Pagemo's 89 Yellow TSi
pagemo
Since the car is basically complete i thought it time to add to the show room.
The car was a 2 year resoration i picked up as a roller but in fair condition. I decided to paint the engine bay and just make a driver out of it but that snowballed into a what you see below. :wacko:
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00180-20100516-1834.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00155-20100430-2017.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00156-20100430-2017.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00197-20100516-1838.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00194-20100516-1837.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/IMG00196-20100516-1838.jpg
While posting these i just relized i have no recent engine bay pictures so i guess ill add them later.
VERY nice. Loving the seats and steering wheel, do you recall the model?
Thanks guys!
The steering wheel is a MOMO competition and the seats are just re covered stock seats.
Best pics Ive seen with a spoiler delete on a widey. I like it alot. Going to PF10? I love to see it in person.
I'll be dragging Scott along for PF if it kills him...LOL. His pics are bad too.....whole different animal in person. We actually did some interstate pulls over the weekend (him vs. my turbo HHR) and it looks freakin' sweet charging down the tarmac too.
Better pics:)
http://www.26liter.us/gallery/albums/userpics/10197/DSCN1323.JPG
http://www.26liter.us/gallery/albums/userpics/10197/DSCN1322.JPG
http://www.26liter.us/gallery/albums/userpics/10197/DSCN1327.JPG
http://www.26liter.us/gallery/albums/userpics/10197/DSCN1331.JPG
http://www.26liter.us/gallery/albums/userpics/10197/DSCN1335.JPG
It's a Bullseye T04B P-trim made for a 4G63 but modded to fit a South FLorida header. Spools like a 12a......with serious guts. I don't have a copy of his dyno, but when he let off at 6200 the hp curve was still rising linearly....but he runs a very aggressive custom spec'd Schneider cam. Edited by jonboyb
Scott and I talked about that today. His highest dyno was never printed and we THINK it was 378 RWHP at 18 psi on pump. He had inadvertantly mis-torqued the head studs (ARP's with 30w oil but only moly torque specs) and the head lifted allowing the Titan HG to stretch and blow. The last dyno we did went down and I think it was posted on here as 350. Since then he added custom Ross 8.2:1 pistons and had alot of head porting/oringing done when I had the machine shop still. 21 psi is the daily level now....and the car is notably stronger. I think I talked him into some race fuel and 30 psi tonight so hopefully we'll spin it up again in a few weeks. With the Crower rods and Ross pistons.....should be a walk in the park for the block.
Since he hardly ever visits here.....the mods are as follows:
Bored .040 over
Balance shafts eliminated
Balanced assembly
Ross forged pistons (flat top with
Crower forged rods
ARP head and main studs
Cleveite 77 main and rod bearings
New oil pump
M-6 magna head with steel orings
Schneider custom cam 294,282
HD springs
SS +1mm intake valves
Ported and polished
Magna intake
70mm ford throttle body
4, 75lb RCI injectors
Bullseye TO4B vtrim ptrim turbo
SFP tubular header
3” exhaust and SS Magnaflow muffler
4” bar and plate intercooler 3” in and out
RFL blow off valve
Walbro 255lh/hr fuel pump
Performance products fuel pressure regulator and Aeromotive gauge
Mega squirt II vs3 2.35 code
EDIS4 ignition
Innovate LC-1 wide band O2 sensor
Stock radiator w new 3 row core
Short shifter by Mookie
SS braided clutch line and rebuilt slave cylinder
ABS bypass line
Center force clutch and 6 puck sprung disk
Fidanza flywheel
ARP flywheel bolts
The rest of the cars mods are:
Suspension
Poly bushings
New tie rods and ball joints
New wheel bearings and seals
Custom coil over struts, Cosmo sleeve over’s on machined factory struts for lower perches
KYB struts and inserts
MK1 front camber plates
Custom rear camber plates(top mount for extended travel)
SS braided brake lines
Completely rebuilt front/rear calipers
Misc
99% of all bolts were re zinc plated and yellow chromate
New battery
Rebuilt alternator
Rebuilt starter
7’ and 8’ factory wheels with polished lips
New torque tube shaft/bearings and coupling
Body
Fresh factory Yellow Y-59 paint(few minor bad spots from buffing and several small nicks)
painted under hood and jambs
Stripped to bare metal, one fender replaced and one rear quarter grafted in.
Epoxy primer
Valspar polyurethane base
House of kolor clear coat
83 turbo hood
Shaved rear wing
Interior
Fresh reupholstered front seats black with black micro suede inserts
Suede inserts in door panels
New black plush carpet
Re-dyed dash and console satin black
3 gauge Pillar pod with Autometer, fuel, water and oil pressure
Autometer 30# boost/ vacuum gauge in stock location
Momo competition steering wheel
Momo shift knob
Momo shift boot
Momo pedals
Recovered gauge cluster
Edited by jonboyb
  • 6 months later...
Some recent pictures
I removed the helper springs from the coil overs and dropped the front a little more.
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/2010-09-25_13-09-17_366.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/2010-09-25_13-10-29_320.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/2010-09-24_19-00-44_679.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/2010-09-25_13-09-54_867.jpg
http://i244.photobucket.com/albums/gg1/pagemo/yellow%20quest/DSCN1323-1.jpg
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
