Are camber plates neccesary with Cosmo coilovers?
7 replies to this topic
#1 Preludedude
Preludedude
  • 2,182 posts
Posted 01 January 2017 - 08:55 PM
First, my car will only be driven around 1k miles per year. It is usually driven to the drag strip, and thats it...Maybe a few days to work, and maybe some cruising on my days off.
Now, I am currently installing some Cosmo coilovers, and I seen a few posts recommending camber plates. My car will be dropped around 1.5" I'm guessing.
I really don't know much about suspension. Do I really need to get these?
I see only Mookeeh offers these, and its $180(front) and $100(rear), so for $300 total...
With my car only being driven 1k miles per year, and only used for drag racing?  Do I really need these? I really just planned on getting an alignment done once I got the coilovers installed...
Thanks for any input...
Edited by Preludedude, 01 January 2017 - 08:58 PM.
#2 psu_Crash
psu_Crash
  • 6,923 posts
Posted 01 January 2017 - 09:17 PM
I run the Cosmo setup at a similar drop. I don't run camber plates in the front and the drop gave me aprox -1.5° camber. I run the Mookeeh non adjustable plates in the rear and I also have about -1.5° in the rear.  Since I autocross a little negative camber is what I'm looking for. Long story short, do you need the plates? No, but it will definitely wear out the inside of the tires first.
One of these days I'd like to pick up plates so I can run a little more negative camber.
'86 Starion, MPI with MS2extra, Ebay To4E 57 Trim (in testing), P&P head, OS SS Valves, Wiseco +.030, ARP head/rod, O-Ringed Block, Schneider 284-H, prepped rods,AEM H2O/Meth Injection, Mighty Max CAS 4 Direct Fire Wasted Spark, BSE, Tial 38mm, JDL exhaust mani, HKS turbo timer and EVC3, AEM UEGO, 3" DP into 2 1/2" Dual Exhaust, 75# Delphi's, Magna modded by Chad, Accufab FPR, Walbro 255, D2 Coilovers, Poly Bushings, Funk-Lock, LED Tails and Dome ... etc^4
My Feedback Link
#3 cryquest
cryquest
  • 80 posts
Posted 02 January 2017 - 02:18 AM
I ran the stock top hats with the cosmos for a little bit and the front springs would make a noise when I'd turn the steering wheel. Even though the stock top hats have a bearing on them for movement, the springs would I guess grind along the top or bottom perch for some reason. It made a nasty noise that went away when I installed the camber plates. I don't know remember if my stock top hats had a bad bearing but all I can say is that I have no more noise with the camber plates.
Edited by cryquest, 02 January 2017 - 02:20 AM.
#4 scott87star
scott87star
  • 4,826 posts
Posted 02 January 2017 - 03:08 PM
Quote
Toe is the only thing adjustable on these cars without camber plates, plus our toe is only adjustable on the drivers side, you'll just drive the tech insane if you show up.  There are lots of inexpensive ways to check/set toe.
You can run quite a bit of camber without causing excessive tire wear, you can't run your car too many miles with incorrect toe without trashing the tires.
#5 Preludedude
Preludedude
  • 2,182 posts
Posted 19 January 2017 - 12:23 AM
Got the springs installed today.  Going to take it for a drive tomorrow and see how it feels with the new kyb inserts in front and the Cosmo springs.
I wound up using the stock strut mounts which are worn, but I'll replace them one day....
With the Cosmo, I had to drill out the hole on the aluminum tophat that comes with the springs. The hole wasn't big enough to go over the strut itself...it was only big enough to go over the threaded tip of the strut....
I'll post back with driving results....
#6 psu_Crash
psu_Crash
  • 6,923 posts
Posted 19 January 2017 - 12:17 PM
Yep, that's normal.
My Feedback Link
#7 clow340
clow340
  • 321 posts
Posted 26 January 2017 - 10:48 PM
I don't mean to start anything but how is toe only adjusted on the drivers side?  I thought both sides adjust and can be adjusted equally? When I replaced a tie rod end on the passenger side I do remember only adjusting that side until things were aligned. Is that just what the manual says?
#8 TexasQuest
  • 8,410 posts
Posted 27 January 2017 - 08:54 PM
Because the passenger side tie rods are bolted on, unlike the driver side that has an adjuster sleeve like most cars do.
88 Fiji Blue -Tsi
Zoom clutch, Fidanza flywheel, Stedebani shifter, KYB's, ST springs, ST swaybars, abs delete, a/c delete, cruise delete, JVE, BSEK, TEP steel brake lines, LSP braided cooler lines, CX Racing radiator,  MK1 silicone hoses, MK1 pullies, *DM hard pipes & intercooler,14G turbo, ported exh. manifold, MAF Translator, 3.5" GM maf, Turbo XS RFL bov, *DM 3" exhaust, Cusco front strut bar, TEP rear strut bar, Enkei 92's, HKS turbo timer, AEM wideband, AEM boost gauge, AEM oil pressure gauge, Hallman boost controller
