Haltech f10x ?
6 replies to this topic
#1 SSG_CARTER
SSG_CARTER
  • 40 posts
  • Interests:Fast cars bikes and speed.
Posted 14 September 2017 - 01:11 PM
Any help is appreciated. Would like to use as a fuel computer only. Not knowledgeable about mpi yet still reading
#2 SSG_CARTER
SSG_CARTER
  • 40 posts
Posted 14 September 2017 - 05:45 PM
Nobody has used this type fuel computer ?
#3 speedyquest
speedyquest
  • 3,619 posts
Posted 15 September 2017 - 08:25 AM
Well you haven't asked any questions or spoke about what you want help with. You need to be more specific. Just saying "Help me, I've got a Haltech f10x!" doesn't tell us anything.
#4 SSG_CARTER
SSG_CARTER
  • 40 posts
Posted 15 September 2017 - 11:18 AM
Roger that. I have seen this on one other vehicle and need help with the wiring. Does this replace the stock ecu or is this spliced in. About to jump into mpi. I will go to correct forum as well.
#5 StarquestRescue
StarquestRescue
  • 4,593 posts
Posted 15 September 2017 - 11:33 AM
http://www.haltech.c...vious-products/
#6 scott87star
scott87star
  • 4,791 posts
Posted 15 September 2017 - 12:46 PM
Quote
Please note: This Haltech program is designed to work with early DOS Operating Systems.
In some cases it may work with Win95 or Win98 but if you still have problems communicating
with the ECU you will need to do the following.
Reboot the PC, just as you see text appear on the screen press the F8 key. If caught in time you will see on the screen a bunch of prompts.
Select “Startup in MSDOS mode”, once done you can run the Software.
That translates to difficult to tune, not because it can't be done but relative to newer stuff it will be crude, difficult to understand and if you have a problem there is no support.
#7 SSG_CARTER
SSG_CARTER
  • 40 posts
Posted 15 September 2017 - 01:06 PM
There is member here that runs it. Pablo I believe.Only heard a couple of posts just curious as to how it performed for him. Exploring options before putting more money into it.
