NikoFab Posted February 15, 2014 Report Share Posted February 15, 2014 http://portland.craigslist.org/mlt/pts/4333917159.html conquest tsi starion parts (Portland) http://images.craigslist.org/01111_hYhHw2QH4sL_600x450.jpg http://map1.craigslist.org/t06/14/2612/5859.pnghttp://map2.craigslist.org/t06/14/2612/5860.pnghttp://map0.craigslist.org/t06/14/2611/5859.pnghttp://map2.craigslist.org/t06/14/2613/5859.pnghttp://map1.craigslist.org/t06/14/2611/5860.pnghttp://map3.craigslist.org/t06/14/2613/5860.png http://www.craigslist.org/images/map/marker-shadow.png http://www.craigslist.org/images/map/marker-icon.png © craigslist - Map data © OpenStreetMap Clearing out all my starquest parts Full conquest exhaust w/ both cats and stock dual tip muffler Front half stock exhaust- coated, no cats Custom sub box/ amp cover Headliner- black 87 steering wheel 88 steering wheel Trunk area carpet Manifold intake- complete minus ejectors- all sensors Left and right headlight assembly, With motors Gas door Radio trim panel w/ pocket -2, new Dash clock Console tray/ pocket Console/ shifter/ radio trim E- release/ mirror switch trim Drivers side fog light -2 87 mass air w/ intake boot 87 ecu board Heater control trim-2 Headlight switch Full gage cluster hood w/ both switch sets Front license plate bracket New Mitsubishi oil feed line-turbo 87 climate control Turbo water feed line Throttle cable Upper fuel line - new Upper fuel line-2 Two fuel rails w/ regulators Ac pulley- goes on head Inertia performance coil w/ 10mm coil wire 1 & 3 port waste gate actuators Resistor Light controller Water/ thermostat neck Speedo cable Factory radio w/ tape player and equalizer Rear washer fill neck Turbo heat shield- new New turbo xs dsbc New Bosc boost comp regulator 4 bolt axles- low miles-2 Heavy duty Rps turbo pressure plate and new disc set 3 exhaust gaskets 3 turbo base gasket 3 water neck gasket 3 throttle body base gasket New 180 thermostat Ecu relay New v cover gasket w cones Hood prop grommet- new Fog light relay Ac & power relays- new 8 new cowl clips 3 new dash screw cover- plastic piece in lower dash pannel New Mitsubishi pcv valve 4 egr gaskets 3 1/2 moon plugs 1 cam seal- new Oil pump gasket injectors pair- good Billet waste gate actuator plate Radio plate to convert to 1 din deck Short water coupler hose Curved water hose -intake 87 ignitor o-ring for fuel hose to fuel rail injection mixer screw set most parts are Mitsubishi OEM dealership items Tim 971-219-9290 Quote Link to comment Share on other sites More sharing options...
crazystarion Posted March 19, 2014 Report Share Posted March 19, 2014 hi deartail light sale ? Quote Link to comment Share on other sites More sharing options...
TURBOPRO Posted July 21, 2014 Report Share Posted July 21, 2014 How much for the factory radio? Quote Link to comment Share on other sites More sharing options...
