How to rebuild the Heater Box and Blower Motor assemblies
STEP BY STEP WITH PHOTOS
19 replies to this topic
#1 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 07:05 AM
This thread is for rebuilding your heater box and blower motor assembly.
Have to add my disclamer:
Please note: I am not a mechanic who works on cars day in and day out! I don't have an unlimited supply of specially tooling! I am an auto enthusiest/backyard mechanic like the majority of us on this site. I've done my best to document how I performed this particular rebuild using standard hand tools and the factory service manuals as my guideline. If you see something in error, please respond via PM. If you see something that may be performed in a simpler fashion, again please respond.
First and foremost: YOU NEED THE FACTORY MANUALS FOR ALL REBUILDS!
Parts required:
  • Open cell foam of .13" and .25" thickness.  See suggested part numbers that I used in thread.
  • Small piece of 3/4" heater hose and some hose clamps
  • As always, any replacement component for an item found bad during the rebuild.
Tooling Req'd: This rebuild was performed with just basic hand tools with exception of the following:
  • 110V to 12V power convertor.  Used to test electrical components out on your workbench
  • Vacuum pump - hand held
Consumables:
  • Green Grease: Doesn't have to be green, I just like it...but you want to use a grease suitable for bearings/axles for the internal components of rotating assemblies.
  • Lithium Grease: I use lithium grease for all of the joints that aren't continually used as well as the joints that are open to the cabin of the vehicle....for the simple reason that lithium grease doesn't have much of an odor.
  • Loctite
  • 3M General Trim Adhesive
kev
Edit 11/5/2014: Lately I have been receiving many requests from club members asking if I would consider rebuilding their parts per the steps shown in these ‘how-to’ threads. Although I am humbled at your trust in my abilities to rebuild such critical parts of your vehicle, I respectively have to decline any such requests. With a family of four, a demanding career, and just the normal responsibilities in everyday life, I have difficulty in finding time to work on my own project vehicles much less take on additional work. However, I encourage you to review the thread in detail, try to gather the required parts and tools, and attempt to rebuild the items on your own. My goal in developing these threads was to give members the encouragement to perform these component rebuilds at home while gaining valuable experience, saving some $, and simply having fun with the hobby. I hope by sharing this information and by including my own trials and mistakes along the way, help to achieve these goals.
Regards,
kev
#2 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 07:33 AM
Heater Box Rebuild:
I'm not going to bore you on step by step photos on taking apart the heater box...everyone knows how to use a screwdriver.   However, I will show step by step installation photos showing how every piece goes back together.   So tear her down to the last part.   The primary purpose of this rebuild is to clean out that 25 year old box...we'lll do a couple checks on the vacuum and electrical systems and then bolt her back together.
During your teardown, do not disassemble the following linkage joint on the underside of your heaterbox.  I guess it isn't a big deal if you do, you can set it later, but it will save you some time if you don't alter this factory setting.
Ok, tear it all down.  Organize your parts and CLEAN CLEAN CLEAN.  No need for mineral spirits here.  Simple Green and water was all that I used to clean everything up.  The parts aren't really greasy, they are just dirty.   For the white plastic items, I did a quick final clean with Wesley's Bright White just to clean up the stains.
The cleaner the better when it comes to all mechanical and electrical components.
First thing first;  test your two vacuum diaphrams.
The first is a double acting diaphram for head/foot/combo that is the most common for failure.  That bellows boot is the air seal!  Believe it or not, but it is!   The bellows boot drys out and rips with time.
Didn't pass this test...here is why:
This component needs replaced.  I pulled out both of my spare heater boxes and found the same problem in this particular vacuum diaphram.  I tried contact cement to glue back the boot...no luck.  Also tried HH66..no luck.  Even on further inspection, you could see that in the ribs of the boot that there are cracks in the rubber.  No sense in trying to repair this unless you can rig up a little spring return or something.....
edit 2/22/2017:  or go here to repair the bellows:  http://www.starquest...howtopic=151807
You can go with a good used part (BTW they are NLA from Mitsubishi).  Or do a modification suggested by another member here (what I chose).  We will revisit this later on.   Lets move on in the troubleshooting/assembly
Other vacuum diaphram.  This one is single acting with a spring return.  This controls the defroster.
