Help identify black wires
7 replies to this topic
#1 81zfan
81zfan
  • 941 posts
Posted 25 March 2019 - 05:38 PM
Iím in the middle of removing the box on the driver fender and behind it was 2 black wires running into a single eyelet. It was not bolted or screwed into anything.
Can someone help with this. I looked through the manual and cannot find these
#2 speedyquest
speedyquest
  • 4,159 posts
Posted 25 March 2019 - 05:45 PM
Can you take a picture? If it's near the coil it might be a noise reducer for the radio. Otherwise it could be a chassis ground. Really depends on what your talking about.
#3 81zfan
81zfan
  • 941 posts
Posted 25 March 2019 - 05:53 PM
Yeah. I can, but Iíve never posted a picture on here.
#4 81zfan
81zfan
  • 941 posts
Posted 25 March 2019 - 06:01 PM
View Post81zfan, on 25 March 2019 - 06:01 PM, said:
Maybe this will
Work
Maybe this will
Work
Edited by 81zfan, 25 March 2019 - 06:02 PM.
#5 speedyquest
speedyquest
  • 4,159 posts
Posted 25 March 2019 - 07:15 PM
That's a chassis ground. Just clean it up and find a good place to bolt it down for a good ground.
#6 81zfan
81zfan
  • 941 posts
Posted 25 March 2019 - 07:23 PM
I was fixing to post that I had found it in the manual. I must have unhooked it years ago and forgot to bolt it back in. Luckily I’m finding things that was not hooked back up. In the process of cleaning them all and trying to hook a aftermarket fan and stuff up. Thanks man.
Where did you get ignition power from for the relay on your fan install?
#7 speedyquest
speedyquest
  • 4,159 posts
Posted 25 March 2019 - 07:50 PM
My car is completely rewired not using any factory harness so I can't help you there, sorry dude.
#8 81zfan
81zfan
  • 941 posts
Posted 25 March 2019 - 08:07 PM
Oh ok, thanks a million.
