idles/cruises hot
tonight for example, 65 degrees out.
i left work, and on interstate temps stay at 175, raises to 180-185 boosting
on normal road, temps stay around 180-190
if i stop and idle temps start slowly climbing, 205 is highest i let it go
newer engine, 88 with 88k miles, jetvalve
87 car
88 ecu, 1g mas
sr20 aluminum radiator with 16" electric fan
new bpr6es-11 spark plugs (dont even start with the bur7ea-11 thing)
good black/green top injectors
throttlebody is leaking gas onthe sides
any ideas?
  • Replies 71
  • Created
  • Last Reply
Top Posters In This Topic
#1 get the Tbody rebuilt. it is easy to do and worth the $28
it cost for a gasket set. better than your car burning to the
ground.
does the car run or operate fine besides runing hot?
when floored or heavy accelleration? or does it buck
when stepping in to the gas?
i had the same problem running hot all the time.
It could be many things. does it eat rad fluid?
how often do you have to fill or top it off?
have you checked your rad fans? do they turn on
when you ground the lower thermal rad sensor switch
wire? how old is the water pump?
could be a bad head gasket. cracked head, bad T-Body gasket.
clogged radiator if it is stock and never been rodded out.
clogged fuel pump filter might make it run lean.
when you take off the radiator cap and start te car does it
bubble out the top once it reaches operating temp?
did this just start happenning?
Edited by importwarrior
ground.
i already ordered the kit to rebuild the Tb
yea runs fine, unless under heavy load, heavy load it tends to fall on its face til you let ogg to 1/2 throttle
doesnt use any coolent at all
has 1 month old sr20 aluminum radiator with 16" electric fan
engine/waterpump has 88k miles on it
doesnt blow any coolent or bubble
wideband doesnt say its lean, cruising is 16-17afr, boost is 12.3afr, idle is 14-16afr
Those plugs are for the non intercooled lower boost motor why are you using them? They are too hot if you car won't run it has other problems.
If that fan has no shroud its useless and the part that isn't enclosed by the shroud isn't cooling at all unless you are moving.
Those plugs are not removing enough heat, this is one reason the coolant gets hotter but 205 is nothing, don't worry about it. It it hit like 280-300 then drive easy. 230ish who cares the engine is normally at 212 and they said this is the "normal" operating temperature of the engine oil and that would be under no load normal driving not boosting or hard driving either that would mean the temperatures would be higher. You think the coolant is to be cooler than oil? So the coolant would also try to cool the oil when I thought that was what they put the oil cooler on for? lol Too many freak out and say their car is too hot makes me laugh every time.
Next thing is ignition, there is no way to tell if ignition is causing this unless maybe you get 4 EGT probes and watch them spike under boost because air fuel ratio tells you nothing about EGTs at all. EGTs come back to using the wrong heat range plug and that's what you are using and I still can't see why.
You want to know what the specs were for coolant temps and where the gauges lay at what ohm readings and what they define the position of the gauges needle to be here they all are on one page: http://www.b2600turbo.com/SQ%20Cooling.htm
"yea runs fine, unless under heavy load, heavy load it tends to fall on its face "
I bet it does, its about to melt something and those plugs are misfiring so badly this is what is happening. Its not a mystery to me and you took the plugs out you were supposed to use why? You still thought it was "too hot" BS it was not it was just NORMAL. Stop paying attention to people that "claim" this motor is to run COLD and that if it gets even a bit warm it just warps all to hell. It doesn't.
"205 is highest i let it go"
This is being crazy why would you do that and who told you this? Damn the secondary cooling fan won't even work at that low a temperature.
You don't like the OEM spark plugs? Funny, many including mpi people finally switched to using them as all should be.
http://www.b2600turbo.com/images/oilcooler2.jpg
funny, old engine ran cooler though it was on its last leg
the bur7ea-11 run hotter and causes the car to run rough
i did not say it falls on its face, it still pulls just not as hard as half throttle
ignore the fan and radiator, its a custom setup nothing factory controls it
on my temp gauge 190 is 1/2, 205 is 3/4, 215 is tip of red
im a conputer tech, im a cold freak, i dont like anything being warm
the manifold glows between 2+3 as well
You have timing issues, ignition issues that are causing the glowing manifold. Its from the wrong plugs and/or too much timing. Did you set this using a timing light that has a correction adjustment on it? You may have it set wrong you should double check that. Perhaps you used the wrong plug wire (not #1) to set it with?
A stock thermostat doesn't even start to open until 192 and its not fully open until 212.
Doesn't matter if the radiator is "custom" if it has no shroud around the fan, it will not work the fan spins in the air and does nothing it will not "pull" air through the core AT ALL.
I'd not be driving this car until this was all fixed you are on dangerous ground and sounds like near limits that cause pistons to melt.
