Starion D50 Swap, Bad milage please help
starion D50 gas milage bad
1 reply to this topic
#1 retyhabmore
retyhabmore
  • Newbies
  • Pip
  • 1 posts
Posted 02 December 2017 - 05:18 PM
Okay, so I swapped the Starion 2.6 into my didge D50, its on a set of brand new 31 mastercraft MXT's, before the swap the original 2.6 got around 20MPG average using a weber carb. my current set up is a megasquirt 2 assembled, wideband, ford edis wheel and sensor, but not using the EDIS brain. stock tbi set up with new injectors from injector clinic, im getting 8-10mpg highway.....55mph, 2600rpm, stock boost, im shooting about a 14AFR cruising and 11.5ish when boost starts kicking in. im attaching my tune file so maybe someone can help me get going in he right direction. thanks
#2 boostinmini
boostinmini
  • 805 posts
  • Interests:G54b, 4G63, anything mitsubishi especially pre 2000s, custom fabrication and mountain biking.
Posted 03 December 2017 - 01:21 PM
Hey you sound like you have the same set up as my truck.
Is it auto?
I set my afr target table up so on highway i get around 15.2:1 afr, 14.7 is standard.
I get about 18us miles per galon highway with a little intown.
I am running 89 max 4wd, auto, 4.64, 235/75/15, ms1, edis, water meth, 19c td06sl2, starion front mount, stock internals truck engine except arp and mls headgasket
Also tagged with one or more of these keywords: starion, D50, gas milage, bad