This one checks out good and is a pretty reliable diaphram...so it will be retained.  Note:  upon disassembly the white plastic 'nut' you see on the diaphram had spun off and the inner plastic guide that is under it slid down.  I threaded it back in for this test...but will resolve the 'unthreading' issue later on.
#3 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 08:09 AM
Foam replacement:
As everyone knows the foam on the divider panels within the control box (and blower motor box) is so old and dryrotted that it crumbles at the touch.   Everyone tries their best not too touch it and hope it lasts more and more....screw that.  Plus my car was a smoker's car at one point in time (almost 20 years ago)...you can still smell the cig. smoke in this old foam.  Enough said, lets get rid of that old crap.
You can see that most of the foam came off already in the cleaning process.
Take one piece at a time and scrap away the old foam.
This is the air divertor that diverts the air into the heater core.  It had ~.25" open cell foam on both sides.   So lets replace that foam.
Here is what I used.  I bought a large sheet of it to use on multiple projects..you may want a smaller sheet.
From www.mcmaster.com:
Using the divertor as a template, trace out the shape on the adhesive backing paper, cut it out, and stick it on the divertor:Posted Image
Looks good as new!
Next:  this is the divertor for the face/foot.  This is the one that is in the upper middle and is easily seen with the box still in the car.
This one has foam on the one side and on the other has foam with a rubber sheet.
Remove the foam from the side with foam only:
Flip it over.  Now peel off the rubber sheet and rub away ALL of the foam under it.
Now using the same type of foam but with 1/8" thickness:
Cut out two pieces using the divertor as a template.  Note:  This time the foam doesn't wrap around like it did on the last deflector.
Stick it on on both sides:
Now glue back on the rubber sheet.  Make sure you put it on the correct side.  If you forgot which side that is, just match up the small notches on the corner.
I used 3M general trim adhesive as the glue.  Follow the adhesive application instructions for the product you are using.
Next:  Defroster divertor.
#4 kev
kev
    Moderator
  • 4,779 posts
Remove the old foam.  Refoam using the 1/8" thick foam.
Last divertor:  This one has the rubber sheet with foam under on one side and nothing on the other.  Repeat steps above for it.
There you go...all four divertors:
Using white lithium grease, apply a small bit on every hole in the plastic box where the divertors stick thru:
I don't show it here, but use a piece of emery cloth to clean up the rods on the divertors.
Other half of the box.  Note that I installed that small steel bracket...if you removed yours.
Install the two divertors in the positions as shown (in bottom half of the heater box):
I lost a photo along the way...but install the top half of the heater box and snap together with the spring clips.
Next move on to the front two piece section of the heater box:
Grease up the holes.
Install both divertors as shown:
Put on other half:
Snap both parts of the box together with the spring clips:
Here is what you should have together.  Take the time now to make sure that the divertors open and close the way they should...in their respective guides.
If you are comfortable with how the divertors work.  Screw the front of the box onto the main box:
Looks like a heater box again.
#5 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 08:26 AM
Next to the linkages and diaphrams.
First:  defroster vacuum diaphram.
If yours isn't this far disassembled, make it look like this.   Apply lithium grease to the guide and shaft
Insert guide
Apply red loctite to the threads to prevent this plastic nut from spinning off again.  Install nut and snug tighten it.
Bolt back on the bracket.  I use loctite on every screw that threads into metal.  Lube up the pin on the bracket while you are here and install the plastic bushing.
Bolt onto heater box as shown with linkage bracket on divertor panel.
Test that it opens and closes the defroster divertor smoothly:
#6 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 08:34 AM
Now the harder linkage;  the face/foot control
Here are your parts:
Follow the photos for assembly:
Bolt on your double acting diaphram (assuming yours still works or you found a good one).  Note:  I'll come back to this with a modification using a different diaphram...for those of us who can't find a working factor double acting diaphram.
