Fixing the Foot/Face HVAC Actuator
foot/face PITA
12 replies to this topic
#1 scott87star
scott87star
  • 4,939 posts
Posted 12 August 2016 - 12:57 PM
To those interested I've managed to fix my foot/face HVAC actuator with the help of Mike C's writeup.  The one on my flatty has never worked, I had it out a year or so ago in an effort to fix it with some RTV but of course that only worked until the first time it extended and it broke/ripped in the next pleat up on the bellows.  You can't RTV the entire thing as then it would be too rigid.  Mike suggested something flexible could be fit over the bellows, I jumped on McMaster-Carr (http://www.mcmaster....2/3864/=13p16un) and found this:
P/N 5298K78.  It's much larger in diameter than the original and much longer too but I splurged for it hoping to make it work.
So that's what I got.  The rod end is close in size to the rod but not perfect, the flange end is way too big and I couldn't think of a way to seal it.  On my actuator the smaller diameter of every pleat was rotten on the inside EXCEPT for the last one before its flange, I suppose it doesn't get much flex action in operation.  I also noticed that the OD of the big part of each pleat was just a bit larger than the ID of the small part of each pleat on the new bellows.  So, I cut off the old bellows leaving the last pleat and the flange secured to the actuator, then cut the new bellows to what seemed appropriate which ended up being three pleats.  The new bellows was tough to cut, I ended up using a sharp scissors, it's so compliant it stretches instead of holding and cutting and it's really tough material.
You can also see that the shaft has a groove in it near to end, this will help seal the new bellows.  I test fit the new bellows over the old and it looked pretty good, when you trim the new bellows you do it near the smallest OD but leave a bit of lip behind.  I gave the old bellows a good coat of RTV to help it seal and tried in vain for 1/2 an hour to get it on using every trick and specialty tool I could think of, it just kept slipping off due to the RTV.  So I wiped it off and walked away for awhile to let it dry and clean all that crap off my fingers.  Came back later and it went right back on, then used a short zip tie to hold it in place.
Note the mandatory fermented malt beverage, key to success.
And the rod end was just a matter of pulling the rod out about 1/2 way in its travel (3/4 total travel), goobering in some rtv and using a another zip tie to clamp the bellows to the rod at the groove.  Full travel in each direction and both ends hold over 20 inches of vacuum which is the most the car can make.  I happen to be changing my dash so removal and installation wasn't as bad as with the dash in place but it's still surprisingly more difficult than it should be.  Now my HVAC flapper valve has full travel in both directions, yippee!
#2 Killaphil
Killaphil
  • 303 posts
  • Interests:fast cars
Posted 13 August 2016 - 08:17 AM
You should rebuild one of these and send it to me for harsh real world testing.
(88 SHP Figi) magna mpi, ms1 from scott with funk lab harness, hx35, 3inch, wiseco block with o-rings, port work, 4inch intercooler, methanol,  ST springs/sways, Mad Dax Rack swap, ACT extreme, fidanza, so its mostly stock
(99 ws6 Black) AFR205s, Yella Terra's, Fast 90/90, Kooks, Comp cam, Nano N2O, 4l80e 3400 stall w/ Jakes brake, 9inch w/ 4:10s-SOLD 8/12/2014:(
#3 wrngwae
wrngwae
    Always Smooth like Keith Stone
  • 3,461 posts
  • Interests:trying to keep this motor under the hood, and off the engine stand
Posted 13 August 2016 - 09:30 AM
Good job Scott! i need to do this myself.
1989 Conquest  MOTOR BUILT BY DAD!!!!!!!!!.20 over block. Wiseco pistons.new M28 head w/ ss valves. Holeset Hx35 at 25psi.Snow Performance Meth injection, hurricane MPI intake manifold. 750 injectors. 3" exhaust. 3bar map sensor. Ajusta Head gasket. ARP head studs. FIP updated by Scott87star to control spark, and boost. running MS2.0.6. XTD stage 3 clutch.  I'm likely forgetting something. http://www.enginemachineservice.com http://www.starquestgarage.com
Scotts the man! check out his store.  http://www.starquest...             My site provided by Natallica the sticker Guru http://nbingaman.wix.../gntperformance Posted Image
#4 scott87star
scott87star
  • 4,939 posts
Posted 13 August 2016 - 11:37 AM
Send me  yours Ryan and I'll do the same, you have the hard job of removing and replacing that POS thing.
#5 duckheads
duckheads
  • 664 posts
Posted 13 August 2016 - 12:11 PM
Where do we sign up? Lol
Nice work Scott!!
Visit my site for your performance needs http://nbingaman.wix.../gntperformance
1988 White Starion-Time to modify!
1987 Red Conquest fresh motor, big 16g and MAFT
#6 kev
kev
    Moderator
  • 4,905 posts
Posted 13 August 2016 - 07:26 PM
This is awesome!   I tried and tried to find a fix for this part a few years back.   Great work!
#7 randy
randy
  • 4,092 posts
Posted 14 August 2016 - 07:14 AM
that's great work
#8 Edde
Edde
    Still Dead
  • 11,117 posts
Posted 14 August 2016 - 01:37 PM
Hope this gets pinned :)
#9 Skullzaflare
Skullzaflare
  • 4,731 posts
  • Interests:Computers, hotrods, ratrods
Posted 14 August 2016 - 05:59 PM
is there a guide to getting this out of the car without removing the dash? lol
Spark plug elimination kit
#10 scott87star
scott87star
  • 4,939 posts
Posted 14 August 2016 - 07:35 PM
Go to the Heat and AC section in the how-to's, mike's writeup covers how to get it out.  Hope you like lying on your back and you have small girly hands.
#11 kev
kev
    Moderator
  • 4,905 posts
Posted 16 August 2016 - 10:15 AM
Scott,
Are you ok if I move this to FAQ?
#12 scott87star
scott87star
  • 4,939 posts
Posted 16 August 2016 - 11:19 AM
Please do.
#13 kev
kev
    Moderator
  • 4,905 posts
Posted 22 February 2017 - 09:50 AM
Another option to obtain a replacement bellows;
http://www.starquest...howtopic=153207
Also tagged with one or more of these keywords: foot/face, PITA
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
