Drake's MPI swap
48 replies to this topic
#1 '87quest
'87quest
  • 839 posts
Posted 18 May 2017 - 08:05 AM
Well guys I've finally decided to go mpi! I've read through a lot of threads on this topic but I'm sure I'll still need some help/advice so any is welcomed. I recently purchased a hurricane intake and am waiting for that to show up to post pics of it. My plan is to run Scotts new megasquirt system when he gets it finished. The only thing I'm not 100% on is the ignition system. I have what appears to be a locked caravan distributor so I'm thinking I'll run that instead of messing with a crank trigger, just not exactly sure how that distributor will work? I believe I'll need an msd 6al ignition box too.
Will also be upgrading to a cx racing intercooler and making new 2.25" hardpipes. Hoping I can keep the battery in stock location but we will see. Also running a snow water meth injection system so I'm not sure if that will make things like tuning more difficult or not. Well I'll post up some more pics when parts start showing up!
Before pic
Again any advice is greatly appreciated!
Drake
#2 importwarrior
  • 18,390 posts
Posted 18 May 2017 - 09:06 AM
Scott can answer all your questions for sure!
i have 3 options for ignition.
locked stock Dizzy
Australian Dizzy from a magna. like an eclipse type with cam and crank sensors in it .
crank trigger.
i will let Scott decide whats best and go with that. to me the crank would probably be best.
#3 tux
tux
  • 1,615 posts
Posted 18 May 2017 - 09:24 AM
I've got a Magna dizzy laying around (it was brand new, I tried to use with my AEM, never got it to start, AEM said resolution was too low).
If you want it, let me know
#4 '87quest
'87quest
  • 839 posts
Posted 18 May 2017 - 03:33 PM
Yes I'm already in a convo with Scott. This is the distributor I have here I believe it's a locked caravan dizzy? It has two wires coming from it.  Will this be good or am I better off going with a crank trigger setup?
Drake
#5 scott87star
scott87star
  • 5,095 posts
Posted 18 May 2017 - 04:09 PM
Lots of high HP distributor cars out there and it is the easy thing to start with.  I like the crank trigger for the rock solid timing but that's something you can do easily later.
#6 '87quest
'87quest
  • 839 posts
Posted 18 May 2017 - 08:10 PM
Cool! If the one I have will work I'll probably just use that for now at least. Goal hp is 400 but not sure if I'll get there with a TD06SL2 18G but we'll see.
#7 Woody
Woody
  • 382 posts
  • Interests:Starions
Posted 21 May 2017 - 12:58 AM
I'm in the middle of going MPI. I already have the aftermarket computer running though and I had to change the dizzy for that to the aussie magna one. I highly recommend the magna dizzy.
www.sweetfrostings.com.au
#8 '87quest
'87quest
  • 839 posts
Posted 21 May 2017 - 03:58 PM
Is the magna dizzy different than a caravan one?
#9 importwarrior
  • 18,390 posts
Posted 21 May 2017 - 06:40 PM
The magna is a direct fit.
The only main difference is that it is like an eclipse crank cam sensor type.
4 wire.
#10 tux
tux
  • 1,615 posts
Posted 22 May 2017 - 12:10 PM
Ya it's different than caravan.  It has a Crank and Cam Angle sensor in it.
#11 '87quest
'87quest
  • 839 posts
Posted 22 May 2017 - 05:18 PM
What would you guys recommend for me? Is the magna dizzy good to go for 400 hp or would I be better/save money in the long run to do a crank pulley trigger wheel setup? (<-- stupid question but this way would eliminate the dizzy completely right?)
If I'd be better off spending a little more money now and not have to deal with anything else in the future I'd rather do that but I'm not too familiar with all these choices for the ignition system when going mpi. Also would I still need a 6al ignition box with a crank trigger setup?
Thanks in advance
Drake
#12 TexasQuest
  • 9,139 posts
Posted 22 May 2017 - 05:22 PM
I would go with a Magna dizzy in my opinion. They're easily obtainable from the Aussie guys and they're relatively cheap.
http://starion.mrbde...m.au/magna.html
Edited by TexasQuest, 22 May 2017 - 05:24 PM.
88 Fiji Blue -TSi
#13 '87quest
'87quest
  • 839 posts
Posted 22 May 2017 - 11:20 PM
Got the manifold today and it looks very good. There are a few things I'm not sure about like the block off plate on the head, only the one vac port on the rear (would it be dumb to weld in a plate with a few more nipples? Or maybe just keep T'ing off the one?) and the coolant passage not connecting to the rear like the original but I'll do some more research and try to see what others have done to make it work. Here's a few pics for you guys
#14 Matt888
Matt888
  • 372 posts
  • Interests:Not breaking down in the TSi
Posted 23 May 2017 - 02:21 PM
Nice!  Your engine compartment is sweet looking as-is!  I ended up getting a plug and play Megasquirt from Scott and it came with a locked dizzy for the stock setup.  I'm shooting for same HP when I swap over to MPI.  I believe I'm going to go with the Holset HX35 turbo.
#15 '87quest
'87quest
  • 839 posts
Posted 23 May 2017 - 04:02 PM
Thanks, fun car as TBI but will be happier with the power and reliability of a nice mpi build.. once I have it all done it'll all be powdercoated to look just as good or better.. and will have a lot of nice TBI parts for sale then too.
#16 TexasQuest
  • 9,139 posts
Posted 23 May 2017 - 07:55 PM
Congrats man, those are really nice intakes.
88 Fiji Blue -TSi
#17 '87quest
'87quest
  • 839 posts
Posted 23 May 2017 - 08:42 PM
Thanks Tex, I've wanted one of these ever since I first saw one like 8 years ago lol
#18 TexasQuest
  • 9,139 posts
Posted 25 May 2017 - 06:54 PM
Yeah they had literally just stopped production on them right after I joined SQC. :unsure:
88 Fiji Blue -TSi
#19 '87quest
'87quest
  • 839 posts
Posted 30 May 2017 - 05:22 PM
Anyone that's ran a hurricane manifold, what intake gasket did you use? My mani has a thin piece of metal rtv'd to where the fuel pump block off plate was, but not sure if a regular blue felpro will work? Or maybe I need two?
#20 importwarrior
  • 18,390 posts
Posted 02 June 2017 - 04:49 AM
i had my fuel pump opening welded shut. no more worries...
it is counter sunk. i need to get a pic.