That temperature gauge is useless for you its range of operation is way too little. I can't even imagine an engine that doesn't get over 215degrees I don't think there are any. Where is the sending unit for it? Is that sending unit matched to the gauge? Did you use a different gauge with a stock sending unit?
the fan cover 90% of the radiator
timing is at 10 btdc, vac off and plugged, idle at 900, yes plug 1
oh yes i just randomly wrote numbers on the stock gauge and hoped they were right....
its installed in the intake mani, sendingunit goes straight to the matching gauge
As long as the outer diameter of the fan blade has at least a flat ring around it that acts as a shroud. You remember what your stock secondary or pusher fan looked like? This is actually a shroud and the fan being that large should work.
The stock gauge has no where near the same readings that you have assigned to it. 3/4 on a stock gauge is more like 250. The "C" mark is about 130 and middle is just about 200-210.
What turbo and how much boost? Its not supposed to glow. I'll assume there are no CATs? What injectors? Fuel pressure regulator?
Pull FPR reference hose off the throttlebody and hook a vacuum gauge to it, rev the motor and see that is shows a vacuum. If it shows vacuum it will also show boost so it can act on the FPR. If the throttlebody was rebuilt and just a tiny bit of sealant if any was used it could clog the passage. Check that if you haven't already.
Does ignition timing change if you unplug the knock sensor?
IF your knock sensor was dead or broken wire and the ignitor is already in safety mode and pulled timing back and then base timing was set then you drive it there will be no bucking or jerking as timing is pulled back because it already is. If at this time you also have a bad vac. adv. it won't pull it back either.
i didnt "assign" it, it was a joke, thats where the stock gauge sits with my aftermarket gauge
small 16g 10.5psi
both cats completely hollowed
stock 88 black and green (dont leak)
stock FPR, idles 38psi, boosts 52psi
ive never touched the knock sensor, same knock box i used on other engine fine, but the TB/sensors were on the engine when i got it (was running fine in his car)
ill put the bur's back in before i leave for work, and tonight when i leave ill see if the manifolds glowing when i stop
Ok I couldn't find the bur7's so I threw the bpr7ix in. In wendys drive thru, no boosting at all, I was idling temps climbing, hit 220 and factory gauge was almost on red line. There's no way the car is suppose to do that from factory
Stock gauge, stock sending unit?
Aftermarket gauge, what sending unit and where is it?
Aftermarket gauge isn't going to work with a stock sending unit but you knew that right?
Easy to test the knock sensor even without a timing light, just unplug it while the engine is running and timing should retard about 7-12degrees and you'll hear that.
stock gauge with stock unit yes, impossible to switch i have a mechanical aftermarket gauge
the gauge is hooked in where the EGR vacuum switch was near the watertemp gauge
Cruising is too lean !!!! 14.7 afr is ideal, 16 afr at idle, too lean again.
Bill
Edited by Caliber308
Bill
what would you suggest i check? in tank fuel filter is clean, fuel pressure is perfect (no hiccups), injectors are good
only thing i can think would be from the leaking throttle body, or 88 ecu, or enginebay fuel filter, or the 1g mas
Leaking Throttle body needs to be addressed. 1st Gen set ups have a tendency to run rich, so I would dismiss that. If you have the money, install the Maf-Translator set up. That way you can adjust the fuel in accordance with your Wideband.Also, try a set of NGKBPR8 spark plugs.
Bill
Bill
i plan to get one but dont have the money right now. my throttle body rebuild kit comes in tomorrow along with my oil pan gasket.
any other ideas?
any other ideas?
Not until you fix the leaking Throttle Body. :) Your A/F Gauge will tell you.
Bill
Ao the tb leak can cause this?
Could be? Fix the Throttle body and see if your A/F readings change, and try some NGK BPR 8s in place of the 6s.
Bill
16g and 10psi is a baby turbo and baby boost
When the air fuel is near 16 and you take off from idle can you hear detonation/spark knock?
What cam do you have? Is it a longer duration intake or stock? Assuming everything IS working and correct a 292 cam causes something like this to happen. If this is what you have then put in an 84-86 injector in place of the primary.
What injectors do you have? If this is a stock cam maybe your primary is wrong and too small iike a B or a K? or its failing have you had them cleaned?
You said you tested fuel pressure did you?
just how much of the thread have you read? i already answered most of that
no knock or clunks
stock cam
stock good green and black 88 injectors
yes idles at 38 and boosts at 52
Bill
ok i rebuilt the TB, and got the oil pan done.
boost afr is 12.05-12.8
cruising is 15-16.5
it has bpr7ix in it right now
cruising is 15-16.5
So doing the Throttle body gaskets helped it run a little richer. Try some colder spark plugs: NGK BPR 8s. And just for kicks, what kind, and the cc rating on your injectors? Boost AFR is fine, but Cruising is still a little lean.
Bill
