importwarrior Posted November 18, 2010 Report Share Posted November 18, 2010 (edited) I have been sitting on this for about 6 months or so.i got the dizzy idea from ChrisVipers post. here are a few pics. 1996 Mighty max dizzy http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Dizzy-Spacer.jpg http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Spacer.jpg in this picture you can see the difference between the mighty max and the stock starquest hole.this is the hole the post goes through to tighten it in place. the quest i farther out from center. http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Spacer-7.jpg the spacer i made can allow me to basically put the dizzy in any 360 degree position i want. http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Spacer-3.jpg http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Cam-Crank-Dizzy.jpg Edited February 9, 2011 by importwarrior Link to comment Share on other sites More sharing options...
jahjah Posted November 19, 2010 Report Share Posted November 19, 2010 brilliant. Link to comment Share on other sites More sharing options...
importwarrior Posted November 20, 2010 Author Report Share Posted November 20, 2010 (edited) Thanks, but i cannot take credit for this it goes to ChrisViper. here are a two more pics. i think this is 1000 timeseasier than an EDIS setup.all though i have yet to install it. spacer dfference. not a great pic but yo get the idea. http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Dizzy-Spacer.jpg http://i139.photobucket.com/albums/q299/I-W/Mega%20Squirt/Dizzy-Spacer-1.jpg Edited November 20, 2010 by importwarrior Link to comment Share on other sites More sharing options...
Technology Posted November 20, 2010 Report Share Posted November 20, 2010 You can't just drop it in like that though, you need the ecu to advance and retard timing. Or was that assumed and I'm dumb? (Don't answer the last part.) So if this works, you are awesome, btw. Make it so. Link to comment Share on other sites More sharing options...
scott87star Posted November 20, 2010 Report Share Posted November 20, 2010 Yeah, I messed with welding together a DSM CAS and dizzy base and even though it seemed to work it was a pain, here is my 4-1 dizzy installed: http://picturehosting.com/images/oblique9881/e89001.jpg The CAS lid fits pretty well once you cut the dizzy cap tabs off, a couple of gaps are left that can be RTV'ed to make a pretty nice seal. Mine is going to run these: http://picturehosting.com/images/oblique9881/e89002.jpg I should know next week how well it works. I'm considering getting that bracket water jet cut and selling them if there is interest. Those are 2-wire COPS from a 4G63 I believe. I like your spacer, I made a multi-plate one and don't like it a bit so I got some 0.25" aluminum to do something like yours. Scott Link to comment Share on other sites More sharing options...
importwarrior Posted November 20, 2010 Author Report Share Posted November 20, 2010 (edited) thanks scott i would be interested in how you setup the megasquirt to run the COP's. I thought the dsm spins in the wrong directionthats why we could not use it in our stock dizzy location. my spacer allows me to clamp down the dizzy in any position i want to help me get the timing between the megsquirt and engine to the proper timing. Edited November 20, 2010 by importwarrior Link to comment Share on other sites More sharing options...
Skullzaflare Posted November 21, 2010 Report Share Posted November 21, 2010 thanks scott i would be interested in how you setup the megasquirt to run the COP's. I thought the dsm spins in the wrong directionthats why we could not use it in our stock dizzy location. my spacer allows me to clamp down the dizzy in any position i want to help me get the timing between the megsquirt and engine to the proper timing.how would you go about creating the effects of vacuum advance? Link to comment Share on other sites More sharing options...
importwarrior Posted November 21, 2010 Author Report Share Posted November 21, 2010 This whole setup is based on a MegaSquirt install.the map sensor along with the spark map can alow you to program your own timing map in a 12 X 12 map of 144 cells. the MegaSquirt i have has a built in 4 bar map sensor with a barometer corection sensor. you set timing and retard in the 12 x 12 spark map. sample spark map, not mine. http://img203.imageshack.us/img203/4500/timingmap122709.jpg Link to comment Share on other sites More sharing options...
pure_insanity Posted November 21, 2010 Report Share Posted November 21, 2010 how do you go about deciphering the wiring in the mm dizzy cas ? which wire goes where? Link to comment Share on other sites More sharing options...
pure_insanity Posted November 21, 2010 Report Share Posted November 21, 2010 and once you had the mm dizzy in place, you could just simply use the dist cap and be done right? kind of a simple mpi setup. Link to comment Share on other sites More sharing options...
importwarrior Posted November 21, 2010 Author Report Share Posted November 21, 2010 yes that is correct. you can use the cap and rotor.the wires are easy, one 12 volt, one ground, onecam sensor one crank sensor. Just so you all know there are different color wiresfor different dizzy's. mine has a red and blackwhite and yellow between the dizzy and connectorBUT after the connector they change to different colorsyellow, black, green, Black~white. so red is + black is- white or yellow is cam or cranki just need the megasquirt to tell the differencebetween the yellow or white wires. basically it will fire one way and it will not the other. if it doesn'treverse those 2 wires. thats it. Link to comment Share on other sites More sharing options...
