Where do I get a dual gauge pod?
Boosted_One
Lotek Engineering offers a dual gauge pod for 87-89 auto seatbelts
They also offer a single pod for the 83-87 non auto seatbelts.
http://www.gaugepods.com/conquest.HTM
Below is a picture of the dual pillar pod for 87-89's
http://a0.cpimg.com/image/F0/5A/9010160-0ca8-019701AB-.jpg
that's what I'm putting in mine.  I was keeping the boost gauge in the dash but I'd like it out to match up with the AF.  I guess if you wanted, you could throw an auto trans temp gauge in there.
I'd throw an EGT gauge in before anything if I had a vacancy in the pod or dash cluster, second would be a fuel pressure gauge.
Just my .02
Mike,
Might be a dumb question but EGT is exhaust temp. guage?
What is a good one to order and what is an approximate cost?
I want to put boost guage in stock location so I am not wasting space.
Going to put a/f and something else in dual guage pod.
Rick
yellow 88 TSI
EGT Exhaust Gas Temperature.
WWW.westach.com
I am very pleased with the quality of gauge that Westach makes.
Go to their AUTOMOTIVE INDEX:
2 INCH ROUND STYLE INSTRUMENTS:
CHT, EGT, and AIR FUEL RATIO
VACUUM, TURBO-BOOST, and MANIFOLD PRESSURE
VOLTMETER, AMMETER, FUEL LEVEL
FUEL PRESSURE and OIL PRESSURE
OIL, WATER and TRANSMISSION TEMPERATURE
OUTSIDE AIR and CARBURETOR TEMPERATURE
TACHOMETER 0 to 8k , HOURMETER, TACHOMETER 0 to 8k 90°,TACHOMETER 0 to 5k 90°
DUAL COMBINATIONS - BOOST-EGT, BOOST-AIR FUEL RATIO, AMPS-VOLTS
WARNING LIGHT INSTRUMENTS
WHITE-FACED GAUGES - EGT, TACHOMETER 0 to 8k
3 INCH INSTRUMENTS:
CHT and EGT-(PYROMETERS)
TACH-HOURMETER
TURBO-BOOST/EGT
VOLTS, FUEL LEVEL, OIL PRESSURE, FUEL PRESSURE
WATER TEMPERATURE, TRANS. TEMPERATURE
DUALS -  EGT/EGT
TRIPLES - EGT/EGT/EGT
I wonder how they look at night lit up.
They have an orange yellow lighted illumination to them, like a standard gauge usually looks, kinda like the stock gauges.
As a side note: Westach gauges owner Paul Westach is the brother of the founder of AUTOMETER.
Westach has been around much longer than Autometer and if you ask me the gauges are a step up from Autometers,not only in accuracy but also construction. Glass lensed gauges aren't a standard anymore like they once where.
Mike K
  • 3 weeks later...
GAUGE POD PACKAGE: $129.99
(1) TWO GAUGE A-PILLAR POD
(1) BOOST GAUGE
(1) A/F GAUGE
The pods are a lotek design and the gauges are autometer Z-series.
He also carries EGT's.
Ask for Otis at sales@midwestturbo.com
Blue
;D
  • 5 months later...
  • 7 months later...
Any dual pods out there that are a simple side by side deal that just mounts right on top of the dash above the speedo and tach, etc.  shaped kinda like this:? ? ??
       ___
      /OO
(the Os are the gauges)
Would be nice to not have gauges near the line of sight of the "christmas tree" when drag racing in the right lane.
-Matt
Never thought of that.
Also, do these a pillar pods have to be melted and formed to fit, or is it a direct fit - do they screw in, glue?
- Paul
The one's listed under a Mits. Starion should fit without melting and require a screw in method.  The "universal" ones need to be cut with scissors and melted with a hairdryer? <-- as it said on one of the listings above.  If it will melt by a hairdryer I wouldn't want that in my car during the summer!  All locked up it gets hot enough in there to fry eggs on the dash.
Please let me know about my alternatetive pod mounting....if it exists.
Thanks,
-Matt
Interesting Westach gauges.... Two gauges in one face
http://www.frostalarm.com/cat/p12.html
Boost on the left and A/F on the right
Air Temp, Before I/C on the left, After I/C on the right
http://www.frostalarm.com/cat/p10.html
A/F on the left, EGT on the right
  • 5 months later...
  • 1 year later...
Figured I would throw this in the FAQ incase anyone wanted to do it.
I had a Auto meter dual gauge pod laying around from an old 1G DSM of mine.
Put it upto the A-pillar, and bam! it fit.
The only thing that needs to be done with it, is the top corner needs to be trimmed for the seat belt.
So, if you have one laying around, or can get one cheap, it will work.