#7 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 08:55 AM
Next to the servo operated mechanism.
Take the black plate and bolt on the potentiometer in the position as shown.
Grease up as shown:
Install linkage arm
Mount motor in position as shown:
Hook up the rest of the linkage:
Mount the entire bracket to the heater box:
Flip over the heater box and connect your under box linkage assembly as shown.
Install protector plate:
Now you a s 110V to 12V transformer to check the function of your servo motor.
NOTE:  PUT LEADS ON THOSE WIRES!  I SHOULD HAVE DONE THAT.  WAY TO EASY TO BLOW THE MOTOR OUT.
Watch the divertors open and close.  The extremes should be as shown below.  You can adjust extremes using the linkage adjustment that I said earlier not to seperate on disassembly.
Note:  it is a stepping motor...so when you apply voltage you will hear 'click..click..click...'  that is normal.
Ok the linkage systems are done.
#8 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:09 AM
Now to the heater core.
Leak test the core first.  I use an old bike tube to apply a couple psi of head to the system.  If you want more pressure, wrap the bike tube in duct tape (I do that later in the final test)  My experience with heat exchanges is that if there is a crack, it'll leak air at as low as 1 psi differential.
Dunk it in water or snoop out the entire core.  Note:  my one fitting was leaking in this photo...I corrected this leak  prior to confirming that there were no leaks in the core
I used some of that 1/8" foam ealier to wrap the top and bottom of the heater core where the old foam was all mashed down.  Also, if you replace your heater core, y ou will need to refoam it as well.
Install it in the heater box.
Oh, I forgot there is one more linkage bar assembly.   This one has to be installed after the core is put in:
Using a piece of 3/4" heater hose and two nice new hose clamps, replace that old forgotton heater hose and obsolete clamp.
Connect your final linkage bar:
Install your pipe bracket
Plug in your t-stat...for 87 and older boxes (doesn't exist on the heater box for 88/89 cars).  This t-stat is for the A/C system...which I am not using...hence why I didn't perform a check on it.  If you use your A/C, check the t-stat per the FSM.
Route your wires as shown:
Install your bracket
One more leak test...the new rubber hose section.  I don't want to find out later on that this leaks.
Note, I duct taped the tube to get more psi.
#9 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:17 AM
Last check.   We didn't test the potentiometer on the servo system during installation.  So lets do that.
Disconnect this linkage for the test:
Connect your voltmeter and test the resistance at its limits.
Reconnect the linkage.
Last thing to do is to recheck the vacuum diaphrams and install the vacuum hoses and bottom deflector.  But lets stop here to do the diaphram modification that I mentioned a few times ealier.  I'll start a new post for this....
#10 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:26 AM
HEAD/FOOT DIAPHRAM MODIFICATION
edit 02/22/2017:  I'd advise fixing your original bellows per the new instructions here: http://www.starquest...howtopic=151807
This modification is per the instruction of ucw458.  Hats off of him for thinking of a way to reuse another starquest part to solve a common issue with our cars!
For the face/foot actuation.  The double spring setup in the linkage system defaults the divertor positions to the middle.  So basically if you loose vacuum, your system defaults to the face/foot combination position.   If your bellows boot is ripped, the face/foot mechanism will work fine for 'foot' only but it will never close the divertors to give you 'face'.   It will simply stay at head/foot combination.
This modification will eliminate the face/foot combination feature in the car!  You will have the choise of face or foot.  It will now default to face with no vacuum!
The modification is to simply remove the double acting diaphram and replace it with a spare single acting/spring return diaphram as used on the defroster system.  Naturally you will need another defroster vacuum diaphram for this test.
See photos on the modifications required to mount this diaphram:
Undo both springs and remove the one shown by the pick:
Mount the new single acting diaphram using the bracket for the double acting one.  It is that simple!
