MPI Manifold.
13 replies to this topic
#1 superscan811
superscan811
  • 107 posts
Posted 04 February 2016 - 07:39 AM
Just playing around with a few Magna manifolds, just to annoy all the US members. lol..
Here is the car one of these manifolds will be going on. In US Speek, it's a Sapporo, in Aussie speek, it's a Scorpion.
It currently has a draw through 1-3/4" Stromberg carb setup.
The 2 manifolds I'm tossing up to use are:
1. with  65mm (2.5") throttle body.
OR
2. This (haven't finished it yet) with a 70mm (2-3/4") throttle body.
Should be fun either way.
Also working on a quad 50mm (2") setup for my high comp Normally Aspirated engine.
Cheers.
#2 bflann
bflann
  • 248 posts
Posted 04 February 2016 - 09:38 AM
Man, i had an 82 challenger, cousin of the sapporo, bring back memeries of my college days, i really enjoyed that car, but then came the conquest, BTW, speaking of magna manifold, i really need a fuel rail for mine, i pm'd u about it
#3 stariondreams
stariondreams
  • 420 posts
Posted 04 February 2016 - 12:30 PM
Does Trilogy not make the fuel Rail anymore ?
#4 importwarrior
  • 17,818 posts
Posted 04 February 2016 - 12:51 PM
nope. they do NOT... i need one.
#5 TSIREX
TSIREX
  • 282 posts
  • Interests:Family,conquests
Posted 15 February 2016 - 10:29 PM
I have a oem Magna fuel pressure regulator. $10.
Njv m28 head,wiseco pistons,ARP head and connector rod bolts,3.5 gm maf with maft 2.0. Ajusa head gasket. Engine rebuilt by Kennedy performance in Lexington Kentucky
#6 stariondreams
stariondreams
  • 420 posts
Posted 16 February 2016 - 03:19 PM
i also have a oem magna regulator
#7 mstieg
mstieg
  • 6,147 posts
Posted 16 March 2016 - 11:56 PM
LMK if able to find an OEM Magna roller cam & rockers.
In Progress: breakin & tune
#8 superscan811
superscan811
  • 107 posts
Posted 19 March 2016 - 06:28 AM
Almost done..
Decided to go for a 75mm throttle body. Think it will work well.
Cheers.
#9 importwarrior
  • 17,818 posts
Posted 19 March 2016 - 07:06 PM
Great work. Looking good.
#10 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,065 posts
Posted 09 April 2016 - 12:00 AM
I remember Chad saying before that anything over 65mm is very hard to tune if not impossible on the G54B.
'84 Dodge Conquest Parts car
#11 psu_Crash
psu_Crash
  • 6,969 posts
Posted 11 April 2016 - 08:28 PM
Hogwash! :)
BTW I'd buy one of those fuel rails too! ... and a magna roller cam with rockers ;)
Great looking build!
'86 Starion, MPI with MS2extra, Ebay To4E 57 Trim (in testing), P&P head, OS SS Valves, Wiseco +.030, ARP head/rod, O-Ringed Block, Schneider 284-H, prepped rods,AEM H2O/Meth Injection, Mighty Max CAS 4 Direct Fire Wasted Spark, BSE, Tial 38mm, JDL exhaust mani, HKS turbo timer and EVC3, AEM UEGO, 3" DP into 2 1/2" Dual Exhaust, 75# Delphi's, Magna modded by Chad, Accufab FPR, Walbro 255, D2 Coilovers, Poly Bushings, Funk-Lock, LED Tails and Dome ... etc^4
My Feedback Link
#12 mstieg
mstieg
  • 6,147 posts
Posted 12 April 2016 - 02:02 PM
View Postpsu_Crash, on 11 April 2016 - 08:28 PM, said:
Hogwash! :)
To each their own & kidding aside, but Tim's right if you like physics.  A few questions:
1) Why use a bigger TB than the IC pipes you're running?  You won't flow any more at WOT or less (98% of run time)
2) You run 2.75 or 3" IC pipes?  Again - why?  How big is your turbo's compressor outlet?  None are that big. Won't flow any more
3) So why push MORE volumetric air with greater inside surface area of IC piping (more friction) by running pipes bigger than 2.5" (2.5" is basically = to 65mm)?
Again, back to #1.
That reads more bluntly than I like, but it's to the point.  That's how I build boost at 1000rpm under load. Fit the pieces to match efficiently.  Also, a 65mm Crown Vic/Mustang TB is as cheap as any w/ the TPS you'll need often included or easy to find.
Keep IC pipes & TB the same (2.0 - 2.5" dep on turbo size & cfm) and you'll get fastest spool, throttle response, and easier fine tuning of smooth idle.
Edited by mstieg, 12 April 2016 - 02:04 PM.
#13 creakyjoints
creakyjoints
  • 1,912 posts
Posted 12 April 2016 - 05:19 PM
Cuz bigger is better! ;-)
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,356 posts
Posted 12 April 2016 - 06:00 PM
Yup!
If I could get some of those flanges with the injector bungs in them I could do some cool stuffs
Edited by Funky Phil, 12 April 2016 - 09:02 PM.
