  Posted Image
#40 D_Venable
D_Venable
  • 6,521 posts
  • Interests:Drawing Starions and Conquests
Posted 17 September 2011 - 12:10 PM
a write up would be awesome
2011 Silverado
88 TSI parts car
