Wtb 89 trans pan - 5 speed
17 replies to this topic
#1 tux
tux
  • 1,624 posts
Posted 14 September 2020 - 04:27 PM
Looking for a trans pan for an 89.  My 87 pan is bent and leaking.
#2 1sicdsm
1sicdsm
  • 18 posts
Posted 15 September 2020 - 07:06 AM
legion elite get the stronger one
89 Conquest TSI
97 Eclipse
86 IROC big tire drag car 8.97 at 150 mph
04 Banshee 391cc
98 Banshee with 900rr motor
yfz 450 with 500cc two stroke
#3 tux
tux
  • 1,624 posts
Posted 15 September 2020 - 10:55 AM
I'm cool with the waffle if anyone has it
#4 ucw458
ucw458
  • 11,731 posts
Posted 15 September 2020 - 11:19 PM
Make one.  You have your old pan for a bolt hole template.  Get a thick piece of flat stock from your local metal supplier.  Then use RTV instead of a gasket.
My 87
#5 tux
tux
  • 1,624 posts
Posted 16 September 2020 - 12:37 AM
I will if nobody has a waffle one available.  No way I'm paying 100$+ for a plate someone put a couple holes in.
#6 ucw458
ucw458
  • 11,731 posts
Posted 17 September 2020 - 09:25 PM
I hear you on that.
My 87
#7 1sicdsm
1sicdsm
  • 18 posts
Posted 18 September 2020 - 07:34 AM
like you said it is pricey for a piece of metal.but if we don't support the people who support our platform then they will be gone.
89 Conquest TSI
97 Eclipse
04 Banshee 391cc
#8 Preludedude
Preludedude
  • 3,569 posts
Posted 18 September 2020 - 09:31 AM
What strain is on a trans pan?   Why is it relevant if one is “stronger” than another?    Serious question here.
What impact does a pan have?
#9 obsolete
obsolete
  • 504 posts
Posted 18 September 2020 - 09:50 AM
There's a good reason modern manual transmissions don't have large removable pans anymore. No matter how strong the pan is or how tight you bolt it on, the big hole in the case makes the whole design weaker and allows it to flex more, which contributes to the shafts/gears spreading under load and causing damage. Mitsubishi knew about this when they made the 88-89 plate stronger as a band-aid, but the real fix is a design like a T56 where the case is one solid piece that slides over the shafts/gears and bolts onto the front plate.
#10 tux
tux
  • 1,624 posts
Posted 18 September 2020 - 11:08 AM
Understood, but if it's overpriced, it's overpriced.
#11 1sicdsm
1sicdsm
  • 18 posts
Posted 18 September 2020 - 12:19 PM
I looked up a 1/2 thick t651 1ftx1ft is 65.21 + shipping .so if you don't have a piece lying around you still have to spend.and as stated the hole is a big flex point email sitewhirks@gmail.com  from starquestparts.net he has a good inventory
89 Conquest TSI
97 Eclipse
04 Banshee 391cc
#12 croquest87
  • 1,812 posts
Posted 18 September 2020 - 08:01 PM
Go to the scrap yard  and find yourself a nice piece of aluminum . Cant be more than $10.
#13 Dad
Dad
  • 8,201 posts
    87 White Quest
    87 Shetland
    83 Starion- Chevy powered
    ___________________________
Posted 18 September 2020 - 08:36 PM
I stock the gaskets if you get to that point
#14 tux
tux
  • 1,624 posts
Posted 18 September 2020 - 08:37 PM
The metal mall near me is 40$ for a piece of 1/2"x8"x8" t651
If nobody has one available i'll be doing that.
#15 tux
tux
  • 1,624 posts
Posted 18 September 2020 - 08:38 PM
Thanks, I actually acquired the felpro 5mt kit from advance auto.  I didn't see them on your site when i was looking
#16 ucw458
ucw458
  • 11,731 posts
Posted 18 September 2020 - 10:28 PM
Who says it has to be aluminum?  1/4" steel would be stronger and cheaper.  And only a little heavier but not enough to matter.
My 87
#17 tux
tux
  • 1,624 posts
Posted 19 September 2020 - 11:26 PM
Oh it's 8.5" x8.5". Not 8x8 as I previously stated.
Steel is fine.  I don't care much about the weight
#18 tux
tux
  • 1,624 posts
Posted 22 September 2020 - 07:27 PM
this can be closed.  I got a 1/4" steel plate for 20$ cut to size
