Vacuum pump swap
1 reply to this topic
#1 Spooled_Starion
Spooled_Starion
  • 483 posts
Posted 31 July 2018 - 02:19 PM
So the vacuum pump is not functioning in my 87 and I have a replacement pump but it's from an 84/85. The electrical connector looks to be the same and it looks identicle to the one in my 87 minus having different mounting brackets. It looks like I can just swap the brackets over to the 84/85 pump and bolt it right in. My question is how do I know if it would be compatible with my 87 and work correctly other then doing the work and finding out? Has anyone used a vacuum pump from an earlier year and have it function in a later model year?
#2 Speedy2222
Speedy2222
  • 524 posts
Posted 31 July 2018 - 03:51 PM
all the plug does is power. The pump bracket is different because of the vac pump was mounted on the opposite side up front on the earlier years.
