trying to upload pics
8 replies to this topic
#1 RWInspired
RWInspired
  • 17 posts
  • Interests:Auto racing, shifter karting, drifting things that shouldn't be drifted. fabrication
Posted 08 December 2010 - 10:32 PM
When I go to create a new album I don't see a "apply modificatons." I thought i was getting somewhere at first, started uploading a pic and it just brought me to a blank screen.?
Edited by RWInspired, 08 December 2010 - 10:51 PM.
88 Starion Esi-R 114,*** JE 8.2:1 .040 over, Preped rods, bs removed, cleaned up hyd non jet head, 284 cam, titanium valves/retainers, arp studs top and btm, 10+ lbs lighter stock flywheel, 3sx aluminium crank pulley, 16g small with ported exhaust, ovcp type H, k&n cut can. etc...
#2 RWInspired
RWInspired
  • 17 posts
Posted 09 December 2010 - 07:18 PM
Would appreciate some help on this one, got many pics of my build i'd like to share.
Edited by RWInspired, 09 December 2010 - 07:18 PM.
#3 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 10 December 2010 - 04:12 AM
Ok, I tried to see what the deal is... looks like the server might be full.
You could try photobucket.com or imageshack.com to upload your photos to.
-Robert
#4 JAinsworth
JAinsworth
  • 16,912 posts
Posted 11 December 2010 - 07:30 PM
Click on the drop down box in the top right hand corner of the homepage next to your user name.  Go to my gallery.  On the left you will see an option for Private user albums.  Once you click on that you will get the option to start a new album. Click on that and fill in the info, at the bottom is a "create album".  that should give you a new album.
On the 2 pic limit, I need to know each step you are doing to insert your pics, I can insert as many as I want.
Jimmy
#5 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 22 December 2010 - 07:07 AM
Ok, figured out the dealio... looks like we can have up to 5mb per user.  But the reason you're getting the error is probably because the resolution is too large.  I resized my images to a modest 800x600 and it uploaded them no problemo.
-Robert
#6 DMNDSTAR87
DMNDSTAR87
    THERMONUCLEAR WARRIOR
  • 1,373 posts
  • Interests:Handguns,Darts,
    Mopars and the NFL
Posted 07 August 2011 - 08:23 AM
cant seem to upload anymore pics---tells me i have used 492k of my 500k global upload upload limit(what is this?)---i deleted all my pics in my gallerys but i t did not help----need some guidence---
thx
gig out
Posted Image  Posted Image
87 ESI-r--Ported/Polished Marnal Njv head,ARP studs,JE 040pistons,+1mm S/S valves,H/D valve springs,match ported intake to T/B and head,52mm ported T/B and inj mixer,850cc/1600cc injectors powered by Acceleronics Versafueler,Degreed 274h cam w/adjustable custom camgear,Spearco 3.5" intercooler w/custom  2.25" hardpipes,MSD 2222 RRFPR, HKS Turbo XS bov mounted in I/C pipe,MBC,H/V oil pump,Walbro F/P,HRC TD06 "super" 20G compressor mated with a TD05H 10cm T3 turbine,Gato T3 header,Innovative Lc-1 wdbnd,3"GM MAS w/MAF-T,AEM filter,MSD6AL ignition box,Bosch coil,BSE kit,lightened flywheel,TEP race clutch,Tep frontstrut bar,S/S hoses,A/C delete,ABS delete,EGR delete,Cruise delete,battery relocated to trunk,relay relocation,Whiteline bushings all around,MK1 adj. camber plates front/rear,ST lwr springs front/rear,ST swaybars front/rear,slotted rotors front and rear,s/s lines and bla bla bla--
#7 Komeuppance
Komeuppance
    Amused.
  • 13,590 posts
Posted 07 August 2011 - 08:25 AM
Are your pictures 800x600??
-Robert
#8 DMNDSTAR87
DMNDSTAR87
  • 1,373 posts
    Mopars and the NFL
Posted 07 August 2011 - 08:43 AM
-Robert
i have them as small as 200x150 and it says file to big----(UPDATE)i cant upload at all now----says my gallery is not available---i uploaded one pic earlier to the home page but even if you click that pic it says unable to display---need some help--
thx
gig
Edited by DMNDSTAR87, 07 August 2011 - 01:48 PM.
#9 jszucs
jszucs
  • 7,326 posts
  • Interests:"Keep the turbo spooled!"
Posted 30 April 2013 - 03:32 PM
thx
gig
Yep getting the same.  Man and I just finished my rim fitment too :(
Seems to work now
Edited by jszucs, 02 May 2013 - 03:31 PM.
