ECU pinouts needed for 87 starion
4 replies to this topic
#1 mxphotog
mxphotog
  • 3 posts
Posted 24 October 2006 - 10:02 PM
Does anyone have or know where i can find the ECU pinouts for an 87 starion?? Any help would be greatly appreciated.
#2 Shelby
Shelby
    Rookie
  • PipPipPipPipPipPipPipPip
  • 50,164 posts
Posted 24 October 2006 - 11:04 PM
ecu terminal useage is the same as for the 87- 88/89's,, a couple wires are slightly diff in the 88/89 to the 87's but   it's not  of a great importance
one  thing i do recall is the  power  keep alive mem is   pull'd  from the main power  feed on the 87 , and on the 88/89 it has  a seperate power  wire from the  fuse links
also the 87-88  B38  connector is  in the same location,,but on the 89's  the B38 is to the left of the glove  box  and the wires are  of a diff sizeing , all useage is the same other  then mention'd
pin out for 88/89 is in the fuel section page 14-15 i beleave  or close to there
88TSI Silver
89TSI red auto
#3 JAinsworth
JAinsworth
  • 16,915 posts
Posted 25 October 2006 - 04:46 AM
I believe they are the same as the 86, if so, here it is:
86 TSI:  “A” connector
1: IGN –
2: AFS
3: n/c
4: GND (AFS)
5: Intake temp
6: Coolant temp
7: Idle SW
8: Motor Position SW
9: Pressure to gage
10: +5 volt power
11: O2 sensor
12: Ignitor signal
13: n/c
14: n/c
15: TPS
16: n/c
17: Intake temp (OVCP)
18: n/c
19: speed (coil)
20: n/c
21: Diag. Output
22: control relay (fuel pump)
23: secondary air (for catalyst)
24: pressure solenoid
86 TSI “B” connector:
1: +12V
2: GND
3: GND
4: EGR
5: IGN (cranking)
6: AC relay
7: +12V
8: Inhibitor
9: ISC + (out)
10: Injector # 1
11: ISC – (in)
12: Injector # 2
13: +12V backup
#4 JAinsworth
JAinsworth
  • 16,915 posts
Posted 25 October 2006 - 04:48 AM
You can find the 88 pin-out on page 14-11 (Fuel section of the FSM).
View online at www.starquestgarage.com
Jimmy
#5 Chad
Chad
    noob
  • 9,182 posts
  • Interests:Starquest Fanatic
Posted 25 October 2006 - 11:21 AM
Jimmy, the 87's are the same as the 88/89's, the 86 is unique.
the 87 is this: (I'VE NOW ADDED COLORS TO THE CHART) AND EDITED THE DECRIPTIONS FOR THE 87.
THESE ARE STRAIGHT OUT OF AN 87 MANUAL FOR THE 5 SPEED ANALOG GAGE MODEL (WIDE BODY).
87 TSI “A” connector:
W  1: IGN – (coil)
WB 2: AFS
LR  3: Motor position SW
B   4: GND
GR 5: air Intake temp
YG  6: Coolant temp
YR  7: Idle SW
      8: n/c
      9: n/c
GR  10: +5 volt power
W   11: O2 sensor
YB  12: ISC – (in)
YB  13: Ignitor advance
LY   14: MPS GROUND backup
GW 15: TPS
BW  16: Barometric sensor
       17: n/c
       18: n/c
LgB 19: Speed (coil)
RG  20: secondary air (catalyst)
BR  21: Diag. Output
WR  22: control relay (fuel pump)
YL   23: ISC + (out)
87 TSI “B” connector:
R   1: IGN +12 V
B   2: GND
B   3: GND
RW 4: EGR
BY  5: IGN START(cranking)
BW 6: AC switch
R    7: IGN +12 V
BY  8: GROUND
YG  9: Boost gage
YB 10: Injector 1 (primary)
BR 11: Ignitor signal FOR INJECTOR TIMING
YL  12: injector 2 (secondary)
B   13: +12 V CONSTANT
