Forged Piston Options? All I can find are two Wiseco part numbers
5 replies to this topic
#1 Grand Duke
Grand Duke
  • 12 posts
  • Interests:1987 Atlantic Blue Conquest
    1984 Ford Mustang SVO
    1970 Ford Mustang Convertible (M code 351-4V)
    1970 Ford Mustang Convertible (F code 302-2V)
    1970 Torino GT (351-4V) Vermillion/White 4-speed Ram Air
    1971 Mercury Cyclone GT (351-2V) Winter Blue
    2001 Ford Excursion 7.3 Diesel
    2003 Land Rover Discovery 2
    1990 Formula 311 Boat Twin 454 Chevy's Bravo 1 drives
Posted 08 March 2021 - 05:31 PM
Is this the ONLY manufacturer that has forged pistons for this car...
K555M92       92.00 Bore    7.2
K555M925     92.50 Bore    7.3
Why is the compression ratio so low on these????  Any preference one over the other?  I was trying to find a set of pistons between 8 and 9 to 1.
Anyone suggest any other manufacturers or forged piston options because I cant seem to find anything other than these two Wiseco options?
Thanks for your input in advance.
Rodge
#2 860QuestTuner
860QuestTuner
  • 481 posts
  • Interests:B and J motorsports
    89 Conquest Tsi
    86 Conquest Tsi Rotted and cut up RIP
    89 240 sx coupe
    85 300zx TURBO Sold
    06 Evo MR
    06 RSX TypeS Traded for truck
    2012 Silverado Z71 crew
    autoX/fishing/shooting/paintball/audio/electrical/beer
Posted 08 March 2021 - 06:31 PM
Mine are Wiseco ASC-03484, 6cc dish, 1288x3.067, 8 to 1 comp. They are 89mm,20 over. Engine Machine Service used to stock these. Specificly for G54B. Try giving Wiseco a call with your needs.
89 conquest Tsi (B and J motorsports)
20 0ver Wiseco 8-1,prepped rods/floaters/arp bolts,lighted/polished crank,IJH crank scraper ,18G/ported housing,ported manifold ,adjustable cam gear,ARP studs, M28 head,Shnieder 274 cam,ss valves,ported int+exh+TB,*DM HP hardpipes,*DM ahp,*DM intercooler,TXS bov ,*DM aluminum Radiator,Moroso oil catch, BS elem.,no AC,TEP dp,HKS exh,CompClutch S2Clutch/Light flywheel,SS clutch line, Walbro255,aeromotive FPR,GM maf,Injen filter,Boostmini TPS,SAFC,MSD,custom poly mounts ENG/Trans,Braided fuel/turbo lines,Hallman pro boost cont.,AEM wideband,,Cusco strut bar/camber plates,KYB struts,ST Springs,custom swaybar links,MK1 adjustable Strut Rods, MK1 rear Camber Plates,TEP rear strut bar, SS brake lines,slotted/crossed rotors,metal master pads,ABS Removed,wilwood prop valve
06 Evolution MR
intake, full int pipes,intercooler,ignition,full exhaust,clutch,flywheel,tune
#3 Dad
Dad
  • 8,214 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 09 March 2021 - 05:05 AM
  He can call and ask for Sue Nash.    They should have some  made already  you will just have to purchase rings.   same ring set up as oem, just whatever oversize. They are higher compression with 6CC dish  Vs oem dish of 15cc
Dad
#4 importwarrior
  • 18,412 posts
Posted 20 March 2021 - 12:26 PM
like to get a set of flattop wsieco's
#5 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,141 posts
Posted 28 March 2021 - 01:58 PM
Flat-tops are 9:1 ish. I tried a set of hyper-u 9:1 and it ran very well but I had the boost very low, like 7 PSI intercooled boost pressure. I tried a set of 8:1 hyper-u's and they didn't fare well at all. Melted at 4 PSI Non-intercooled boost. 2 Different cars.
The reason for a low static compression is because it is far less likely to detonate. The boost can be safely raised higher in a general sense.
IMHO - JE makes the best forged piston at a reasonable price, and they are more expensive than Wiseco. They will be lighter and stronger but I think the only option I had was free floater pins. I wanted those anyway, so it wasn't a problem.
Wiseco is a quality piston too and well worth the money. I have them in 3 engines and JE's in one. The Wisecos are probably the best bang for the buck piston.
If you bore it .075 over, then a Toyota 22R at .030 over is the same size and the pin height is the same. So you can order those pistons and they will work fine if you want to bore that baby out.
'84 Dodge Conquest Parts car
#6 Grand Duke
Grand Duke
  • 12 posts
Posted 05 April 2021 - 02:12 PM
Thanks y'all for the info on pistons,  I got a bit side tracked Feb and March with the passing of my Father which just really hit hard.   :(
For 500.00 for a set... I have to say, I was hesitant to go forward and was looking at just chucking the drivetrain and looking at inline 6 or 2.3 Ford.  However, I guess since the car I guess has the rare color. I decided to stick with the G54B and just try and add value to the car instead of chopping it up.
