Caravan intake MPI conversion???
15 replies to this topic
#1 Phantom
Phantom
  • 115 posts
Posted 10 February 2019 - 12:14 PM
I have done a search but unless I missed it, I didnít find any clear answers. Has anyone actually converted one to MPI? Thanks.
#2 speedyquest
speedyquest
  • 4,035 posts
Posted 10 February 2019 - 12:17 PM
Has anyone converted what to MPI? Are you referring to a Dodge caravan, a Starion, or maybe you mean using a caravan intake as a base to create an MPI manifold?
#3 Phantom
Phantom
  • 115 posts
Posted 10 February 2019 - 12:25 PM
Caravan intake to MPI for use on Starion.
#4 speedyquest
speedyquest
  • 4,035 posts
Posted 10 February 2019 - 07:17 PM
I've not seen it done but that doesn't mean nobody has done it. I don't necessarily believe it would work well BUT I would also say if it interests you then definitely try it. If done correctly it will cost less than the other standard options and maybe you will learn from the experience.
#5 Phantom
Phantom
  • 115 posts
Posted 10 February 2019 - 10:49 PM
My thought was to also use a Ford 5.0 intake elbow and throttle body to mate up to the ported Caravan intake. Big issue I see from my end is not knowing optimum distance for the bungs from the cylinder head flange as well as depth &  angle of the bungs.
Edited by Phantom, 10 February 2019 - 10:51 PM.
#6 speedyquest
speedyquest
  • 4,035 posts
Posted 11 February 2019 - 01:21 AM
Id say use the magna intake and how its made as inspiration. Also though don't get too hung up on making it perfect. Remember, the stock manifold uses two injectors facing the floor of a manifold with unequal length runners and its nowhere near the intake port so anything you end up with will be an improvement. I fabricated an adapter plate so I could use an intake manifold from a mazda 626 turbo engine. The runner spacing was off, the injectors don't point at the intake valve, and that manifold wasn't intended for the motor, yet it still works great and only cost me about $70 in materials. With some careful consideration, some understanding of the basic principles of how the manifold delivers the air and fuel, you'll end up with something that is at the very least slightly better than stock.
#7 speedyquest
speedyquest
  • 4,035 posts
Posted 11 February 2019 - 01:24 AM
Some inspiration for you.
#8 Phantom
Phantom
  • 115 posts
Posted 11 February 2019 - 03:17 PM
Got it. I appreciate the pics!
#9 Speedy2222
Speedy2222
  • 521 posts
Posted 11 February 2019 - 07:20 PM
Hey Speedy, Speedy here, What thickness material did you use for the 626 adapter? i've had one here for years i've been wanting to do this one but havn't had a chance to mess with it. what did you use for a throttlebody?
#10 speedyquest
speedyquest
  • 4,035 posts
Posted 11 February 2019 - 08:08 PM
Hey Speedy, this is Speedy responding. The thickness I used was 1/2" but if you could go a bit thicker you could have an even smoother transition between the two different port spacing. And the throttlebody on there is a mustang 4.6 liter one. No idle control stuff because race car haha!
#11 Funky Phil
Funky Phil
    Super Pooper
  • 6,425 posts
Posted 11 February 2019 - 10:37 PM
Heres a bunch of diff manifolds for the 2.6. Should give some ideas...
http://www.sqperform...php?topic=203.0
#12 jinx
jinx
  • 1,884 posts
Posted 12 February 2019 - 01:37 AM
cool intake link. Would be good to add the mazda/probe.
CNM had an unusual center mounted MPI intake. Can't remember if the plenum or injectors/rail were mounted underside
#13 freebird
freebird
  • 2,878 posts
  • Interests:time is of no moment, but only what your doing
Posted 12 February 2019 - 06:19 PM
i thought maybe a member named artinist did this kindof mpi to the manifold. maybe it wasnt the straight runner caravan intake im not sure. just search the name artinist pics may appear but that was a long time ago.
#14 Funky Phil
Funky Phil
    Super Pooper
  • 6,425 posts
Posted 13 February 2019 - 01:16 AM
Man the cnm mpi i saw had couplers for runners. I have their webpage around here somewhere.
Maxboost did i reallt cool mpi for stock hardpipe location
Edited by Funky Phil, 13 February 2019 - 01:17 AM.
#15 TexasQuest
  • 8,806 posts
Posted 13 February 2019 - 11:07 PM
Honestly in my opinion it's not really worth the time and effort. You'll probably see minor improvements over a stock manifold even with equal runners & 4 injectors. Save your money and do it the best way with an mpi manifold.
88 Fiji Blue -Tsi
#16 jinx
jinx
  • 1,884 posts
Posted 14 February 2019 - 08:59 AM
Option to add, some guy started adopting the 3rd gen eclipse steel intake. Looks like a medium length header, and the throttle body already faces the correct way. G54 probably enhanced even more, Lots of cheap ones in usa jukyards.
Never heard how it tuned out. Sound concept tho
caravan intake ports shoot direct from plenum to head, without the oem "Y". So in theory should go better MPI converted
oem probably put the Y there to help channel the centrally injected fuel to the ports.
if converting, you should be able to grab a caravan, Kcar or mitsu pickup carb intake for pennies. A ton of those things were junked
Geos holley 4-barrel carb blowthru on carb g54 intake ripped. Full weight with a 60-1 @ 23psi ran 11.8sec 1/4
MPI/caravan intake + standalone should be an improvement in every facet = good stuff.
Quote
the CNM intake had an oblong plenum with a central inlet, facing the strut tower and curved runners to ports, iirc
Would be nice to see those CNM web pages. I liked his upgrade stages and approach. Content seemed methodical & no-nonsense
James was a very cool dude on the phone. I was just about to order when the drama hit. Too bad it all went sideways
