Fog Light Mod....
27 replies to this topic
#21 JAinsworth
JAinsworth
  • 16,871 posts
Posted 05 June 2008 - 04:45 PM
Just guessing because I have not done it but wire the power for them to the wires going to the parking lights maybe?
Jimmy
#22 livesTSI
livesTSI
  • 1,425 posts
Posted 07 June 2008 - 08:29 PM
QUOTE (GCNTSi @ Jun 5 2008, 03:48 PM) <{POST_SNAPBACK}>
Mine did the same thing, the headlights stay on in the down position when the parking lights are on, so the light hits the ground behind the spoiler, looks kinda funny. But I'd like to know how to correct it so only the foglights stay on with the parking lights.
-GCNTSi.
Im not positive that its the problem, but really the only thing you couldve done wrong is spliced into the wrong wire. The one your supposed to tap into is green/white(green with white stripe). There are a few other green wires at the same spot so you have to been careful.
I just followed KO's original instructions and mine work just fine.
-Matt-
89 Fiji Conquest TSi *Complete Overhaul in Progress*
#23 starquestPilot
starquestPilot
  • 815 posts
  • Interests:General Aviation, RC Helicopers, Square Dancing
Posted 08 June 2008 - 10:36 AM
Here's how you make the "fogs on when button pressed" mod. Very easy - takes about 15 minutes.
1) At the fog light relay: Cut the GREEN wire and "T" it into the RED wire. Cap the GREEN wire at the wiring harness. (Page 8-62 of '88 Conquest Manual).
Before: Attached File  FogBefore.JPG   10.92K   52 downloads    After:  Attached File  FogAfter.JPG   11.39K   52 downloads
Enjoy!
'84 Conquest (black w/gold/tan)
'85.5 Starion (grey/black)
'85.5 Starion (white/black)
'87 Starion LE auto (white/red)
#24 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 08 June 2008 - 10:55 AM
Starquestpilot, does that keep them on if the key is out/ignition off? If so, I don't want that. But your diagram is great. Please clarify.
#25 JAinsworth
JAinsworth
  • 16,871 posts
Posted 08 June 2008 - 11:24 AM
QUOTE (Technology @ Jun 8 2008, 11:55 AM) <{POST_SNAPBACK}>
No, they will go off when the battery dies...you gotta remember to turn them off.  At least that is the way mine work and he wired them smile.gif
Jimmy
#26 SFBMX88
SFBMX88
  • 1,497 posts
Posted 08 June 2008 - 03:25 PM
If you made "2-G" go to a SWITCHED 12 volt source(ignition switch), you wouldnt have to worry about turning the fog lights off.
I assume "2-G" normally gets its power from the headlight circuit, and the fog light switch completes ground on "RG".
#27 SFBMX88
SFBMX88
  • 1,497 posts
Posted 08 June 2008 - 04:01 PM
The switched 12v can come from either the ignition switch(12v+ on the coil maybe), or splice from the power wire to one of the "parking/marker" lights.
Be sure to have a voltmeter handy!
Edited by SFBMX88, 09 June 2008 - 12:28 AM.
#28 starquestPilot
starquestPilot
  • 815 posts
Posted 09 June 2008 - 07:25 PM
QUOTE (JAinsworth @ Jun 8 2008, 12:24 PM) <{POST_SNAPBACK}>
No, they will go off when the battery dies...you gotta remember to turn them off...
Push the switch and the fogs are on - push it again and they're off...
Mike
