REAR SHOCK BOTTOM CLAMP
9 replies to this topic
#1 toofast
toofast
  • 660 posts
Posted 22 October 2018 - 09:25 PM
Is the Clamp that holds the bottom of the rear shocks threaded all the way through or just the back half ?
#2 markhansenconquest
markhansenconquest
  • 3,335 posts
Posted 22 October 2018 - 09:32 PM
yes its fine just the back half , it tightens up when u tighten the bolt that goes in there ......
Edited by markhansenconquest, 22 October 2018 - 09:33 PM.
#3 toofast
toofast
  • 660 posts
Posted 22 October 2018 - 09:46 PM
Thanks I am trying to weigh out my options to get it out so I can change my rear shocks
#4 techboy
techboy
  • 3,266 posts
Posted 22 October 2018 - 10:42 PM
Just back out the bolt and then get a big flathead screwdriver, stick in the split and give it a whack with a hammer.  It should open up wide enough for the strut to slip right out.  I did this a few months ago.
#5 toofast
toofast
  • 660 posts
Posted 23 October 2018 - 06:15 PM
Thanks for the tip :)
#6 TexasQuest
  • 8,841 posts
Posted 23 October 2018 - 10:37 PM
Some penetrating lubricant helps a lot too.
88 Fiji Blue -Tsi
#7 importwarrior
  • 18,238 posts
Posted 25 October 2018 - 09:28 AM
the bolt has to come all the way out... in case you didn't know. in order to remove the strut.
#8 Turbo Cary
Turbo Cary
  • 1,632 posts
Posted 25 October 2018 - 11:41 AM
Using a chisel to spread the slot helps with removal however dont use too big of one and crack it otherwise you'll need a hub assembly
#9 toofast
toofast
  • 660 posts
Posted 02 November 2018 - 08:34 PM
Thanks everyone for some tips, I'm going to try and attempt it this weekend .Hopefully I get that mother out :)
thanks,Gary
#10 toofast
toofast
  • 660 posts
Posted 11 November 2018 - 04:50 PM
Did anyone have any problem with mk1 shock inserts lining up to the two mounting bolts where it bolts to the bottom of the housing ? For the rear.
thanks,Gary
Edited by toofast, 11 November 2018 - 04:51 PM.
