Known good oil pump
6 replies to this topic
#1 mbruneaux
mbruneaux
  • 1,414 posts
Posted 03 October 2017 - 08:37 PM
Anyone have a good oil pump they need to sell?  Please send me a price shipped to 06331.  Thank you.
Canterbury, CT
1998 BMW 528i 5 Speed because the Suburban gets 10 MPG
#2 markhansenconquest
markhansenconquest
  • 3,226 posts
Posted 04 October 2017 - 09:42 AM
whats wrong with yours ?? if yours went bad there could be alum junk all threw your block !!!!  I have one from a 86 that broke the timing chain ....and as soon as the chain broke game was over  ....if u have  ALUM junk in your block or your O - ring is leaking.... the pump will fail again....the pump cant pump oil bubbles.............I pm ed u.............
I can email u a picture ...just need your  e mail addresss...........
Edited by markhansenconquest, 04 October 2017 - 10:05 AM.
#3 mbruneaux
mbruneaux
  • 1,414 posts
Posted 04 October 2017 - 10:33 AM
http://www.starquest...opic=152625&hl=
I'm pretty sure I've replaced the "O" ring in the past so I've isolated the issue to a weak pump.
Canterbury, CT
#4 '87quest
'87quest
  • 839 posts
Posted 04 October 2017 - 11:20 AM
I think Randy (DAD) sells new ones
#5 '87quest
'87quest
  • 839 posts
Posted 04 October 2017 - 11:22 AM
But if you want a used one I have my old one in a box somewhere, I spun a rod and during rebuild I just bought a new one while I was in there. 50$ shipped if you want it
Drake
#6 Tim_C.
Tim_C.
    Addicted Starquester
  • 10,072 posts
Posted 04 October 2017 - 10:04 PM
You should also clean out the pressure relief valve in the pump and add a washer in there, so it by-passes oil at a higher pressure (doesn't allow oil to by-pass so soon). It needs more pressure to push the by-pass piston out enough to allow the oil to go out the relief hole. Then the system will keep a slightly higher pressure than before. I usually gain about 20 PSI oil pressure by doing this when using an old pump on an old block.
Anyway, it is very easy to do and self explanatory once you remove the large nut that holds the spring and piston in there.
'84 Dodge Conquest Parts car
#7 mbruneaux
mbruneaux
  • 1,414 posts
Posted 05 October 2017 - 07:39 AM
I will definitely do that, thanks.
Canterbury, CT