importwarrior Posted November 21, 2010 Author Report Share Posted November 21, 2010 and once you had the mm dizzy in place, you could just simply use the dist cap and be done right? kind of a simple mpi setup. if you set up direct drive coils for megasquirt you can use a eclipse coil pack or edis coil packto spark your plugs. triggered by the MM dizzy. not a crank wheel and VR sensor. Link to comment Share on other sites More sharing options...
psu_Crash Posted November 22, 2010 Report Share Posted November 22, 2010 I have a dizzy and BIP373 on the way. I'll make up the bracket as soon as I have the dizzy in hand. May even have try to install this coming weekend. I'll let you know how it goes. Link to comment Share on other sites More sharing options...
importwarrior Posted November 22, 2010 Author Report Share Posted November 22, 2010 very cool, i have a diyautotune megasquirt. i allready had 1 driver installed.when i converted it to 2 drivers i had to remove the vb-921 driver and replaceit with the BP-373 then add one more BP-373. Very easy to do.I just got the new head on my car and need to sort out a oil leak. once thatsdone then i will be trying to get this megasquirt installed as well. Link to comment Share on other sites More sharing options...
importwarrior Posted November 23, 2010 Author Report Share Posted November 23, 2010 (edited) some info for a megasquirt setup: BIP373 ignition output mods single coil driver can work just use spark output A onlyand stock starquest coil. for dual coils use link above. input mods and ignition mods for megasquirt cannot mix n match drivers msextra MS setup Qustions Edited November 23, 2010 by importwarrior Link to comment Share on other sites More sharing options...
scott87star Posted November 23, 2010 Report Share Posted November 23, 2010 Here's my control module for the COPs, I've mounted them in the megasquirt case before but that gets messy and I like the idea of the actual coil power wires being as short as possible (less susceptible to noise). The 5 volt logic lines are in that wire exiting out the left side, they go through the firewall and to the ECU case. The 18 gauge white wires run to the coil negatives of course, and a common ground out. I've used that board several times now, it fits in a spare slot in the megasquirt case if you want it there, its from Glen's Garage. You can also get one from JBPerf but I like Glen's better. http://picturehosting.com/images/oblique9881/4channelcoilcontrol.jpg Scott Link to comment Share on other sites More sharing options...
importwarrior Posted April 18, 2011 Author Report Share Posted April 18, 2011 Mighty Max Dizzy Link Actually the Dizzy can be found in many different cars. 1996 Mighty Max Dizzy is the one i used. Rockauto link Year Make Model Engine 1990-1989 Dodge 2000 GTX (Canada) All Application Data: 1990-1989 Dodge Colt All Application Data: Exc. 1.6 Liters 1991-1989 Dodge Colt Vista All Application Data: 1988-1988 Dodge Colt Vista All Application Data: w/2 screw holes for harness bracket 1987-1987 Dodge Colt Vista All Application Data: w/o Vacuum and w/2 screw holes for harness bracket; From 11/2/86 1993-1992 Dodge Trucks Ram 50 All Application Data: 1991-1990 Dodge Trucks Ram 50 All Application Data: 2.4 Liters 1990-1989 Eagle Summit All Application Data: 1.5 Liters 1994-1990 Hyundai Excel All Application Data: w/FI 1992-1991 Hyundai Scoupe All Application Data: 1991-1990 Hyundai Sonata All Application Data: 2.4 Liters 1989-1989 Hyundai Sonata All Application Data: 1990-1989 Mitsubishi Galant All Application Data: SOHC 1987-1987 Mitsubishi Galant All Application Data: w/2 screw holes for harness bracket 1990-1990 Mitsubishi Mirage All Application Data: 1989-1989 Mitsubishi Mirage All Application Data: 1.5 Liters 1994-1990 Mitsubishi Precis All Application Data: 1996-1995 Mitsubishi Trucks Mighty Max All Application Data: 1994-1991 Mitsubishi Trucks Mighty Max All Application Data: 2.4 Liters 1990-1990 Mitsubishi Trucks Mighty Max All Application Data: 2.4 Liters and w/2 screw holes for harness bracket 1990-1987 Mitsubishi Trucks Van All Application Data: w/2 screw holes for harness bracket 1990-1989 Plymouth Colt All Application Data: Exc. 1.6 Liters 1991-1989 Plymouth Colt Vista All Application Data: 1988-1988 Plymouth Colt Vista All Application Data: w/2 screw holes for harness bracket 1987-1987 Plymouth Colt Vista All Application Data: w/o Vacuum and w/2 screw holes for harness bracket; From 11/2/86 Link to comment Share on other sites More sharing options...
psu_Crash Posted April 18, 2011 Report Share Posted April 18, 2011 I really need to post up some pics of my install. Now with a high res 24/1 wheel Link to comment Share on other sites More sharing options...
scott87star Posted April 19, 2011 Report Share Posted April 19, 2011 Where did you pick up the wheel? I had a guy wanting $100 for one so I passed. Scott Link to comment Share on other sites More sharing options...
grsmnky81 Posted June 20, 2011 Report Share Posted June 20, 2011 where do we get one of these spacers i see that you have on yours? Link to comment Share on other sites More sharing options...
psu_Crash Posted June 21, 2011 Report Share Posted June 21, 2011 where do we get one of these spacers i see that you have on yours? You have to make the spacer Link to comment Share on other sites More sharing options...
