Axle/diff question....
7 replies to this topic
#1 Starionslider
Starionslider
  • 299 posts
Posted 31 October 2017 - 03:57 PM
Know a guy with a open diff in a 87, wants me to swap in a lsd he bought. Are the axles gonna fit or are they a totally different axle? I feel like ive read about people swapping in lsd's with same axles on 87's but ive been looking all over and cant seem to find the info.
#2 Turbo Cary
Turbo Cary
  • 1,609 posts
Posted 31 October 2017 - 08:15 PM
I know there are differences in 4 bolt axles. I had tried to get some for my 86 but the ones they sent looked right but were wrong. The bolt spacing on the hub side was off. I ended up rebuilding my own.
Not sure if that helps but it did feel like the axle side went in smooth.
#3 markhansenconquest
markhansenconquest
  • 3,329 posts
Posted 31 October 2017 - 09:21 PM
Is your car a wide/body 87 or flatty 87 intercooled ??does it have a LSD diff ? Intercooled axles are diffrent on the hub side ,, that's why a non intercooled will not fit ,,,unless u grind the 4 holes oval to make it fit...............The ones on rock auto are for non intercooled cars...........
Edited by markhansenconquest, 31 October 2017 - 09:23 PM.
#4 87redcat
87redcat
    10 years and counting...
  • 3,798 posts
Posted 01 November 2017 - 05:49 AM
3 types of axles.  Flatbody 4 bolt. Fatbody 4 bolt. Fatbody 6 bolt.
Non are interchangeable
Most parts stores have the the flatbody 4 bolts.  The other 2 have not been sold new in years.
#5 Starionslider
Starionslider
  • 299 posts
Posted 01 November 2017 - 06:56 AM
So the inner joints are different? I understand the outer 4bolt vs 6bolt on the hub side.
#6 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 01 November 2017 - 08:49 AM
The non intercooled 4 bolt axels are slightly longer but the splines are the same. Many have used them with the 4 bolt intercooled lsd with no reported problems.
#7 Starionslider
Starionslider
  • 299 posts
Posted 01 November 2017 - 07:00 PM
Ok thanks. If they are the same i will have another spare diff for my beast too....will just need some welding hahaha
#8 JDM
JDM
  • 94 posts
  • Interests:Restoring Aussie and JDM Starions GSR-V & GSR-VR
Posted 02 November 2017 - 06:29 AM
There's more to this equation. It also depends on whether the car is 4 lug or 5 lug.
Regarding 4 bolt axle shafts, the spline count on the '87 diff side should match. However,
if the open diff car is 4 lug, then the shaft wont match with the 5 lug LSD shafts on the hub side.
Just change the matching hub flange on the hub axle to make it bolt up (providing you have access to both sets).
Edited by JDM, 02 November 2017 - 06:30 AM.