Note the difference in default position.  This is a good quick modification. You loose the face/foot combo...a feature that I don't even use on my newer vehicles...not a big deal.
Do a vacuum check on the new system. It should open/close smoothly:
Might as well check the other diaphram again..we're here
You will need to make one slight modification to the vertical brackets that get installed once you bolt the box in the car.   You need to notch the bracket to clear the vacuum line.  Wait until you bolt everything in the car to do this.  mock up the bracket and mark it for a notch.  Cut your notch and use some foam to rid any sharp edges that may cut the vacuum line.
#11 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:36 AM
Back to the heater box assembly.  Almost done.  Just need to bolt on the plastic deflector and run the vacuum lines.  Naturally I went with the diaphram modification on my heater box.
Vacuum lines...only two used with the diaphram modification. Cap the other one:
Use new vacuum lines of course.
#12 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:44 AM
Heater box rebuild is complete!
Lets move on to the blower motor box
BLOWER MOTOR REBUILD
Ugh...look how disgusting that is:
Again, not going to bore you with the teardown...just the assembly.  So tear it all down...
Here is why you need to rebuild the blower motor!   Take a look at the crud in the motor itself!   Did you know that the blower motor pulls more current that almost any other device on the car when it is running?
NOTE:  This car has been parked since 2000 in my garage...That was 12 years ago on what is now a 25 year old car.  Imagine what yours looks like today!
CLEAN CLEAN CLEAN...and organize.  Same as before...Simple Green and water
#13 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:50 AM
Lets start with the foam replacement on the divertor.
From inspection of the old part:  There is 1/4" foam on one side.  On the other side is a sandwich containing one 1/8" foam, a rubber sheet, and an 1/8" foam overtop.   So that is how we will rebuild it.
Clean off the divertor and clean all the foam off of that rubber sheet...we'll reuse it.
Spray your 3M adhesive on one side of the rubber sheet and one side of one of the 1/8" foam sheets.
Lay the rubber over the 1/8" foam
Stick the other 1/8" foam sheet over the rubber
Stick the 'sandwich' to the panel...note orientation
Stick 1/4" sheet on the other side.
#14 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:54 AM
Test your diaphram....looks similar huh?  Same process as before
Lube and loctite
Bolt on
Using 600 grit sandpaper, clean up the contacts on the motor.  Note how chewed up they are from all that dirt in the motor!   Get them pretty smooth but don't remove too much material.
Snap in metal guide on the plastic box
Lube divertor holes...like we did on the heater box
#15 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 09:57 AM
Linkage assembly.  This one is real easy
There you go:
Test it.  looking for a nice smooth operation.
Here is what we got so far...doesn't that foam look good?  No more disintegrating smoke infested brown crap.
#16 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 10:02 AM
Motor Assembly:
Place a dab of good grease in the bearings on both sides of the motor.  I like using a good hi-temp grease here but don't go overboard.  You don't want it leaking into the motor.  The motor shaft has dust covers to keep this grease where you want it.
Grease the shafts:
Vent:
Motor is together.   Test it's operation...>VERY IMPORTANT!!  You want to know if you did it right now...and not when it is together.
Note that I wised up and put leads on my wires! lol
#17 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 10:05 AM
now to finish assembly.
Putting on the fan and bolting it all up.  Follow along in pictures, no need for words:
#18 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 10:07 AM
new foam surround:
Look how nice that looks now
Install your wiring:
DONE!
#19 kev
kev
    Moderator
  • 4,779 posts
Posted 16 July 2012 - 10:10 AM
Photos of the final product.
Sorry guys, I'm deleting the A/C on this car so I didn't rebuild the evaporator...but it isn't hard to do.
#20 kev
kev
    Moderator
  • 4,779 posts
Posted 06 August 2013 - 10:07 AM
Link to a thread discussing removal/installation of the heater box and blower motor assemblies:
http://www.starquest...howtopic=138420
Also tagged with one or more of these keywords: STEP BY STEP WITH PHOTOS
