Rear Main Seal - Redi-Sleeve Installation
26 replies to this topic
#21 Dad
Dad
  • 8,123 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 25 May 2016 - 08:03 AM
Fel pro sleeve won't work,  I have that and the install tool, it does not allow  room for flywheel to  go on over crank.
#22 kev
kev
    Moderator
  • 4,905 posts
Posted 25 May 2016 - 08:27 AM
Being that I talked so much about it, I might as well add some pics of when the Felpro sleeve was installed.   Unfortunately, I misplaced the part number that I had (but it's the one listed in rockauto).  The sleeve didn't come with an install tool.  I ordered the tool separately but it consisted of a block of delrin that enabled you to drive the sleeve flush with the crank flange.  Obviously that isn't sufficient because you need to drive it further to provide clearance for the flywheel.
I drove this flush with the delrin tool but then had to use a brass punch to carefully (or not so carefully) push it further onto the boss.  You can see from the photos how much I knicked up the sleeve in the process.  I was also concerned about the limited depth of the sleeve and what would happen if for some reason it started to 'walk' on the boss.   This sleeve pushed on a lot easier than the National sleeve, possibly due to the shorter depth but it might be less of an interference fit as well.
Here were the pics of the FELPRO brand sleeve installed:
#23 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 25 May 2016 - 09:11 AM
Kev i did add a link to your post in the SOS manuals, please tell me if this is ok with you.
http://starquest.i-x...p?p=36573#36573
thanks,
Bryan
2005 Acura RL SH-AWD
#24 kev
kev
    Moderator
  • 4,905 posts
Posted 25 May 2016 - 09:28 AM
Looks great!
Sorry to be such a pain.
#25 cyberquest
cyberquest
    Power Poster
  • 4,963 posts
Posted 25 May 2016 - 04:56 PM
no not at all, completely understandable. i know PQs fan base was NOT very big...lol.
but since people still visit his manuals i would like to continue to add as much information as i can.
#26 Guest_STARION_NORTH_*
  • Guests
Posted 25 May 2016 - 06:26 PM
I might suggest for an easier install of either brand of sleeve, try warming the sleeve in an oven to make it expand slightly and loosen the interference fit. Even better, if you can chill the crankshaft in a freezer (obviously before the crank has been installed in the block) and warm the sleeve, it may slip right on by hand if you work quickly. Works like a charm when I install cylinder sleeves into the barrel of two-stroke engine.
#27 Dad
Dad
  • 8,123 posts
    87 White Quest
    87 Shetland
Posted 25 May 2016 - 06:34 PM
Please don't even consider the fel pro sleeve,  it won't fit right, again it has a lip that is a stop at end of crank,  the sleeve has to go past the end of the crank so flywheel flange will clear,  the speedy sleeve is the only one that will fit correctly.
Dad
