Trim clips and Reupholstered seats/door panels?
8 replies to this topic
#1 KO
KO
  • 2,754 posts
Posted 26 November 2017 - 04:30 PM
I see http://www.clipsandfasteners.com has our windshield molding clips, awesome. Trying to remember what the clips look like for the molding outside the door windows? Same? Been years since I've taken that off and do not remember.
Also, back in college I asked a shop how much it would be to get my seats reupholstered, his answer was too much for a broke college kid. Anyone have luck getting your seats and door panels reupholstered?
Insta=extexascoach
Posted Image Posted Image
89 TSi 14G, 2.5"Ex,21lb.Flyw, Sht.Shift, SS Hoses,1G MAS/K&N,
125psi F.Pump, Type-H BOV /H-Pipes, 9" Rears, ST's, KYB's.
2016 Escalade Platinum Edition
2014 Silverado
#2 BC_99
BC_99
    Plays in traffic
  • 5,169 posts
Posted 26 November 2017 - 06:24 PM
I had my front seats redone with pleather and it was $600.
BC
#3 KO
KO
  • 2,754 posts
Posted 26 November 2017 - 07:58 PM
Niiice, appreciate the feedback.
Insta=extexascoach
2014 Silverado
#4 mstieg
mstieg
  • 6,171 posts
Posted 13 December 2017 - 04:35 AM
BC
Did this include new foam, or just the pleather skin?  My seats are in good shape, but leather is just kinda hard, and padding is flat & not cushy.  Further down the list, but just curious.
In Progress: breakin & tune
#5 Matt888
Matt888
  • 307 posts
  • Interests:Not breaking down in the TSi
Posted 28 February 2018 - 07:13 PM
I was quoted $500 a seat for genuine leather and refoaming/forming as necessary.  I haven't executed on it yet.
#6 croquest87
  • 981 posts
Posted 07 March 2018 - 04:39 PM
I got a quote for two front seats wraped in leather w new padding as needed  was around $1300 plus tax
Edited by croquest87, 07 March 2018 - 04:40 PM.
#7 TexasQuest
  • 8,643 posts
Posted 08 March 2018 - 07:52 PM
Yep about $700 a seat around where I live.
88 Fiji Blue -Tsi
#8 Paul87Quest
Paul87Quest
  • 59 posts
Posted 09 June 2018 - 11:31 AM
The door clips are likely proprietary and are a mixed bag when you pull off the trim piece - they will either stay on the door or stay with the molding.  They will not break Just remove the vertical one first pulling towards the center of the window, not outwards.  The clips are strong metal and as long as you don't remove pulling outwards, you should be fine - recommend rolling window down first as well to aid in removal.  The upper one be careful as it will easily deform or twist  prying inwards a little along the length, then repeat slowly prying it off towards the center  - get over eager and you'll damage it.
#9 tux
tux
  • 1,181 posts
Posted 17 June 2018 - 11:15 AM
On the doors, I used Nissan trim clips.  Fit with a little convincing
